Old 09-12-2016, 08:28 PM   #1
djrbash
Drives: BRZ Premium GBS
Excess Pulley Movement
Has anyone on here experienced pulley movement like in the video below. I had my car serviced for an oil leak by the timing chain cover. After the fix, I felt my car was significantly louder during idle. Seems like something is not tidied up here. Just need to compare to some other FRS/BRZ. Is the pulley shaking excessively compared to yours? Your input is much appreciated.
Tiny Pic Video Link
djrbash is offline   Reply With Quote
Old 09-12-2016, 08:31 PM   #2
new2subaru
Weight Weenie
Drives: 15 FR-S
That's normal bud. The idler pulley. You're not the first to question it.
Old 09-12-2016, 09:20 PM   #3
[pedantic statement]Actually the belt tensioner pulley. Idler pulleys are fixed in place.[/pedantic statement]
Old 09-13-2016, 12:12 AM   #4
djrbash
Thanks guys. I wondered if everyones shakes like this. My coworker who has an frs had some movement but not as much as mine. I wonder if this has anything to do with my idle dropping off and if timing can be modified to reduce shakiness.
Old 09-13-2016, 12:46 AM   #5
You may wish to carefully inspect your car's serpentine belt for signs of wear.
Old 09-13-2016, 06:40 AM   #6
new2subaru
Weight Weenie
Drives: 15 FR-S
Oops! Thanks, Ultra!
Hangs head in shame...
Old 09-13-2016, 10:34 AM   #7
lol
Old 09-13-2016, 12:57 PM   #8
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
That's likely due to having the air conditioning/defrost on, it cycles on and off putting a load on the engine causing the idle to not be consistent.
If it happens with the AC/defrost off then there is a service bulletin to update the tune provided your car is a 2013/2012 build.
ineedyourdiddly
Cold Start Excess Revving Incident Manic Engine, Exhaust, Transmission 20 12-15-2015 08:04 AM
Options for excess mileage on lease MrAnthonyC Scion FR-S / Toyota 86 GT86 General Forum 24 05-29-2015 03:49 PM
Transmission movement brn12345 Engine, Exhaust, Transmission 2 10-09-2013 04:47 PM
