Old 09-23-2016, 05:40 PM   #589
johnmk
Fidei Defensor
Drives: 2015 Subaru BRZ Limited - Black
I finally figured out why my car's dyno in the mid-range is so pathetic, my ptuning headers are leaking.
In case it's not clearly defined, all 4 runner bridges where the collector meets the runners are leaking, as with the V-Band flange itself. This was discovered largely due to your complaint about the exhaust smell and we didn't find any residual exhaust leaks. Also, after 4 hours of trying on the dyno yesterday, I had yet to smell that and figured that the dyno fans was clearing out the odors. When we smoke tested the setup with a 3 PSI machine, all this was what we found.
I've got pictures showing smoke coming out of several different places in the headers. This can't be normal, right? What's my next step?
-Chad
johnmk is offline   Reply With Quote
Old 09-26-2016, 01:54 PM   #590
Freddy@PTUNING
Freddy@PTUNING's Avatar
Drives: Honda S2000 & Acura RSX Type-S
Send a message via AIM to Freddy@PTUNING
-Chad
PM'd
Freddy@PTUNING is offline   Reply With Quote
Old 09-30-2016, 06:41 PM   #591
s30series
Drives: 2015 BRZ Series.Blue
It's been a while, but heres an updated exhaust note video
Got a new track day mic setup...so thought I'd make a video.
Ptuning header coated and wrapped, Motiv overpipe coated and wrapped, HKS dual resonated front pipe, Perrin 2.5" resonated cat-back system.
Nothing is really over 6k RPM or WOT in this video...just everyday driving to show what it sounds like for those wondering.
stereo mic is located right next to the license plate, so there is a slight rattle every once in a while.
[ame="https://www.youtube.com/watch?v=OGsj5QVBdLQ"]2015 Subaru BRZ Exhaust with Perrin/Ptuning System - YouTube[/ame]
s30series is offline   Reply With Quote
The Following 2 Users Say Thank You to s30series For This Useful Post:
Mrc@ptuning (10-03-2016), sato (05-07-2017)
Old 05-04-2017, 03:32 PM   #592
PandaSPUR
PandaPandaPandaPandaPanda
PandaSPUR's Avatar
Drives: 2015 BRZ Limited CWP
The groupbuy thread being bumped caught my eye.. beautiful header. Anyone running this with a JRSC kit?
Old 07-26-2018, 06:02 PM   #593
Jrdad
Jrdad's Avatar
Drives: 2013 Scion FR-S 6M Argento
Recorded a video of what my exhaust sounds like with this header for anyone wondering
Jrdad is offline   Reply With Quote
The Following User Says Thank You to Jrdad For This Useful Post:
Mrc@ptuning (07-27-2018)
Old 10-07-2018, 11:45 PM   #594
dutchman1
Drives: 2017 86 6-Speed
Just installed a Ptuning header I picked up used locally, and I'm getting a bit of an airy/fluttery/ticky type noise around 3k rpm on acceleration. Can't replicate it without load. It sounds like it's coming form the front of the car (though I know that can be tricky to judge).
The header was installed with new oem gaskets all around on cleaned mating surfaces, and everything was torqued to spec. The rest of the exhaust is stock.
Don't see an obvious leak (no soot). Is this normal for this header? Am I just hearing exhaust valves tick or something, or is it leaking somewhere?
2017 86 set up for CS STX autocross
dutchman1 is offline   Reply With Quote
Old 10-08-2018, 12:11 AM   #595
86TOYO2k17
Drives: 2017 toyota 86
May or may not be related. Not sure if PTuning had this issue. But my ace header between 2500-3000 made a weird noise. Turned out to be the underbody panel rubbing and the frequency at that rpm resonating through. Visually it looked like it had space but these motors move a lot under load. Could see rub marks on the header exactly where it was rubbing. Rubber mallet fixed that issue.
The Following 2 Users Say Thank You to 86TOYO2k17 For This Useful Post:
dutchman1 (10-09-2018), mrjj (03-14-2020)
Old 10-09-2018, 12:22 AM   #596
dutchman1
Bingo, thanks!
Old 10-31-2018, 08:33 AM   #597
J1Avs
Drives: 2018 BRZ tS
Would also like to know if anyone is running with JRSC!
J1Avs is offline   Reply With Quote
Old 01-31-2019, 12:11 PM   #598
Grips&slips
Drives: 99 mazda miata sport
Man these guys are right down the road from me. I actually worked on an Evo they did and that thing was a beast. Looks like I'm saving up for this header and having them do the custom ecutek tune. I'm thinking if I do any exhaust at all other that that I'll do the hemholtz thermal r&d to keep sound down.
Grips&slips is offline   Reply With Quote
Old 01-31-2019, 02:41 PM   #599
ldooks
Drives: 2017 GT86, 2014 Honda CBR650F
Are you guys making these anymore? I've been looking to buy one forever but every time i email they say they're out of stock.
Is anyone looking to sell theirs? (will pay shipping)
ldooks is offline   Reply With Quote
Old 01-31-2019, 03:01 PM   #600
J1Avs
Drives: 2018 BRZ tS
From what I hear, they may be building another batch in the future, if there is enough interest to make it cost effective. So I'd say the more support and commitments shown, the more likely it could happen!
Old 05-27-2019, 11:17 AM   #601
tom@ptuning
tom@ptuning's Avatar
Drives: 2013 Scion FRS
We will actually be installing a PTUNING header on a customers car with a JRSC kit this week and doing a re-tune. Stay tuned for updates.
tom@ptuning is offline   Reply With Quote
The Following 2 Users Say Thank You to tom@ptuning For This Useful Post:
CkOne (06-23-2019), why? (05-30-2019)
Old 05-27-2019, 04:26 PM   #602
J1Avs
Drives: 2018 BRZ tS
200hp na, 4-1 full, merge collector, ptuning, race header
WTB: Equal-length (EL) catted header ck-GT86 Engine, Exhaust, Bolt-Ons 1 04-10-2014 07:31 PM
PRE Stepped diameter 4 to 1 double slip collector Header Jmonty Engine, Exhaust, Transmission 9 02-28-2014 09:24 AM
BRZ/FR-S/GT86 – 4-1 Equal Length Header Group Buy P&L Motorsports Groupbuys 634 12-03-2013 05:36 PM
*PHASTEK* DC Sports Equal Length Header PhastekSport Engine, Exhaust, Bolt-Ons 3 11-14-2013 10:17 PM
