Old 09-08-2016, 05:39 PM   #211
sevenmarc
Drives: 2013 Scion FRS Edition 10
Hey guys, quick question. I had my car up on stands today, but couldn't get the fill plugs off of either the trans or the diff; I'm need some PB blaster, I think. I also couldn't get my 10mm hex in the fill plug for the trans while attached to my ratchet thanks to the 1/2in to 3/8in adapter; I'm going to need to grab a 3/8in ratchet as well.
My question is this: how are you guys using the Motul 300 to fill the trans without a pump in that tiny space? I looked everywhere for pics or videos, but couldn't find any.
sevenmarc is offline   Reply With Quote
The Following User Says Thank You to sevenmarc For This Useful Post:
ThisGuyRett (09-24-2016)
Old 09-08-2016, 05:44 PM   #212
Maverick986
Drives: 2014 Subaru BRZ
I have not changed my transmission oil yet on my BRZ, but when changing on other cars I've had, I've used some vinyl tubing and a funnel. I snake the tubing through the top of the engine down into the transmission, making sure to get enough tubing in so that it doesn't just pop back out (happened once). Then put. The funnel into the tube and pour in the oil.
Sent from my SM-G925V using Tapatalk
Maverick986 is offline   Reply With Quote
Old 09-08-2016, 05:53 PM   #213
gramicci101
Off Topic
Here you go. Make sure you have new crush washers for the diff. Also make sure you have some way to catch the transmission fluid. It comes out sideways.
Originally Posted by gramicci101 View Post
Here you go. For the transmission, the bottle fits nicely up alongside the transmission. Massage the fill tube to get any kinks out and give the bottle small squeezes to assist with the filling process. It shouldn't need to be said, but put the fill tube in the hole before you raise the bottle. Also, put the fill tube in the actual fill hole and not the gap in the fins just in front of the fill hole. It's kind of embarrassing to pour brand new transmission fluid down the side of the transmission and all over your arm before realizing that you're a dumbass.
The diff is more difficult, especially with the newer, more square bottles. You can't really get the bottle up above the fill port until it's mostly empty and you can crush it a little. Get it as high as you can and squeeze it pretty hard to force the fluid up and out. Once that doesn't work anymore, squish the bottle up in front of the axle shaft and keep going. It's ok if you wad the bottle up to get it up there, because you'll be throwing it out anyways. It isn't a 100% solution, but it's good enough. You can always unscrew the tops of the bottles to transfer any remaining fluid into the next bottle.
The Following User Says Thank You to gramicci101 For This Useful Post:
ddevl_86 (04-02-2021)
Old 09-08-2016, 11:03 PM   #214
sevenmarc
Thank you; this is really helpful!
Old 09-09-2016, 09:59 AM   #215
Astroboy
Astroboy's Avatar
Drives: None
A pump is only like 10 dollars at O'Reilly's. But that motul method others are using looks faster on the trans
Sent from my LG-D850 using Tapatalk
Astroboy is offline   Reply With Quote
Old 09-19-2016, 04:51 PM   #216
ap5512
ap5512's Avatar
Drives: 2013 SWP BRZ
So i've changed my transmissions fluid in the past around 15K miles but never touched the Diff. Is there a noticeable difference once you change it?
"Don't be a don'ter, do be a doer" - Johnny Wu
ap5512 is offline   Reply With Quote
Old 09-19-2016, 06:11 PM   #217
B-R-Z
I love peanut butter
B-R-Z's Avatar
Drives: 2013 SWP BRZ Limited
Yea, you see a ton of metal shavings in your old fluid. You do not feel any difference from a driving perspective.
B-R-Z is offline   Reply With Quote
The Following User Says Thank You to B-R-Z For This Useful Post:
ap5512 (09-20-2016)
Old 09-29-2016, 03:09 AM   #218
brz2727
Drives: white brz
so its that time for mr to change out my transmission fluid and diff fluid also any suggestions my car is running on e85 if that matters i don't run my car all that much but i want a quality fluid for both need help!
brz2727 is offline   Reply With Quote
Old 12-22-2016, 06:06 PM   #219
Calvin27
Drives: GTS
Has anyone done the MT fluid change and noticed it got worse? Does it need to 'run in'? I went for motul fluid as per most of the suggestions here and it actually feels more clunky than what I originally had in there. (I presume it was oem because there were a lot of metal shavings). I drove the car for about 5km changing gears slowly and it improved a bit but the feel is still very notchy compared to previous. freaking out I did something wrong - I made sure i filled it the correct amount, no sure what else could have gone wrong.
Calvin27 is offline   Reply With Quote
Old 12-23-2016, 01:07 PM   #220
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
It shouldn't be worse or really take any time to run-in.
What fluid did you use?
Old 12-24-2016, 07:04 PM   #221
Calvin27
Drives: GTS
Motul 300.
Old 12-29-2016, 01:50 PM   #222
fl4t
Drives: '13 WRB BRZ '05 STi OBP
I am feeling the exact same way with Motul 300. It feels the same if not a bit notchier particularly downshifting into 5th at highway speeds.
fl4t is offline   Reply With Quote
Old 12-29-2016, 08:15 PM   #223
Mr Nerd
Mr Nerd's Avatar
Some good info for everyone to take a moment and read.
https://cloud.tapatalk.com/s/5865b51e...nsaxle_oil.pdf
Mr Nerd is offline   Reply With Quote
The Following 2 Users Say Thank You to Mr Nerd For This Useful Post:
catsspat (01-08-2017), KL (01-03-2017)
Old 01-08-2017, 10:38 AM   #224
arxm
Drives: 2013 FR-S, 2023 BRZ
so as per my understanding as I've never done this before on any car is that i need 2.2L of motul 300 75w-90 for the transmission, and can I use the same stuff for the diff?
2013 Whiteout FRS 6MT with a JRSC @ 330ish WHP on E98
2023 Ignition Red BRZ 6MT awaiting boost
arxm is offline   Reply With Quote
differential, diy, fluid, transmission
Transmission fluid swap? flawedchemical Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 48 09-12-2014 02:23 PM
What Differential fluid is in your BRZ/FRS? ft86Fan Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 9 11-12-2012 08:57 PM
Anyone change transmission lube yet? BMWDavid Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 14 08-21-2012 05:47 AM
FR-S quick reference and warranty / maintenance guide is up pkny Scion FR-S / Toyota 86 GT86 General Forum 15 06-20-2012 11:33 PM
topspeed difference between manual transmission and automatic transmission torquemada BRZ First-Gen (2012+) — General Topics 51 05-04-2012 07:54 PM
