#2997 |
Drives: Toyota 86 GTS Auto
Gents, got a tricky question.
I've been out at night for a drive and on a u-turn on a very dark road I've managed to whack the curb with the front left. It looked like there was only grass on the roadside. I have stopped, then stepped on it to turn around like an idiot I am, and I think I have understeered the left front into the hidden curb at a fairly shallow angle with the wheels turned right, but in any case with enough force to bend the lower control arm something nasty. I was almost out of the u-turn, and since I did not expect the curb, I did not brake. Now the steering is off, car drives like rubbish (small wonder, the tyre is not pointing forward!), and noises coming from the front left of course. Lucky it was very close to home so I have just came home & parked the car now. Here's what it looks like underneath: http://imgur.com/5i14IYm I'm wondering if you guys have an experience with this kind of damage, is it ok to replace the arm & ball joint, and then take it in for an alignment and check-up? Or is it likely that there's more damage and take the car into a service to be sure? I'm tracking the car, and it's not a daily driver, so I'm interested in opinions if I should just replace the suspension parts with performance ones? (eg I can't notice any bend in the coilovers, but I'm looking to buy some MCA ones anyway...but I'm sure I can find performance arms, too?) In any case, just looking for opinions, not legally binding advice ![]() Edit: almost forgot; the ABS light came on, too, and stays.
Toyota 86 GTS A/T, ACE 250/B header + OP, Apexi air filter, Whiteline camber bolts
#2998 |
The Stig's German cousin
Your tie rod maybe looks bent. Could be steering rack damage. Could've bent the sway bar. May have damaged the ABS sensor.
For the last issue you definitely want it looked at by a professional. Otherwise you can start throwing parts at it, but that looks like a hell of a hit... |
| The Following 2 Users Say Thank You to renfield90 For This Useful Post: | strat61caster (09-27-2016), ysu (09-27-2016) |
#2999 |
Drives: Asphalt 2015 FRS
Googled around and didn't find any thing conclusive one way or another:
I am saving up for some RCE T2's plus the camber plates and saw somewhere that it is recommended to buy new endlinks when putting in coilovers. Is this true? Is this something that is purely optional but beneficial? Are the stock endlinks ok with the coils or will they eventually fail from being used with the new coils? This will be my first time doing any suspension mods myself so I just want to make sure I am fully prepared and don't jack anything up too bad in the process. TIA!
Build Thread: http://www.ft86club.com/forums/showthread.php?t=101096
#3000 | |
Drives: GT86
| The Following User Says Thank You to DeaconRoc For This Useful Post: | Brayden_23 (09-27-2016) |
#3001 |
Drives: 2013 BRZ,08 Chevy Cobalt, 90 BMW M3
Sagging K.W. coilover springs
I've had a set of K.W. double adjustable coilovers on my 2013 BRZ for about two years now, and until recently not had any problems. My current problem started about 6 mos ago with the front inner fender liners coming detached during auto crosses. At first, I attributed this to just hitting too many cones! However, I noted that the tops of both wheels were rubbing the inside tops of the inner fender liners. I then decided to measure the height of the car compared to where it was when I installed the K.W.'s. The car has the same wheels , tires, tire pressures and has been measured from the same locations. The measurement was from the lower rim of the wheel to the top of the fender wheel well, and it shows over 1/2 inch drop from the original measurements.
I've discussed this with my favorite local shop that did the K.W. install, and they agree the springs have sagged, and that this has caused the inner fender liners to come detached. However, they claim some spring sagging is not uncommon! I've always heard this was a defect, and not all that common. What's the real story here? Is spring sagging really that common? Does this affect the spring rates, and does this sagging mean the springs or the entire coilovers need to be replaced? Thanks in advance. |
#3002 | |
Aftermarket endlinks are a little thinner on the heads and provide more clearance. For street use, middle of the range is plenty of camber. For autocross/track you will want more than that. Any talk about upgrading for reliability or strength is pure marketing BS. The stock endlinks can take anything you can dish at them. |
| The Following 2 Users Say Thank You to renfield90 For This Useful Post: | Brayden_23 (09-27-2016), Racecomp Engineering (10-03-2016) |
#3003 | |
| The Following User Says Thank You to renfield90 For This Useful Post: | strat61caster (09-27-2016) |
#3004 | |
#3005 |
Is the preload on the stock ARB adjustable? I wasn't looking at upgrading those yet until I know how the car handles with the new suspension first.
#3006 | |
#3007 | |
Drives: '13 FRS - STX
#3008 |
I am anticipating dropping between 1-1.5", dependent on what looks good. Not trying to mess up the geometry too much. I am not a low n slow kind of guy; just someone who enjoys practicality as well as looking good
#3009 | |
Thank you for your help!
#3010 |
Thanks, it's in the shop now so I'll check.
| Air Suspension Discussion Thread - Let's Get Nerdy | Andrew@ORT | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 174 | 02-13-2016 03:17 PM |
| RallySport Directs Everything Suspension thread!! | RallySport Direct | Brakes, Suspension, Chassis | 21 | 07-02-2014 05:31 PM |
| The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension | ModBargains.com | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 63 | 05-22-2013 08:15 AM |
| 2012 Team USA vs the 1992 Dream Team | ERZperformance | Off-Topic Lounge [WARNING: NO POLITICS] | 1 | 09-14-2012 06:19 PM |
| Team build thread; PROJECT.STH | trueno86power | Other Vehicles & General Automotive Discussions | 0 | 03-02-2010 10:13 AM |
