Old 10-02-2016, 07:19 PM   #15
UFO
Drives: 2013 Scion FR-S, 2014 Audi S4
Don't know what af.., means, what mods, and can you be more vague?
AFAIK = As Far As I Know.
He's talking about the 86Nanny: http://www.beastronix.com/shop/86nanny-pedal-dance/.
UFO is offline   Reply With Quote
The Following User Says Thank You to UFO For This Useful Post:
mdm (10-02-2016)
Old 10-02-2016, 07:38 PM   #16
mdm
not a twin owner
mdm's Avatar
Drives: 2016 Veloster Turbo DCT
Yes. I did not remember the name of the device.
mdm is offline   Reply With Quote
Old 10-02-2016, 08:59 PM   #17
Zaku
-Proud of Brzerhood-
Zaku's Avatar
Drives: '17 BRZ CWP LMT.
should I take the 15 and my 17 out to track and slide it around for you guys to get the solution? lol
I think the replies on this thread is pretty on point.
so far yes, track mode doesn't seem to interfere as much from my experience.
I don't really care for the primacies on either car, but I need to find time to actually take both cars and slide it around and I've only slid a 13 around track once a year or two ago, I would need to do it back to back.
heck I'll even look for a pro driver to do it, since I might not be the best candidate, I'll need permission for the 15 I have possession of.
this might take a bit or arrangements... not gonna promise anything.
Bottom line is the posts on here are pretty on point already.
The Following 2 Users Say Thank You to Zaku For This Useful Post:
deejaylew (10-03-2016), Tjs Blunts and Coffee (10-03-2016)
Old 10-03-2016, 02:45 AM   #18
SuperDave
SuperDave's Avatar
Drives: DAT Rally Blue BRZ
Wasn't it made clear that track mode in the 2017 car = pedal dance in 13-16?
SuperDave is offline   Reply With Quote
Old 10-03-2016, 08:10 AM   #19
deejaylew
deejaylew's Avatar
Drives: AP1 Honda S2000, Focus RS
Nope. Holding down the traction off button on a 17 would be more akin to the pedal dance.
deejaylew is offline   Reply With Quote
The Following User Says Thank You to deejaylew For This Useful Post:
Zaku (10-03-2016)
Old 10-03-2016, 08:45 AM   #20
No. Holding it down does the same as before but they are a little more forgiving on the 17s. It specifically says this in all the official materials. To completely turn them off you still need the pedal dance.
Beastronix (10-07-2016), deejaylew (10-03-2016), mdm (10-03-2016)
Old 10-03-2016, 11:05 AM   #21
deejaylew
deejaylew's Avatar
That goes contrary to a post earlier in this thread which is what I was referencing when I gave that answer. Which official materials did you get this info from, is this in the manual?
Originally Posted by WWFT86 View Post
Holding the "Traction-off" button (leftmost button, looks like a car with skidmark and the word "off" at bottom) for 3 seconds while he vehicle is stopped get you into an ALL-OFF (aka. You're on your own) mode -- This is what Toyota/Subaru intended for completely turning off TC and VSC. Brake LSD will be off as well if it's a MT but in an automatic transmission the Brake LSD will be in "TRACK mode" still. In the first gen FRS/BRZ with MT, Brake LSD remained on in this mode and often cause interference when the driver wants to take full control. This is perhaps why there was a need for the pedal dance (someone from 1st gen pls confirm?)
Indicator light so you know you're in this mode: "TRAC OFF" and "Car with skidmark with word OFF at bottom"
To turn off this mode, simply press the "Tracktion-off" button. This mode will also be turned off when:
- regular key-start vehicle -- engine switch is turned to "LOCK" position
- push-button-start vehicle -- push button ignition turned off
- note this mode will NOT turn off even after reaching 50km/h (~31 mph)
Old 10-04-2016, 12:16 AM   #22
WWFT86
Drives: 2017 BRZ Limited
I agree with deejaylew on this one... Holding down the "Traction-off" button (e.g. the leftmost button) for 3 seconds on MY17 cars with Manual Transmission should have the same effect as the pedal dance on 1st Gen FRS/BRZ, as the users guide says that will turn off TC, VSC, and Brake LSD.
Now if you have the Automatic transmission MY17 you'll still need to do the pedal dance to turn Brake LSD off as well, as in the Automatic holding down the "Traction-off" button for 3 seconds only turns off TC and VSC, while the Brake LSD reamins in "Track mode" and not completely off.
I stand corrected but the button that Tcoat is referring to is the TRACK button (rightmost button).
WWFT86 is offline   Reply With Quote
The Following 2 Users Say Thank You to WWFT86 For This Useful Post:
deejaylew (10-04-2016), Zaku (10-04-2016)
Old 10-04-2016, 10:22 PM   #23
dradernh
Drives: Used to Drive:Grand-Am GS #54 E36M3
Here's your pro: Aaron Povoledo - http://povoledotrackdays.com/wp/
I've used him extensively at tracks all over the Northeast, Quebec, and Ontario, and he's more than capable of sorting this out in short order.
dradernh is offline   Reply With Quote
The Following User Says Thank You to dradernh For This Useful Post:
sroby (08-01-2019)
Old 10-04-2016, 11:11 PM   #24
Toyarzee
Shibby!
Toyarzee's Avatar
Drives: '14 White FR-S, '01 turbo mini taco
I'm having a laugh reading, and may be proven wrong just the same, but I'm going to toss my bets that it's just a change in the threshold, but otherwise same shit different story...
Toyarzee is offline   Reply With Quote
2017 86 bruce CANADA 73 02-27-2017 11:51 AM
?? about the 2017 changes. UAmach1 Scion FR-S / Toyota 86 GT86 General Forum 26 03-28-2016 08:55 PM
2017 86-LIKE IT? bruce CANADA 16 03-28-2016 08:47 PM
