Old 06-23-2012, 12:26 AM   #43
spiller
Drives: JZA70 Supra, Lancer Evo 5, 86 GTS
^^ there are actually harness holes in the back seats for mounting in this configuration...
spiller is offline   Reply With Quote
Old 06-23-2012, 02:06 PM   #44
Dimman
Kuruma Otaku
Dimman's Avatar
What spring rates are you using?
Because titanium.
Old 06-23-2012, 04:06 PM   #45
Ben_G
Drives: Blue BRZ
I'm also interested in this. Although you guys are pushing the car to limits that most of us will never reach, I'm sure that the rigours of daily driving can be just as detrimental of the long term and could make upgrades on older cars difficult if the hardpoints are in bad shape....
Originally Posted by brillo View Post
What about other suspension components or their connection points to the frame? Are you seeing stress or wear that could cause failure or replacement? Replacing a control arm is relatively easy, but what about the hardpoints where the arm meets the frame? Would stiffer bushings only make the problem worse?
Ben_G is offline   Reply With Quote
Old 06-24-2012, 01:57 AM   #46
Grip Ronin
The Mechanic
Grip Ronin's Avatar
Drives: Civic Turbo,FR-S
so from the factory the stock bushings are really bad? hmm do you have a link to the bushings you used front and rear?
IG-Joey_Soul
Progress Thread Ported billet 20G
Grip Ronin is offline   Reply With Quote
Old 06-24-2012, 07:01 AM   #47
Nardi330
Nardi330's Avatar
Drives: 86
Can you show us the locations?
Thx
Nardi330 is offline   Reply With Quote
Old 06-24-2012, 07:31 AM   #48
spiller
Sorry mate didn't take any pics but they are in the lower section of the back seats.
Old 06-24-2012, 08:05 AM   #49
aaronosaurus
The data matters
Drives: WRBP BRZ
The factory control arms are also designed as a failure point. If you hit a curb on the street and destroy the control arm it's easy to replace. If you damage the pick-up points and the frame you are going to need a very skilled welder to put the car back together. The chances of getting everything bent back exactly as before are slim, and a slight difference in those mounts will make a big change in the caster on that side.
How is the car on tires? Did the stock setup heat or wear them unevenly?
aaronosaurus is offline   Reply With Quote
Old 06-24-2012, 01:01 PM   #50
brillo
Drives: 2013 Firestorm FR-S
I hope your right on this, much rather have the arms fail than the pick up points arms are easy to replace
brillo is offline   Reply With Quote
Old 06-24-2012, 03:48 PM   #51
KeepGuessing
Drives: e30 150 deville etc etc
Great writeup..
Funny because back in the MotoIQ article 6+ months ago, when they showed pics of the LCA's and said "this is the lightweight suspensions" yadda yadda..
FIRST thought in my mind was "they left too little material in the R&D and with a updated set of slop-free bushings you'll be cracking hardware left and right because it just wasn't designed to deal with any sort of hard impact.
KeepGuessing is offline   Reply With Quote
Old 06-25-2012, 10:39 AM   #52
no_name
no_name's Avatar
Drives: 2005 Hyundai Accent
Seriously cool. I'm going to be following this closely.
GT86: "This car has two steering wheels: one is circular, the other is operated with the right foot."
no_name is offline   Reply With Quote
Old 06-25-2012, 12:52 PM   #53
AVOturboworld
Current spring rates on the coilovers is:
Front: 8kg
Rear: 10kg
This is with the RE11's.
We are thinking of moving to Hankook tires. They will be grippier than the RE11's, so we are thinking of upping the fronts to 9kg, as they are already feeling a touch soft.
The Following 2 Users Say Thank You to AVOturboworld For This Useful Post:
Dimman (06-25-2012), SVTSHC (06-26-2012)
Old 06-26-2012, 12:58 AM   #54
spiller
what was the reason for running the heavier springs in the rear? seems interesting given that the weight dist. is almost 50/50 and if anything slightly front heavy.
Old 06-26-2012, 01:16 AM   #55
Surok
Wise old man
Surok's Avatar
Drives: 86 GTS
Subscribed for updates!
Surok is offline   Reply With Quote
Old 06-26-2012, 01:19 AM   #56
Dimman
Kuruma Otaku
Dimman's Avatar
Motion ratio is different front and rear.
Because titanium.
Element Tuning Track Tested and Track Proven FRS Video Element Tuning Tracking / Autocross / HPDE / Drifting 47 07-17-2012 04:12 PM
$110 Track day at Willow Springs- Big Track -May5 in SoCal Louie Southern California 3 05-04-2012 01:05 AM
$110 Track day at Willow Springs- Big Track -March24 in SoCal Louie Southern California 1 03-10-2012 01:31 AM
$85 Track day at Willow Springs- Big Track -Feb 18 in SoCal Louie Southern California 0 02-12-2012 03:09 PM
$109 Track Day@WillowSprings-Big Track-August 13-14 in Socal Louie Southern California 1 07-26-2011 04:34 AM
