Old 08-09-2016, 12:56 PM   #43
shr133
shr133's Avatar
Drives: 2013 FRS
turn all settings to full stiff.
front compression- back off 7 clicks from full stiff.
front rebound-back off 10 clicks from full stiff
rear compression - back off 8 clicks from full stiff.
rear rebound- back off 7 clicks from full stiff.
from there I advise you to drive the car in many scenarios BEFORE you make any more changes.
NEVER, NEVER ,NEVER make more than one change at a time. ( you will never know what change made the difference you liked or disliked).
Rebound is on TOP and compression is on the bottom.
Remember as you upgrade your suspension things like rear control arms and rear subframe bushings that will effect these settings so dont be surprised if things feel different after certain changes.
Myles
RCE/ GTWORX
Thanks for the advice, just got a used set off ebay and they had your adjustments already.......
I have my front a 1/4 inch lower so had to add a click of compression and rebound to the front and I think It's about perfect for a daily driver... Just enough to be firm but not stiff and very well balanced....
That 1 click made a big difference, you guys are right, start with your settings and make 1 small adjustment at a time to dial them in.......
shr133 is offline   Reply With Quote
Old 08-24-2016, 12:08 AM   #44
shr133
shr133's Avatar
Drives: 2013 FRS
This set up is working great... I haven't needed to touch a thing....
I could maybe give it another click of rebound..... or a couple of clicks all around but the roads are too rough were I need to drive... Just firm over bumps but not harsh at all...
I also went to 20mm front bar and a 18mm rear bar.... It handles crazy good the harder you push it the flatter it is and can still go over bumps while you're driving like a fool...... I don't spin the tires in turns, you hit the gas and it plants the tires and you go...
If any out doesn't know yet, the KW V3 are great shocks and worth the money....
Lower it a bout an inch and your're good. It looks good and handles great...
Old 09-03-2016, 02:48 AM   #45
wootwoot
Drives: FRS
Are you guys on the older (stiffer) rates or the new (softer) rates? Seems like the new rates at not even worth the trouble... But would like to hear optinions.
Let's see your computer setup! Hanakuso Off-Topic Lounge [WARNING: NO POLITICS] 79 11-06-2022 11:43 AM
Megan Racing Coilovers - Street / Track / EZ STREET - Starting at $699 Shipped GuerillaRacing Brakes, Suspension, Chassis 149 05-12-2015 05:53 PM
Cusco Street Zero-A & Street Spec A Coilovers - In Stock And Ready To Ship Enjuku Racing Brakes, Suspension, Chassis 0 09-12-2012 05:12 PM
Brz Drag Setup Tansey86 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 14 09-12-2012 11:24 AM
Audio setup 315FR-S Electronics | Audio | NAV | Infotainment 20 05-17-2012 06:23 PM
