Old 09-26-2016, 11:26 AM   #1
redwing634
Drives: 2013 Scion FR-S (Firestorm)
Buying rims/tires online, should it be done?
I'm still on my stock rims / tires, but having just moved to a state that actually had winter conditions / snow, I imagine I need to swap them out for winter tires/rims?
Should I just buy 4 rims / tires, and swap them before/after winter season? And if so, can both rims and tires be purchased online at a reasonable cost?
Any recommended rims / tires? I've literally never purchased rims or tires before.
redwing634 is offline   Reply With Quote
Old 09-26-2016, 12:12 PM   #2
jvincent
jvincent's Avatar
The answer to your first three questions is yes.
If you don't care about looks get some steel rims with a decent winter tire like a Blizzak or Michelin X-ice.
Tirerack will ship them to your door already mounted.
Old 09-26-2016, 12:48 PM   #3
BWilky
BWilky's Avatar
Drives: 2016 Subaru BRZ WRB
You can look for used 16 or 17 inch wheels and save money. You can also buy used winter tires already mounted if you search your local craigslist as well.
BWilky is offline   Reply With Quote
Old 09-26-2016, 01:11 PM   #4
You didn't say which State but if it is one with a pile of snow or regular freeze thaw days I would stick to a set of plain steel rims. Spoke rims may look nicer but you will soon get sick of kicking frozen slush out of them.
Also if lots of snow stay right away from "performance" winter tires. They do neither thing well enough to use the two words together.
You may even want to invest in some mudflaps. The stock ones work well.
Shark_Bait88 (09-28-2016)
Old 09-26-2016, 07:31 PM   #5
redwing634
A set of steel rims with General Altimax Arctic tires (cheapest, and decent reviews), with the sensors, comes out to $1021 ($1162 after shipping), seems... like a lot.
Old 09-26-2016, 07:32 PM   #6
redwing634
Yeah I'm fine with steel rims and basic winter tires. Just trying to figure out the best way/place to get both. Tirerack looks to be about $1100 for a full set. Seems like a lot but then again I have nothing to compare it to...
Old 09-26-2016, 07:33 PM   #7
jvincent
jvincent's Avatar
You don't need the TPMS. Just ignore the warning light so that will help bring the cost down.
Winter tires that keep you on the road are much cheaper than going off the road and writing off your car. Also, you should get at least three winters out of a set of tires depending on how much you drive.
The Following User Says Thank You to jvincent For This Useful Post:
why? (09-26-2016)
Old 09-26-2016, 07:45 PM   #8
Yep I skipped the sensors. Don't even notice the light after 2 days. Mind you when I put the summers back on and the light goes out I think something is wrong for two days as well.
Old 09-26-2016, 11:13 PM   #9
why?
Only happy when it rains.
why?'s Avatar
Drives: series.blue
You must be going with expensive tires. 4 Generals are 477.80 and 4 steel wheels are 280 for a total of 757.80
The General Altimax are amazing and blizzaks are getting overrated and crazy expensive.
why? is offline   Reply With Quote
Old 09-26-2016, 11:45 PM   #10
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
Buying online is hit or miss. I'll check out local tire shops get quotes. Somethings you get a better deal sometimes not.
Just don't think that all online prices are the best deal. Like others said you may just find a good deal on local Craigslist ads.
Old 09-27-2016, 02:53 PM   #11
JoeShaft
JoeShaft's Avatar
I'm looking into the same thing right now. Where did you get that pricing and was that mounted as well? Do steelies still need a hub centric ring?
2013 Scion FR-S M/T, Five Axis Edition, Whiteout
JoeShaft is offline   Reply With Quote
Old 09-28-2016, 08:44 AM   #12
why?
why?'s Avatar
Drives: series.blue
tirerack.com. Tire rack will give you whatever you need. Not sure if it includes mounting or not.
Old 09-28-2016, 08:54 AM   #13
Summerwolf
Panda Trueno
Summerwolf's Avatar
Drives: No twin now.
You can get some stock steelies off a forester for cheap and then get some nice snow tires. Easy. You should do it if this is your only vehicle.
Old 09-28-2016, 10:24 AM   #14
Shark_Bait88
Shark_Bait88's Avatar
Drives: 2013 Firestorm FR-S
Kicking the snow out of the wheels isn't too bad if you get a simple set, plus a stock set of alloy wheels will be hubcentric unlike steelies (that being said, I actually like the look of steelies. lol)
I originally ran the stock wheels with Blizzaks WS80s, but clearing snow out of those was a huge PITA. This past winter I bought a used set of WRX 16" alloys off a buddy for $200 (this sort of deal can be found all over craigslist). I would suggest going that route, and then order tires off of TireRack. I'm a huge fan of the WS80s, but the Altimax are a good option too if you're trying to save a little.
Here's what it can look like with some WRX wheels and a little paint.
I'd definitely recommend going with a 16" wheel either way, because not only will tires be cheaper but you can run a narrower 205/55/16 (which will drive better through snow).
"Shark_Bait88, the man who’s spent the most money modding his stock FR-S and it’s still stock." -@jdnguyen
Shark_Bait88 is offline   Reply With Quote
The Following User Says Thank You to Shark_Bait88 For This Useful Post:
Tcoat (09-28-2016)
FS: OEM tires and rims - Stock rims and tires Webster10 Wheels and Tires 14 11-16-2015 05:50 PM
Online buying 2k14frs Scion FR-S / Toyota 86 GT86 General Forum 9 05-19-2014 09:13 PM
245 or 255 bad tires + light rims = 225 mid-gripy tires + normal rims? Figo Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 12-18-2013 02:33 PM
cons of buying online? chickdigger802 BRZ First-Gen (2012+) — General Topics 35 09-03-2013 10:42 PM
buying parts online Silverdub CANADA 29 03-18-2013 09:52 PM
