| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
Drives: Black Limited JDM BRZ
Anyone running 18" wheels with RS-R super down springs?
Sorry can't really find anything concrete on the subject.
I'm about to go RS-R super down springs (so it's 1.0-1.2" drop) with my Work Kiwami 18x9.5 +38 (235x40 tires) and was wondering if anyone has the same or similar setup? Is there any rubbing issues in the front? I'm getting SPC front camber bolts and SPC rear arms as well, so will be able to do minor camber adjustments. ![]() ![]() P.S. I nave 0 issues on OEM suspension.
#2 |
Country Boy 4 Life
#3 |
Drives: Scion FR-S
I had 18x9.5 +40 offset squared on all sides... The front rubbed, but I used a 5mm spacer in the front so turning the wheels would clear. I also used 3mm in the rear(not needed, but looked better in the back since the looked flushed... hope that helped.
#4 |
Ok, here's update on the subject: RS-R super low springs + SPC 14mm camber bolts (SPC on the bottom, bottom crush bolts on the top). The car is noticeably lower, but no rubbing so far.
![]() ![]() Managed to get -2.0 camber on the front. Rear springs are still settling down, so rear camber is a bit messy - I don't worry to much about this as I will be installing LCA soon.
| The Following User Says Thank You to In1t For This Useful Post: | turbos86 (10-15-2016) |
| "LED Strip Daytime Running Lights and Valenti Tails --- Shipped Anywhere!!" | F-T | Exterior Parts - Lighting | 169 | 08-20-2016 01:15 PM |
| TRD Lowering Springs and 16" wheels anyone have? | stevesnj | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 3 | 08-07-2016 08:22 PM |
| RomRaider: Running super rich at high load/low RPM | PantsDants | Software Tuning | 14 | 09-15-2015 04:23 AM |
| F/S: 18"x8" Avarus AV-8 Matte Black wheels w/Michelin Pilot Super Sports | Opie | Wheels and Tires | 5 | 04-09-2014 08:35 AM |
| Anyone else try running "square" tires on "staggered" wheels? | hamlet | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 21 | 12-19-2012 12:59 PM |
