#1 | |
Proud of BOXER
Drives: Subaru Boxer
Mann Engineering Coilovers - Inverted
The only threads on these are multiple years old, so I figured I'd start a new one.
Seriously considering these and wondering if anyone else wanted to chime in with thoughts, driving impressions, photos, or anything else regarding these: https://www.mann-engineering.com/ind...t86-25585.html ![]() One‐way adjustable inverted struts (Fronts Only) 12‐point adjustments for rebound and bound Aluminum rear shock casings to help Reduce weight Carefully selected springs rates by AST Springs Included front endlinks Factory coated shock casings to prevent rust and corrosion Aluminum shock collars for height adjustment Designed to utilize OE top hats Fully rebuildable Optional Swift Springs
#2 |
Pissin off regressives
Drives: They have engines.
I have the 5100, which seems to be what these are based off. Don't want to hijack your thread so let me know if you want me to give you my impressions on those.
#3 |
Drives: FR-S Whiteout
Not 100% but I believe these are the AST 4150's. http://www.ft86club.com/forums/showthread.php?p=1782684
Intent > Content
cowardice is the mother of cruelty. |
#4 | |
#5 |
Ahh right more like AST 5100's strut but 4150 shock bodies in the rear? https://www.vividracing.com/catalog/...150919207.html
Intent > Content
#6 |
Drives: SWP BRZ
I own these Mann coilovers. I can confirm that they are based on the AST 5100. I'll have more detailed impressions after I get off work!
#7 | |
Proud of BOXER
Yes please!
#8 |
Drives: SWP BRZ
OK so I'm just going to share some quick thoughts about these coilovers.
First, my goals for the car. My BRZ is my only car so it has to be compliant on the street. I decided on single adjustables just to keep things simple as I'm no suspension guru. I also wanted to get a set of quality coilovers that will last the lifetime of the car. After considerable debate, I narrowed my choices to Ohlins Road & Track or the Mann Engineering inverted. I chose Mann because they're a local shop and I can get any problems taken care of easily. I was also glad Mann didn't try to upsell me on unnecessary things like upgraded springs, top hats or other suspension bits. I told them my goals and they provided great advice. Build quality is excellent. They're understated with an all black design, save the blue adjustment knobs. I also like that the rear adjustment knobs sit flush with the carpet, without intruding into the trunk area. The only problem I had with them was a strange clunking that happened after a long road trip. I pulled the suspension apart to tighten every nut and bolt and the problem went away, though it pops up from time to time. I can't track down exactly what's causing since the clunking rarely manifests. So how do they ride? On the street, they're excellent. With the fronts set at 4/12 and the rears 3/12, it's a perfect mix of performance and compliance. I wouldn't go any softer except for on long road trips. I love that these only have 12 clicks of adjustment, so each click is noticeably different. On backroads, these are excellent. The car has zero body roll, even with "soft" 5kg/5kg springs front and rear. The backroads in the Bay Area are really bumpy, and these soak up the bumps without problem. I'll hit the bump stops every now and then on really big bumps (only in the rear), but they seem to have about the same amount of travel as stock. The Mann inverted coils/AST 5100 really inspire confidence and the car never feels nervous. I'm running conservative tires (225/45/17 square) so your set up may differ. I haven't been on the track with them yet but I should handle light track duty no problem. The only thing I would change with them is including a dust cover for the struts. It's strange seeing just how much dirt builds up around the shafts but I haven't had any problems with them. If you live in an area with salted roads, it's probably best to request Mann/AST to put a set of dust boots on them.
#9 | |
Proud of BOXER
I wonder if something like this would work to combat the dust/debris?
#10 |
Drives: SWP BRZ
Probably would help! I'm sure I'm just being paranoid as the exposed shafts haven't given me any problems after nearly 15k miles.
#11 | |
Proud of BOXER
Thanks for taking the time to share all of your thoughts on this thread!
These parts stood out at me the most. The fact that there's no unsettled feeling over those mid corner bumps is huge. I hate that feeling of the car getting jarred/loose over those dips/bumps. "On backroads, these are excellent. The car has zero body roll, even with "soft" 5kg/5kg springs front and rear. The backroads in the Bay Area are really bumpy, and these soak up the bumps without problem. I'll hit the bump stops every now and then on really big bumps (only in the rear), but they seem to have about the same amount of travel as stock. The Mann inverted coils/AST 5100 really inspire confidence and the car never feels nervous. I'm running conservative tires (225/45/17 square) so your set up may differ. I haven't been on the track with them yet but I should handle light track duty no problem."
#12 | |
Drives: 2014 BRZ sterling silver
#13 | |
Drives: SWP BRZ
20mm. I was 1 inch lowered but wanted a little more stroke.
#14 | |
Proud of BOXER
Nice - I'm at a 20mm drop now on my RCE Yellows, and this is what I would like to stay with when I move to coils.
These Mann Engineering coils are looking like the perfect option for me.
| Review: Mann Engineering BRZ lowering springs (25mm) | PandaBRZ | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 4 | 05-28-2015 08:52 PM |
| 86DRIVE & Mann Engineering's Dyno Day/Car Meet - Santa Clara, May 17 | PMok | Northern California | 59 | 05-25-2014 01:13 AM |
| Mann Engineering Coilovers | BigFatFlip | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 17 | 04-21-2014 08:48 AM |
| Mann Engineering Coilovers review | l8apexr | CANADA | 10 | 03-11-2014 12:11 PM |
| Delicious Tuning - Dyno Tuning Weekend at Mann Engineering's (San Jose, CA) | DeliciousTuning | Announcements, Contests, Giveaways | 6 | 09-19-2013 05:55 PM |
