Old 09-28-2016, 04:06 AM   #1
BluePaperClips
Drives: BMW
Question Supercharger on stock motor reliability?
Hey guys, I've been lurking around this forum for some time and just couldn't find the answer I was looking for on supercharging a stock motor and its reliability. From what I've read this is what I know (please correct me if I'm wrong)... S/C is more reliable than T/C and better the tune, better the reliability.
So my question is, how reliable will a supercharged, stock motor, with a good tune, be for daily "spirited" driving? Now I know there are always the possibility of something going wrong, but let's say I don't spin a bearing or push a piston out the side, will it hold up?
Thanks in advance!
P.S. Don't have a BRZ/FRS/86 yet, but driven the BRZ multiple times and already know I would like to bump up the HP in the future. (Also this might be the deciding factor on jumping on getting the BRZ!)
BluePaperClips is offline   Reply With Quote
Old 09-28-2016, 04:25 AM   #2
swarb
Search.
http://www.ft86club.com/forums/showthread.php?t=15044
http://www.ft86club.com/forums/showthread.php?t=68600
http://www.ft86club.com/forums/showthread.php?t=89354
http://www.ft86club.com/forums/showthread.php?t=50672
http://www.ft86club.com/forums/showthread.php?t=81693
http://www.ft86club.com/forums/showthread.php?t=85034
In short, supercharger is more reliable because it is harder to add boost and harder to make cheap parts.
Old 09-28-2016, 04:45 AM   #3
BluePaperClips
Drives: BMW
@swarb As mentioned, I have been "lurking around this forum" and searched and not found the answer I was looking for...
Yes I know this vehicles' platform is still relatively "new", but I'm looking towards a number chart, sort of say, to how many miles/years someone has gone (or still going) with a S/C or T/C, on stock motor, without any signs of giving out. Or how long someone has gone with a S/C or T/C, stock motor, and the motor went kaput.
Maybe I have missed it and if I did I apologize and ask that you point me to the right direction.
Old 09-28-2016, 05:06 AM   #4
swarb
Search.
http://www.ft86club.com/forums/showthread.php?t=77475
http://www.ft86club.com/forums/showthread.php?t=35315
http://www.ft86club.com/forums/showthread.php?t=70780
In the end, it is difficult to get reliable data as there are too many variables. Too much boost, bad tune, money shift, cheap/failed parts, bad fuel, ignoring warnings, etc... From my personal experience, most people who blow their motors don't tell anyone, let alone tell the internets of their failure. They usually end up- building it, swapping it, selling the kit to rebulid, or giving up and moving on.
Edelbrock has a sc kit with a warranty.
Boost goes up, reliability goes down. Simple as that.
Do you have any idea of the cost? or how much do you expect to spend? What is your budget? Or power goals?
Old 09-28-2016, 08:12 AM   #5
bfrank1972
Drives: 2013 FR-S Argento
He did, twice. probably one of the most discussed topics on here - basically of you're looking for oem type reliability with boost buy something oem like a stock wrx. aftermarket kits are always pushing an engine past its design, and as swarb mentioned there are too many variables (installer, tuner, how much boost, driving style, track exposure, supporting mods, climate, etc). if you're not at least somewhat prepared for the possibility of blowing your motor, don't do it.
Sent from my SM-N920V using Tapatalk
Old 09-28-2016, 08:20 AM   #6
GsxrMe
GsxrMe's Avatar
Drives: Late 2014 Subaru BRZ
Completely agree, that applies to EVERYTHING. If you can't afford to fix it, don't do it!
Super charger or turbo, no cheap way to get the car as close to 99% complete under 10k with supporting mods. If your not looking to push 280+ bhp then save your money.
Dont take corners with knock offs, dont skip on supporting mods like the oil cooler and dont be cheap with your tune.
On another note. Im really sorry for anyone living in a CARB enforced state. The BHP limitions to dollar ratio really makes it tough.
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe
GsxrMe is offline   Reply With Quote
Old 09-28-2016, 10:53 AM   #7
ajcarson11
Drives: 2013 Subaru BRZ Limited (Black)
If you choose a supercharger that produces lower levels of boost you will be better off. I know @whataboutbob has run his Innovate/sprintex 210 on his car for over 62000 miles. He is now upgrading, but the point stands -- The 210 puts out only 8.5lbs of boost out of the box, and this will help ensure longevity of motor.
On top of this, it is all in the tune.
If you are going turbo, you will HAVE to know what you are doing to ensure long engine life. There are so many variables in turbo setups.
I'd recommend HKS, Edelbrock, Jackson Racing, or Innovate due to company reputation, and history in this forum.
ajcarson11 is offline   Reply With Quote
Old 09-28-2016, 02:43 PM   #8
BluePaperClips
Drives: BMW
@swarb Thanks! Guess I wasn't searching the right terms/words.
But I am the type of guy who'll rather spend a little more time and money to get everything right then cut corners. Budget isn't a huge issue as I can save and/or buy parts separately as my budget allows me to. Not looking to make insane gains, just something to get a little over or around my e36 m3 hp range (240~whp), which a s/c should be able to do.
And as to "if I can't fix what breaks", it's not that I can't. It's a matter of it being a nuisance and hassle. And who WANTS their motor to go bad, I surely don't.
Again, thanks everyone!
Old 09-28-2016, 02:47 PM   #9
ajcarson11
I do agree with GSXR for the most part but I want to add one thing:
If you go lower boost (in my opinion you don't NEED 280 BHP... I'm on the innovate 210 at 225bhp and its plenty with all the torque under the curve) you don't need a ton of supporting mods necessarily. In my case, its likely that an oil cooler would over-cool my car for daily driving (which is primarily what I do). If you do ANY sports driving off the street (autox, track) you will need supporting mods for sure -- But in the case of a low boost application, you can get away with less IF you are only daily driving.
All in, I am $2500 in my supercharger setup, with the purchase of a used Innovate 210 non-intercooled unit, DIY install, and a tune from Mike at moto-east (who is known for an excellent tune for this SC).
10k is what you will spend if you're looking for 280bhp and expecting the car to last while tracking on occasion.
Old 09-28-2016, 02:49 PM   #10
Matt@Cosworth
Drives: blue - Cosworth SC stage 3.0
Its all in the tune, choose a tuner who can provide back up and has a happy customer base and you won't go far wrong
another thing to be aware of is the difference between the centrifugal and positive displacement type chargers and what kind of power delivery you want
Matt@Cosworth is offline   Reply With Quote
Old 09-28-2016, 03:14 PM   #11
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
I blame my laziness on this, but does anybody have a compilation of the psi levels of the carb approved/lowest settings of each SC/turbo option?
Old 09-28-2016, 03:30 PM   #12
bfrank1972
This is the most important thing - and I highly recommend finding a reputable tuner near you (although I'm not sure I'd want a tuner that lives over the rainbow ).
Old 09-28-2016, 04:39 PM   #13
CSG Mike
CSG Mike's Avatar
@BluePaperClips: Edelbrock is so confident in their supercharger, that they will warranty your *ENTIRE POWERTRAIN* if you have your Edelbrock supercharger installed by a qualified installer, and run their supplied tune with an otherwise stock powertrain.
Then there's the Jackson Racing kit, which is by far the most popular kit in competition. @Jackson Racing has won all but one of their regional STU class races this year, testement to their kit's performance and reliability.
Old 09-28-2016, 06:02 PM   #14
scraejtp
Yep, I think people like to throw high numbers out there to justify their excessive spending.
Picked up the Edelbrock kit here, new during the promotion. For $5k with an oil cooler up and running with no problems.
This is all costs, running supplied CARB tune w/ ECUTek and license, self-install, and Forester oil cooler (helps warmup, no turbo heat in oil).
scraejtp is offline   Reply With Quote
how much psi can the stock motor hold? xUhMeyziing Forced Induction 56 10-13-2017 06:43 AM
Turbo Reliability VS Supercharger reliability KGB Forced Induction 130 09-08-2015 09:55 AM
STOCK MOTOR 3k Anthony7515 Engine, Exhaust, Bolt-Ons 16 11-25-2014 03:48 PM
Stock Motor Cross Want-To-Buy Requests 2 08-01-2014 06:47 PM
Fully built motor with a supercharger. Ruckus Forced Induction 38 10-30-2013 11:21 AM
