Old 09-08-2016, 01:59 PM   #379
Gearbanger
Gearbanger's Avatar
Drives: Lexus is300 celica gts
Thanks so is the bypass valve line a good place to tap?
Gearbanger is offline   Reply With Quote
Old 09-08-2016, 02:04 PM   #380
Torry@HKSUSA
Torry@HKSUSA's Avatar
Drives: HKS
It's all manifold vacuum, so it doesn't really matter. Just remember the closer to the actual manifold it is, the more accurate it is.
Torry@HKSUSA is offline   Reply With Quote
Old 09-08-2016, 02:59 PM   #381
Andew727
Drives: Scion FR-S
The smaller pulley is 100 mm good for 11.5 psi.
they make as low as 80mm
Andew727 is offline   Reply With Quote
Old 09-09-2016, 09:21 AM   #382
Efferalgan
Drives: 2025 BRZ, ex-2012 GT86
Originally Posted by Torry@HKSUSA View Post
From my understanding, you may run into problems with one of the pulleys on an automatic version. I'm not sure what that problem is, but I've been told one of the pulleys is different which can cause an problem during install on an auto. If anyone has more details on that, please let me know so I can make note of it!
Also, just to clarify, the HKS Flash Editor will not work on an AT car. So you if you do install the V3 kit, you will need custom tuning.
There is no difference between AT and MT with regards to pulleys, apart from the fact that it's more difficult to remove the crankshaft pulley on an auto as you can't put it into a gear to lock the crankshaft, so you need to lock manually. But it has nothing to do with the SC installation as removal of the crankshaft pulley is not necessary for that.
The front of the engine and pulleys layout is identical between MT and AT.
Efferalgan is offline   Reply With Quote
Old 09-09-2016, 09:29 AM   #383
Torry@HKSUSA
Drives: HKS
Interesting...in that case, I'd be interested to hear from somebody who has installed a V3 kit on an AT car to know if there were any other issues, other than the tuning, which we know the Flash Editor doesn't work for because AT cars have different ECU ID's.
Old 09-09-2016, 12:07 PM   #384
makinen
makinen's Avatar
Drives: Toyota 86
The pulley included in V3 Kit uses 6PK but universal pulleys are 8PK.
Actually 8PK pulley have interference while installing and running with the oil level gauge boss and the auto tensioner body.
makinen is offline   Reply With Quote
Old 09-09-2016, 03:07 PM   #385
brzwayne
Drives: 2016 BRZ WR Blue
Has anyone experienced this on their kit?
I have a V2 kit on for about 6 months, roughly 4000km and tonight I noticed oil coming out of the supercharger exit.
Would this oil be the traction fluid or by-pass oil? I haven't thrashed the car it's mostly city driving sub 5k rpm.
Thanks
Photo:
https://drive.google.com/open?id=0B9...2EwNk15RkEyM1E
brzwayne is offline   Reply With Quote
Old 09-10-2016, 01:30 AM   #386
craigpitts7
craigpitts7's Avatar
Drives: 2013 WRB BRZ
Thanks
Photo:
Nope I've thrown mine around pretty hard too. The most I get is a little traction fluid out the lid.
craigpitts7 is offline   Reply With Quote
Old 09-11-2016, 10:41 PM   #387
lostpanda
Drives: FT86
I will do install the V3 kit for my GT86 2013 AT.
I will put the photo here.
Thank you for your support.
Thank you for everybody here.
lostpanda is offline   Reply With Quote
Old 09-12-2016, 02:52 AM   #388
blindfold
Drives: brz
I'm also in china and I've already finished installing V3 on my manual car. Word of advice, do not run the smaller pulley on 95or98Ron fuel, it is meant for E85 that is not readily found at gas stations. So I'm saying unless you are running race gas like VP ms109 ALL THE TIME, then run the original v3 pulley. Watch the type of fuel you are going to use with the smaller pulley.
I am running 265 sized ad08r and you can still out power them easily, just my thoughts.
blindfold is offline   Reply With Quote
Old 09-12-2016, 04:25 AM   #389
makinen
makinen's Avatar
Drives: Toyota 86
Why not?
V3+100mm pulley+RON 98 with no issue.
Even V2 w/o restrictor can live with RON 98.
It's just matter of calibration.
Old 09-12-2016, 10:42 AM   #390
Andew727
Drives: Scion FR-S
yes, you probably arent running the correct catch can or one at all.
you need a proper FI catch can. the v2 blowers spins the fastest.
its "blow-by" oil and fuel vapor that is recirculated to the intake
Old 09-12-2016, 10:49 AM   #391
Andew727
Drives: Scion FR-S
Originally Posted by makinen View Post
Why not?
there are quite a few reasons "why not" but it all depends on your intake temps. if your intercooler is doing its job then you should be good. e85 burns cooler and allows you to pull more timing safely. keep in mind these are draw through maf setups not speed density.
the v1 kits run a 100mm pulley with a much smaller intercooler making much higher intakes temps... you should be fine aywhere below 10-11lbs of boost though. i wouldnt go higher on pump gas... talk to your tuner.
Old 09-12-2016, 10:15 PM   #392
lostpanda
Drives: FT86
It is very luckly to meet some Chinese here.
For the V3 kit the stock pulley is 110mm, also HKS provide a 100mm kit for us.
I heared from Guangzhou there is a guy tune the 90mm pulley for 7040L in Hks v1 to use 95 petrol.
For my v3 kits I think at least 100mm pulley is good for Chinese 98 petrol.
I already have big radiator,oil cooler,also I want to buy a AEM water injetor system. Could you help me to find a way how to reduce my intakes temps?
Thanks a lot!
If the Chinese guys interesting in my v3 kit install, you can add my wechat 13910761886, I can send the Map for the 90 mm pulley tuning.
Kraftwerks Supercharger Owners Thread projek_01 Forced Induction 4310 04-07-2025 02:12 PM
P&L Turbo kit Owners thread Hawaiian Forced Induction 73 07-07-2018 03:31 AM
Five Axis Edition FR-S Owners Thread digital_assassin FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 563 07-08-2015 10:22 PM
**Offical 213/323/626/818 owners thread** mr. slim Southern California 71 10-07-2013 01:58 PM
Supra Owners Build Thread BoostJunkie Other Vehicles & General Automotive Discussions 164 03-12-2012 10:37 AM
