Old 09-12-2016, 09:22 PM   #393
lostpanda
Drives: FT86
Originally Posted by makinen View Post
Why not?
V3+100mm pulley+RON 98 with no issue.
Even V2 w/o restrictor can live with RON 98.
It's just matter of calibration.
For me I already order the 100mm kits from hks.
I heared some guys tune this kit use 90mm pulley.
I just want to cancel my order for 100mm and make a order for 90mm.
The injector kit of 700cc I will buy it in China.
I do not know waht is the best way for my car is better. 100 or 90?
What I need to prepare ?
lostpanda is offline   Reply With Quote
Old 09-13-2016, 12:40 AM   #394
Yobiwan
Yobiwan's Avatar
Drives: Toyota 86 Turbo, Lexus NX300H
all depends on your tuner.
there are some limitation on stock system like port injector, MAF limit (it's about 300g/s).
2012 Toyota 86 6MT / 11:1 CR block by Outfront / SBD500x Turbo 17PSI@93gas /Avo 2.5 overpipe+Avo 2.5 catted frontpipe /MAP 3" CBE/ Tein Mono sport / STI brembo Front /OS技研 LSD/SSR GTX01 18x9.5
Yobiwan is offline   Reply With Quote
Old 09-13-2016, 11:53 AM   #395
Andew727
Drives: Scion FR-S
It is very luckly to meet some Chinese here.
For the V3 kit the stock pulley is 110mm, also HKS provide a 100mm kit for us.
I heared from Guangzhou there is a guy tune the 90mm pulley for 7040L in Hks v1 to use 95 petrol.
For my v3 kits I think at least 100mm pulley is good for Chinese 98 petrol.
I already have big radiator,oil cooler,also I want to buy a AEM water injetor system. Could you help me to find a way how to reduce my intakes temps?
Thanks a lot!
If the Chinese guys interesting in my v3 kit install, you can add my wechat 13910761886, I can send the Map for the 90 mm pulley tuning.
water meth injection will make any fuel work for high boost applications. if you cant use good fuel then this is your solution
more efficient/larger intercoolers will solve intake temp problems if they are too high
Andew727 is offline   Reply With Quote
Old 09-13-2016, 03:52 PM   #396
Andew727
Drives: Scion FR-S
what tuning software will you be using?
Old 09-13-2016, 08:40 PM   #397
lostpanda
Drives: FT86
ECUTEK.
For the water injecter I will buy it at once.anything else ?
Thanks!
Old 09-14-2016, 08:17 AM   #398
Andew727
Drives: Scion FR-S
ECUTEK.
Thanks!
hks gt supercharger high boost recommendations:
-Oil cooler
-E85, C85, water/meth
-fuel injectors (i dont recommend DW injectors)
-Fuel pump
-forced induction oil catch can/separator
-hose clamp under your intake manifold (pressure solenoid)
-boost leak check the car
these steps and supporting mods will make life a little easier on your engine but anything can happen with time a bad tune or driving habits. So budget for an engine rebuild like i have done.
Old 09-14-2016, 10:17 AM   #399
makinen
makinen's Avatar
Drives: Toyota 86
V3 installed.
I think that the manual needs to be improved for correct working order, especially for traction oil hoses and 7040L body installation.
It works very well with OS-giken LSD. Quite fun to drive.
ECU calibrated using OFT.
makinen is offline   Reply With Quote
The Following 5 Users Say Thank You to makinen For This Useful Post:
Andew727 (09-15-2016), Koj (09-28-2016), Tomita San (09-21-2016), Yobiwan (09-15-2016), zeal86 (09-14-2016)
Old 09-18-2016, 02:35 AM   #400
lostpanda
Drives: FT86
-Oil cooler
-Fuel pump
I already have the oli cooler.
In China we have no E85, our best gas is almost number 92 in USA.
So how many CC I need for my injectors is the most important.
Alao do I need upgrade my fuel pump for 92 petorl ?
Old 09-18-2016, 09:38 PM   #401
makinen
makinen's Avatar
Drives: Toyota 86
As I know, you don't need the fuel system upgrade until it pasts 300 WHP. There is an exception if you use HKS Flash Editor.
Old 09-19-2016, 01:32 AM   #402
lostpanda
Drives: FT86
Yes I heared from so many tuner in China.
They are all told me that I do not need do the upgrade my fuel system incloud my injector.
So my goal is the 300HP on my crank.
I think is easy to meet.
I just worry about the cooler from HKS kits inter cooler.
Does HKS supply a bigger inter cooler?
Old 09-19-2016, 08:10 AM   #403
Andew727
Drives: Scion FR-S
you may not actually need new port injectors if you will be running pump gas, but it still is a good idea to change them out. the water/meth injection will compensate for bad fuel.
i recommend "Injector dynamics (ID)" or "Fuel Injector Clinic (FIC)" 660cc injectors. i had mine tested on a flow bench and read 100+ better than stated.
the DW65c fuel pump isnt bad and is what i run... i just hear bad story after bad story on any "Deatschwerks DW" injectors. so stay away from them.
you shouldnt need a better intercooler. if you are running a v2 or v3 intercooler they should support the smaller pulley, especially if you are running water/meth injection. that will cool down intake temps
The Following User Says Thank You to Andew727 For This Useful Post:
lostpanda (09-21-2016)
Old 09-21-2016, 04:02 AM   #404
lostpanda
Drives: FT86
Thanks for your recommend for the injectors.
For me I think if I change the pulley to 90mm(same to v2), the rotate speed will higher than v2 because the pipe inner dameter is bigger now.
So I am afraid the cooler system is not enough for this power.
If the fuel system can meet this power (crank 300hp), I will ask my tuner try to tune my car before the injecter replace.
After tuning the car I will provide the map.
Old 09-21-2016, 08:35 AM   #405
Andew727
Drives: Scion FR-S
If the fuel system can meet this power (crank 300hp), I will ask my tuner try to tune my car before the injector replace.
the rotation speed will be the same on a v2 and v3 if they are both using the 90mm pulley. you are going to make more power than a V2 kit because you have larger intercooler piping diameter which will move more air and you have a larger intercooler. the last thing to do is upgrade your fuel.
you will be fine, you are doing it the way i would. just use quality parts and take your time on the install and tuning
Old 09-21-2016, 04:58 PM   #406
Tomita San
Tomita San's Avatar
Drives: Scion FR-S
V3 installed.
Considering the V3 too. Where did you get the maps for OFT?
Tomita San is offline   Reply With Quote
Kraftwerks Supercharger Owners Thread projek_01 Forced Induction 4310 04-07-2025 01:12 PM
P&L Turbo kit Owners thread Hawaiian Forced Induction 73 07-07-2018 02:31 AM
Five Axis Edition FR-S Owners Thread digital_assassin FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 563 07-08-2015 09:22 PM
**Offical 213/323/626/818 owners thread** mr. slim Southern California 71 10-07-2013 12:58 PM
Supra Owners Build Thread BoostJunkie Other Vehicles & General Automotive Discussions 164 03-12-2012 09:37 AM
