Old 09-28-2016, 11:17 AM   #435
Koj
Koj's Avatar
Drives: Toyota GT86
Sorry my bad
Torry spoke about MAF...
Means, MAF is ok, as mine on V2 Kit, but you need to change your MAP sensor.
Page 27 in that thread
Originally Posted by Gearbanger View Post
So got my HKS kit with the smaller pulley making 11.5 lbs of boost but stock MAP sensor only reads 5.5 max. I picked up omni 3 bar but the HKS can tune doesn't read it. So I order the analog boost tap for the P3 kit just curious if any one with the HKS kit or P3 gauge has any tips. HKS can tuned for e85. I ordered an analog boost accessory from PS wheres a good place to pick up the boost reading from the HKS kit? Boost gauge port or Vacuum tap. Thanks
I didn't check on internet, but seems to be true.
Torry ? you could confirm ?
Koj
S/C HKSv2, HKS R Spec Manifold, Fujitsubo Authorize R Type S Catback, and more...
My Journal/Garage
Koj is offline   Reply With Quote
Old 09-28-2016, 01:49 PM   #436
Torry@HKSUSA
Torry@HKSUSA's Avatar
Drives: HKS
Originally Posted by Koj View Post
Sorry my bad
I just got more clarification on the way this works.
The HKS tune uses only the MAF for fuel management while in boost, not the MAP sensor. Therefore, it doesn't matter than the stock MAP sensor maxes out at 1 bar because it's not being looked at while the car is in boost.
The only reason to upgrade the MAP sensor would be if you are using a tune other than HKS that utilizes the MAP sensor to control fuel mapping.
If you have an upgraded MAP sensor and try to run the HKS tune, it will not work out of the box. However, the MAP scaling can be adjusted by an HKS Pro Dealer and the HKS tune an be modified to accommodate the different MAP sensor, it just won't do it out of the box.
Torry@HKSUSA is offline   Reply With Quote
The Following User Says Thank You to Torry@HKSUSA For This Useful Post:
Koj (09-28-2016)
Old 09-28-2016, 07:17 PM   #437
renesis808
Drives: 2014 BRZ Limited
ok. so its seems that if I'm just going to bolt on the V3 kit and use the FE 91 tune, i DONT need a new MAP sensor.... right??? LoL
renesis808 is offline   Reply With Quote
Old 09-28-2016, 07:25 PM   #438
HuntingtonFRS
Drives: 2013 Scion FR-S in White
Correct! Save your money! You'll have to send your HKS editor to HKS for the 93 tune if you can get that gas nearby.
HuntingtonFRS is offline   Reply With Quote
Old 09-28-2016, 07:40 PM   #439
wbradley
Sarcastic SOB
wbradley's Avatar
MAP sensor upgrade is necessary for a speed density table based custom tune. My car was dyno tuned with Ecutek, speed density based.
The Following User Says Thank You to wbradley For This Useful Post:
Koj (09-28-2016)
Old 09-28-2016, 10:20 PM   #440
Koj
Koj's Avatar
Drives: Toyota GT86
It is based on a postulat :
- The "Subaru" MAF sensor is very good
- The "Subaru" MAP sensor is very good
But is it true ?
Maybe enough for the stock Engine. But for a supercharged engine ?
That's why some experienced mechanics wanted/adviced me to change the MAP Sensor, and tuned the ECU themself based on a very good MAP Sensor.
So ... what do we do ?
Let's resume, we have 2 solutions :
- Install HKSv3, let the stock MAP & MAF Sensors, use HKS "General FA20" Maps,
or
- Install HKSv3, change de MAP sensor, tune a perfect Map based on a very good MAP Sensor.
For me, HKS USA sell the V3 Kit + Map "in the box" for some people that don't care if the maps are general (like the Open Flash Tablett), and those who want a better price.
It is not so stupid. It s like the OFT after all... with a HKS warranty, and already in a box.
Thanks all for your informations.
I will sleep less stupid tonight
Koj
My Journal/Garage
Old 09-28-2016, 10:37 PM   #441
HuntingtonFRS
•There is no maP with the HKS kit.
•HKS is designed to work using the factory maF for readings.
•You need an aftermarket tune to run HKS based on a maP sensor.
Old 09-29-2016, 09:48 AM   #442
Koj
Koj's Avatar
Drives: Toyota GT86
@HuntingtonFRS you should look to that
[ame="https://www.youtube.com/watch?v=EGb_onFcXo0"]HKS V3 SUPERCHARGER for FR-S / BRZ - YouTube[/ame]
#12001-KT003 GT S/C System Pro FR-S MSRP $3,800.00
#12001-KT003A GT S/C System ECU Package FR-S MSRP $4,100.00
Koj
My Journal/Garage
Old 09-29-2016, 10:43 AM   #443
HuntingtonFRS
Why? I have V3 installed in my car with the ECU...
Old 09-29-2016, 11:16 AM   #444
Koj
Koj's Avatar
Drives: Toyota GT86
because HKS is selling a GT S/C System ECU Package with 3 maps for $4,100...
http://www.hksusa.com/gt-supercharge...fr-s-brz-2013/
Koj
My Journal/Garage
Old 09-29-2016, 11:20 AM   #445
HuntingtonFRS
•91 octane
•93 octane
•e85
It does NOT have a MAP sensor. Also, read above where HKSUSA stated this.
Old 09-29-2016, 11:28 AM   #446
Torry@HKSUSA
Drives: HKS
But is it true ?
The stock MAF sensor works just fine. There is no reason to replace it. There's not much to make it not "very good"...it either works or it doesn't, and the stock one obviously works.
For the MAP sensor, the stock one is a 1 bar sensor. It works just fine for reading pressures below 1 bar. It's not that it's not "very good," but the reason to upgrade is to get a sensor that reads more pressure.
However, this is not needed with the HKS tune, as the HKS tune is not based on speed density. It uses the MAF to manage fuel. So upgrading the MAP sensor with the HKS tune literally does nothing except for making it not run because it sends a different scaled signal to the ECU (the MAP sensor is used to stabilize idle on the stock or HKS tunes). If you have a MAP sensor that reads more than 1 bar, then you have to modify the HKS map to scale it correctly and compensate for the different reading.
The Following 2 Users Say Thank You to Torry@HKSUSA For This Useful Post:
HuntingtonFRS (09-29-2016), Koj (09-29-2016)
Old 09-29-2016, 11:53 AM   #447
Koj
Koj's Avatar
Drives: Toyota GT86
Originally Posted by HuntingtonFRS View Post
•91 octane
•93 octane
•e85
You/We are mixing M.A.P. (Manifold Absolute Pressure) and maps/tunes for the ECU.
HKS is selling 3 maps/tunes
•91 octane
•93 octane
•e85
included in the Kit SKU:12001-KT003A
HKS is not selling M.A.P. (Manifold Absolute Pressure)
Are we agree now ?
Koj
My Journal/Garage
Old 09-29-2016, 11:55 AM   #448
HuntingtonFRS
You re mixing M.A.P. (Manifold Absolute Pressure) and maps/tunes for the ECU.
•91 octane
•93 octane
•e85
Are we agree now ?
Jesus Christ dude. That's what I was telling you but you seemed to need to argue that they were selling a MAP.
Kraftwerks Supercharger Owners Thread projek_01 Forced Induction 4310 04-07-2025 01:12 PM
P&L Turbo kit Owners thread Hawaiian Forced Induction 73 07-07-2018 02:31 AM
Five Axis Edition FR-S Owners Thread digital_assassin FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 563 07-08-2015 09:22 PM
**Offical 213/323/626/818 owners thread** mr. slim Southern California 71 10-07-2013 12:58 PM
Supra Owners Build Thread BoostJunkie Other Vehicles & General Automotive Discussions 164 03-12-2012 09:37 AM
