Old 09-02-2016, 08:10 PM   #15
DoomsdayJesus
In Autobahn withdrawl
DoomsdayJesus's Avatar
Drives: 2015 BRZ Limited Man., WRB
Originally Posted by Toyarzee View Post
Disregard the 300LS suggestion. It's good, but not better or worse than regular gear 300v gear oil since the lsd is a torsen. Additive not required
Thanks, that's what I get for reading too much. Although I could have done worse going with Redline
DoomsdayJesus is offline   Reply With Quote
The Following User Says Thank You to DoomsdayJesus For This Useful Post:
Toyarzee (09-02-2016)
Old 09-06-2016, 01:14 AM   #16
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Most of this info (capacities and fluid types) are in the owners manual.
How to replace said fluids are in the FSM stickied in this subforum
Old 09-06-2016, 02:28 PM   #17
SmireyFase
Drives: FR-S White - Smexy.
I see that he's running the 300V for the manual transmission but the earlier discussions tell me that my automatic car takes something different. Would the 300V also be for automatic?
SmireyFase is offline   Reply With Quote
Old 09-06-2016, 03:57 PM   #18
Toyarzee
Shibby!
Toyarzee's Avatar
Drives: '14 White FR-S, '01 turbo mini taco
No, my point was that the torsen doesnt require 300LS with any special additive for the differential. The auto trans does not use regular gear oil...
http://www.doityourself.com/stry/tra...id-vs-gear-oil
Toyarzee is offline   Reply With Quote
Tax return time = WHEEL CLEARANCE TIME from Gram Lights and Yokohama vividracing Wheels and Tires 4 04-04-2014 03:46 PM
FREE BRAKE FLUID - CONTEST TIME HORSEPOWER DIRECT Announcements, Contests, Giveaways 9 01-14-2014 08:47 PM
12 month and 3 month Xbox live continuecrushing Miscellaneous 3 04-29-2013 12:50 AM
