Old 09-07-2016, 02:44 AM   #1
Impureclient
Drives: 2015 FR-S
$20 oil catch can
Bracket to hold can: http://www.homedepot.com/p/Simpson-S...-A33/100374962
Cut one side in half. Grinded the end to fit into the space where the two little holes are on the back of the can(same little holes as the front of the can)
and drilled two holes to mount it to the can. Bent the piece to match angle of firewall and painted it black.
Filter: http://www.homedepot.com/p/Husky-1-4...3HOM/205331767
It's small but I only drive 3-4k miles a year. It looks like it will hold about 2 oz of oil.
They make the exact same thing and bigger, probably like 6 oz size, but I wanted it small.
Nipple to attach hose to can: http://www.lowes.com/pd/BrassCraft-1...tting/50359348
It is very tight just to push it on, so I didn't use any hose clamps
Used two short self taping screw and 2 M4x.70x6 pan phillips machine screws and 4 feet of hose.
I also epoxied the release valve at the bottom shut.
The Following 8 Users Say Thank You to Impureclient For This Useful Post:
Ben_G (09-07-2016), Hyper4mance2k (03-24-2018), lbroskee (09-07-2016), Respect BRZ (09-07-2016), S84kam (09-17-2016), scottman (12-25-2017), stevesnj (12-30-2017), Vino (09-07-2016)
Old 09-07-2016, 01:23 PM   #2
lbroskee
lbroskee's Avatar
Drives: 2023 WRB BRZ (MT)
love that its clear so u can see whats in it
lbroskee is offline   Reply With Quote
Old 09-07-2016, 08:55 PM   #3
apelpapa
apelpapa's Avatar
Drives: 2013 SPD Black FR-S
Heck ya! Just what I needed.
apelpapa is offline   Reply With Quote
Old 09-08-2016, 04:47 PM   #4
FrostedFlakes
Drives: 2013 Raven FRS
Nice. There is one thing missing on this DIY. Can you take a picture and show how the hoses are all properly routed? Your instruction says 4 ft of hose, but I assume you will need to trim them to fit....how long are the hoses supposed to be for each section?
Thanks.
FrostedFlakes is offline   Reply With Quote
Old 09-08-2016, 09:46 PM   #5
Impureclient
Drives: 2015 FR-S
25 inches to intake and 19 inches to PCV on mine. I first had the can mounted. Best bet is to just buy that 4' piece and cut it after that can is done. I connected it to intake and routed it to the can and then cut it. Same as PCV, connect there and route to can, then cut. Depending on where the can is mounted, it will be a slightly different length each time unless you put it in the exact spot I did. Forgot to add about making sure the arrow on top of the can is going in the right direction from PCV to intake.
The Following User Says Thank You to Impureclient For This Useful Post:
D_Thissen (09-22-2017)
Old 12-29-2017, 02:19 PM   #6
scottman
scottman's Avatar
Drives: 13 mt fr-s
Where did you get this hose?
Is any kind okay? ie garden hose?
Thanks.
scottman is offline   Reply With Quote
Old 12-29-2017, 04:16 PM   #7
Grady
Grady's Avatar
I think you are missing where the oil comes from during WOT.
Old 12-30-2017, 01:57 PM   #8
stevesnj
stevesnj's Avatar
I did this years back on my Land Cruiser. I love when guys spend hundreds for a catch can. I LOL
Be careful as over time the plastic can become brittle. I replace mine every few years just for safety sake
My 2016 Build thread
The Following 2 Users Say Thank You to stevesnj For This Useful Post:
chaoskaze (01-03-2018), Impureclient (12-30-2017)
Old 12-30-2017, 09:14 PM   #9
Impureclient
Drives: 2015 FR-S
Thanks.
No for garden hose. Go to Autozone, Advance Auto, NAPA , Oreillys, etc and get the PCV hose by the foot.
You mean the second catch can?
scottman (01-02-2018)
Old 01-02-2018, 11:00 AM   #10
Grady
Grady's Avatar
I did not see a 2nd catch can. You put another one in the line that goes to the inlet just after the air filter?
Old 01-03-2018, 12:03 AM   #11
Impureclient
Drives: 2015 FR-S
I didn't add the second one as I was under the impression that the PCV was the necessary one. Between the crankcase and intake doesn't catch really anything on a
N/A car According to many people who have dual cans. I might just do it though since it's the same price to do as this one with just different length hoses.
Old 01-03-2018, 12:38 AM   #12
ApexEight
Drives: 2014 Subaru BRZ Limited 6MT SSM
Pretty sure an OCC on the air intake tube breather is pointless unless boosted.
ApexEight is offline   Reply With Quote
Old 03-01-2018, 10:48 PM   #13
gcranston
Drives: 2015 Subaru BRZ Limited DGM
No issues with heat affecting the plastic filter globe?
gcranston is offline   Reply With Quote
Old 03-01-2018, 11:46 PM   #14
Impureclient
Drives: 2015 FR-S
1.5 years later, no issues.
The Following 2 Users Say Thank You to Impureclient For This Useful Post:
Hyper4mance2k (03-24-2018), Sypher (03-10-2018)
Which oil catch can for NA? Tor Engine, Exhaust, Transmission 17 05-05-2016 09:12 PM
oil catch can? iarefluffy Engine, Exhaust, Transmission 15 02-03-2015 02:53 PM
Oil Catch Can? eblamble3 Engine, Exhaust, Transmission 4 03-15-2013 11:58 AM
Oil Catch Can.? Cjs_ Engine, Exhaust, Transmission 18 03-01-2013 12:58 AM
Catch Can Help wootwoot Engine, Exhaust, Transmission 2 12-02-2012 03:35 AM
