Old 09-06-2016, 09:31 PM   #7519
Dream20b
Y u do dis?
Originally Posted by sam69 View Post
How did it go Dream20b or
One part didn't show up- the perrin 3". waiting till tomorrow.
Dat Hot Lava Doe
Clearly you have no clue what you are talking about. Everything you said was completely and utterly the ramblings of a babbling idiot regurgitating garbage from his mouth. Everyone here is now dumber from reading your post. Please die now.
Dream20b is offline   Reply With Quote
Old 09-07-2016, 06:23 PM   #7520
Dream20b
Y u do dis?
And Perrin didn't send the part. Overnight delivery means it will be here tomorrow
Dat Hot Lava Doe
Old 09-08-2016, 08:48 AM   #7521
Dream20b
Y u do dis?
should have some numbers tonight.
Dat Hot Lava Doe
Old 09-08-2016, 05:59 PM   #7522
ajcarson11
Drives: 2013 Subaru BRZ Limited (Black)
Evening all,
Getting ready to install my 210 non-intercooled kit. Noticed I'm missing a hose (only have 4 hoses, but I'm MT so it looks like the kit only came with 5 originally?) -- It looks like I need to locate/replace Evap. Solenoid Relocation Hose Assembly 520mm. Are there any attachments on the end of this hose? or could I stop by a hardware store and have a hose cut to size and band/hose clamp it on?
Any idea of size of hose as far as ID, OD is concerned?
Thanks!
ajcarson11 is offline   Reply With Quote
Old 09-08-2016, 07:27 PM   #7523
Dream20b
Y u do dis?
on the dyno now.
Dat Hot Lava Doe
Old 09-09-2016, 12:14 AM   #7524
newcscsl
Drives: 2013-FRS
Does anyone have positive/negative experiences with using Delicous Tuning's tune? Preferably running 92/91 octane, Innovate/Sprintex 210 non-IC and .. don't care about exhaust setup. I'm considering purchasing a tune from them and would like to hear stories. Thanks!
newcscsl is offline   Reply With Quote
Old 09-09-2016, 01:48 AM   #7525
riboyster
riboyster's Avatar
Drives: 2013 Scion FRS
Running the stage 1 tune with no IC on 92 octane. So far an excellent tune, I'd definitely recommend them. Zach is always quick to answer any questions, and the tune works fine with a 72.5mm pulley and 2" perrin intake. Always at IAM 1, no knock and no bogging problems. Does surge a bit around 3100rpm at low load, but from what I understand that's more of a characteristic of the blower than the tune.
I'd definitely recommend perrin's intake. Much better performance, and much less effected by heatsoak than stock box.
ScreamingElectron - SnakeShit
riboyster is offline   Reply With Quote
Old 09-09-2016, 02:14 AM   #7526
riboyster
riboyster's Avatar
Originally Posted by ajcarson11 View Post
Evening all,
Thanks!
Could you post a few pics so we can see what you're talking about please?
Thanks!
Old 09-09-2016, 03:20 PM   #7527
jwvand02
Drives: 2013 SWP BRZ Limited
I don't think I've ever seen a negative thing posted about them, they clearly do good work and know their stuff. Also great contributors to the forum and are really on the leading edge of this platform.
That said, I ended up going with Moto-East because the cost for a multi-fuel map was much lower and their customer service has been fantastic as I tried to chase down some issues - so much so that they're the one vendor that's earned a sticker on my car.
You really can't go wrong either way.
jwvand02 is offline   Reply With Quote
Old 09-09-2016, 08:01 PM   #7528
nmastereal
Evening all,
Thanks!
Hose is the same size as the others provided, just get some more of that from your kit. One tube runs from the evap solenoid to the engine and other from evap solenoid to the back of the supercharger.
nmastereal is offline   Reply With Quote
Old 09-09-2016, 08:24 PM   #7529
Dream20b
Y u do dis?
Okay, So I hit 300/300 on my tune at the wheels on a "Heartbreaker Dyno."
Supposedly I could have had 350-370 on the same dyno on stock compression, but that would be maxing out the engine and then some imo.
Dat Hot Lava Doe
Old 09-09-2016, 11:53 PM   #7530
riboyster
riboyster's Avatar
Slow and safe
Old 09-10-2016, 02:23 AM   #7531
ajcarson11
Thanks!
I've read through a lot of posts thus far and am still trying to determine: Should I be using the MAP sensor that comes with the kit for non-intercooled, or should I be using the OEM map sensor?
Thanks!
Old 09-10-2016, 10:06 AM   #7532
sam69
Drives: GT 86
Soooo do you think I would be better off going for near stock compression and not 10:1 pistons ??
sam69 is offline   Reply With Quote
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
