Old 06-25-2012, 12:05 AM   #1
Marrk
Drives: Honda Fit
Gearbox: Cable Link or Mechanical Link?
Now that the cars are out in the hands of retail buyers, do we now know for certain whether the gearbox has a cable linkage or a mechanical linkage or something else?
I haven't seen anyone post on this. In fact, I haven't noticed a lot of comments regarding the MT gearbox.
Thanks. :happy0180:
Marrk is offline   Reply With Quote
Old 06-25-2012, 12:25 AM   #2
JP
Backyard Fabricator
Drives: JZX83, SF5 GT, ZZE82 turbo
it's mechanical
JP is offline   Reply With Quote
The Following User Says Thank You to JP For This Useful Post:
Marrk (06-25-2012)
Old 06-25-2012, 12:29 AM   #3
Marrk
Drives: Honda Fit
@JP: Did you drive one? How does it feel?
Old 06-25-2012, 07:23 AM   #4
Zadkiel
Drives: CBS BRZ Limited 6MT
Very notchy. When you get it into gear, you definitely feel it.
Back in (Crystal) Black.
Zadkiel is offline   Reply With Quote
The Following User Says Thank You to Zadkiel For This Useful Post:
Marrk (06-25-2012)
Old 06-25-2012, 08:32 AM   #5
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
Mechanical link > cable link.
Though a lot of people used to cable linkages in their economy cars will probably complain about feeling the synchros mesh and the engine vibration through the stick. *sigh*
Old 06-25-2012, 10:22 AM   #6
Marrk
Drives: Honda Fit
I keep hearing that the gearbox is notchy. Even the magazines report this. Hmm. I wonder how this will go. Will Toyota-Subaru make improvements as the car evolves from one model year to the next . . . ?
Old 06-25-2012, 10:40 AM   #7
Draco-REX
Corner Junkie
Draco-REX's Avatar
Don't see why they should. It doesn't interfere with shifting. As it is, it's only notchy when cold, and even then its only a slight roughness between gears. *shrug* I don't have an issue with it. I'd rather feel more from the transmission than less.
The Following User Says Thank You to Draco-REX For This Useful Post:
Sportsguy83 (06-25-2012)
Old 06-25-2012, 10:46 AM   #8
DeepHunta
Drives: '05 Outback Wgn, '05 Lotus Elise
I think it's mechanical. I hear every gear switching. And yes, like everyone says, it is notchy. Sometimes it scares me when I hear these sounds but I suppose it's for a purpose.
I like it. Huge difference when I drive my Legacy 2.5gt.
Proud ex-owner of GBS 6MT BRZ Limited. Pre-ordered on Feb-29-2012, got VIN on 5/19 with ETA 6/6, arrived early on 6/2, but still didn't pick it up until Jun-6-2012. Recently sold the Buuurz as of 4/21/2014
DeepHunta is offline   Reply With Quote
Old 06-25-2012, 10:48 AM   #9
Marrk
Drives: Honda Fit
You make it sound as though, when people like magazine writers note a notchiness in the shifting that they are noting it because it's no big deal. If it were not an negative issue, they would not note it.
Do I sense that there is some resistance on your part to see the car as anything other than perfect? Intolerant of critique, perhaps?
Old 06-25-2012, 10:51 AM   #10
Sigh-on-Rice
Waited 5 years for this
Sigh-on-Rice's Avatar
Drives: '18 MX-5 Club
How does one feel the synchro mesh? Is it by a noise or by a vibration or by an impact?
Old 06-25-2012, 11:50 AM   #11
Draco-REX
Corner Junkie
Draco-REX's Avatar
Do I sense that there is some resistance on your part to see the car as anything than perfect? Intolerant of critique, perhaps?
You seem to think I'm taking this personally.
The problem is that when people complain to the manufacturers, they try to fix things. Which is great for big issues (i.e. tail light condensation). But when it's a non-issue like a little roughness in the shifter, there's a potential for the "fix" to go too far. I'd rather a little roughness in the shifter than having a shifter with no feeling at all. This isn't a luxury car where the driver is to be shielded from the mechanics of the car. This is a sportscar where the driver should be a part of the process.
This type of "softening" is what has progressed the STI from the raw 04 to the current one which is heavier, softer, and lacks a lot of the feel of the original.
As far as the severity of "notchiness" I don't see what the big deal is. When the gear oil is cold, yes it's got a little rough spot between gears. But when the transmission is warmed up the shifter moves smoothly from gear to gear. So it's only a temporary condition with minimal impact on feel. I can shift this car with my fingertips. It's a non-issue.
I'm not anti-improvement, I'm anti-softening. I like having Nav and heated seats in my car. I like A/C and power windows and locks. The keyless entry and start system is really cool and fun to use. But what I don't like is stuff that gets between me and the car's controls.
I miss cable throttle. Not because I think it can do the job better than Drive-By-Wire (DBW), but because I miss being able to feel the engine's vibrations through my foot. I could tell when it was running rough, or even when it came up to temperature. That layer of communication is gone from today's cars, and I think the driving experience is lessened by that.
The feel through the shifter starts as an almost rubbery feel as the synchros come in contact and the friction material matches revs. Then there's a slight click as the teeth align followed by the shifter slipping into gear very easily. I can tell by the feel when I've engaged only the first synchro and lost the rev match with the second which causes a grind.
Don't pistol-grip your shifter. Just use your fingers and feel what the transmission is doing. The more in-tune you are with the workings of the car, the better you can utilize it.
The Following 5 Users Say Thank You to Draco-REX For This Useful Post:
Marrk (06-25-2012), Sigh-on-Rice (06-25-2012), Sportsguy83 (06-25-2012), Tomzilla (06-25-2012), tripjammer (06-26-2012)
Old 06-25-2012, 12:23 PM   #12
Marrk
Drives: Honda Fit
@Draco: Points well-taken. I'll just have to drive it myself.
Most of the people here don't know what their talking about, but when the magazines all note notchiness, then I pay a little attention. Not much, but a little.
All the magazines universally praised the S2000 gearbox. That was a gearbox that some people here might describe as notchy (especially when cold). It was very short and very direct. But I loved it.
Old 06-25-2012, 01:28 PM   #13
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Do you consider isolation from the mechanics of the car an improvement?
I consider it a problem. It's already more isolated/vague than the S2K trans, it certainly doesn't need to get worse!
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 06-25-2012, 02:03 PM   #14
Marrk
Drives: Honda Fit
That's not what I'm saying. I am taking the word "notchy," when people use it about the FR-S/BRZ gearbox, as a negative critique. A direct linkage that feels direct need not be "notchy."
Why is this so complicated?
If I said that the car slipped out of gear and into neutral under load, you would say that that is a problem. You would not respond by saying, "Do you want a car that stays in gear or do you want a car that is involving to drive?"
:happy0180:
Link to FR-S standard and premium HU manual Sport-Tech Electronics | Audio | NAV | Infotainment 22 06-02-2012 06:46 PM
Five Axis Poll Thread Link Memphis Scion FR-S / Toyota 86 GT86 General Forum 3 05-26-2012 09:28 AM
Brand new FT-86 video w/ring tone link - Final reveal ezmayo FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 7 12-01-2011 06:40 PM
Top Gear UK are ecxited too (article link) Infernal Scion FR-S / Toyota 86 GT86 General Forum 4 10-20-2011 12:55 PM
