Old 07-15-2015, 08:00 PM   #15
kberkel
kberkel's Avatar
The window switch? Are your guys' switches loose? I've never heard of this, mine are super tight.
kberkel is offline   Reply With Quote
Old 07-15-2015, 09:01 PM   #16
navanodd
Drives: 2013 BRZ Sport-tech WRB
I've got some notes in this post regarding how to fix the switches. Requires popping the door card off.
http://www.ft86club.com/forums/showp...5&postcount=23
navanodd is offline   Reply With Quote
Old 09-16-2016, 05:59 AM   #17
thatfilipinoguy
thatfilipinoguy's Avatar
Drives: 87 Supra, 13 FRS, 05 FXT
Bringing this thread back from the dead to let you guys know...in case some of you still care...that I fixed the problem.
I removed the switch modules from the door cards and wrapped the switch and its mount several times in electrical tape, and then proceeded to add thin foam weather stripping in between the plastic parts where it sits in the door card, and even went ahead and removed the speaker/knee pad and pit foam in between it and the door card as well. The vibes in the door are gone now! I will get to posting pictures...when I feel like fixing the handle/lock later.
thatfilipinoguy is offline   Reply With Quote
The Following User Says Thank You to thatfilipinoguy For This Useful Post:
Tcoat (09-19-2016)
Old 09-16-2016, 09:07 AM   #18
Gello
Gello's Avatar
@thatfilipinoguy thanks for tip, I've had my BRZ for 2 months and the rattle is starting drive me crazy.
Sent from my SAMSUNG-SM-G900A using Tapatalk
Gello is offline   Reply With Quote
The Following User Says Thank You to Gello For This Useful Post:
thatfilipinoguy (09-16-2016)
Old 09-16-2016, 02:14 PM   #19
thatfilipinoguy
These are all the locations where I taped, and applied the foam strips.
The foam was purchased at home depot for $2.XX
electrongeek (09-25-2016)
Old 09-16-2016, 02:27 PM   #20
iamjacob
insert witty quip here
Drives: 2016 Limited BRZ
I've had m BRZ for a little over 8 months now and I have no idea how anyone could hear a rattle in this car. The insulation from road noise is so non-existent that at anything over 10mph how can you hear anything?
Is the rattle really that loud?
iamjacob is offline   Reply With Quote
Old 09-16-2016, 04:22 PM   #21
thatfilipinoguy
It's not really a rattle, more like when you're listening to music and you hear the speakers and windows vibrating.
Old 09-19-2016, 12:39 PM   #22
Poodles
Drives: 2015 Series.Blue
It's more of a buzzing noise from the window switch that's caused by the speaker. My dealer did some kind of insulation that fixed the issue.
Driver Side Window Rattle RiceCooker Issues | Warranty | Recalls / TSB 23 08-18-2015 11:20 AM
Driver side Window button Quvit92 Scion FR-S / Toyota 86 GT86 General Forum 16 01-09-2015 07:55 PM
Help with rattle on Window Pillar? ray7792 Issues | Warranty | Recalls / TSB 3 11-15-2014 10:04 PM
Window scroll button flashing mashal Scion FR-S / Toyota 86 GT86 General Forum 16 02-07-2013 11:26 PM
Window Button light is not on zc06_kisstherain Cosmetic Modification (Interior/Exterior/Lighting) 7 01-25-2013 03:50 AM
