Old 08-30-2016, 09:52 PM   #16969
It's been filled twice and still does it. Compressor clutch doesn't engage
Now, tell me that you DID check the fuse .........
IF it has been filled twice, was the leak found and fixed ...??
humfrz is offline
Old 08-30-2016, 10:08 PM   #16970
jawn
jawn's Avatar
Drives: 2015 CWP BRZ Limited
Woohoo. Got a tetanus shot today. I might have been a bit overdue.
jawn is offline
Old 08-30-2016, 10:24 PM   #16971
"Rode" is a perfectly acceptable term in that application and I ain't cryn bout shit.
'Rode' is the simple past tense. When combined with an auxiliary verb, the past participle must be used. For example:
Grammar rules blew his mind.
His mind got (or was) blown by grammar rules.
I would never say "His mind was blew."
Ultramaroon is offline
Sarlacc (08-30-2016)
Old 08-30-2016, 10:39 PM   #16972
Ashikabi
Ashikabi's Avatar
It still works if the fan is turned on before the car is started so the fuse can't be bad. Also it was filled the first time cuz my condenser was replaced, second time when they rebuilt my engine unless they used some magic and many zipties to keep the AC system intact while pulling the motor
Ashikabi is offline
Old 08-30-2016, 10:41 PM   #16973
Ashikabi
Ashikabi's Avatar
Filled twice? Pressure tested? An over pressurized compressor will do all sorts of weird and wonderful things including stopping and starting as it pleases.
Don't know that it was pressure tested
Ashikabi is offline
Old 08-30-2016, 10:50 PM   #16974
Sarlacc
/dev/null
Sarlacc's Avatar
Drives: Uphill
Sarlacc is offline
The Following User Says Thank You to Sarlacc For This Useful Post:
Ultramaroon (08-30-2016)
Old 08-30-2016, 10:54 PM   #16975
soulreapersteve
Contract? /人◕ ‿‿ ◕人\
soulreapersteve's Avatar
Looks like I won't have to be a shut in potato hermit for the rest of the week. Called them and they said its all fixed up. Gauge is now reading correct level. Time to register for track day.
Most likely, I'll still be a potato hermit...
The Twins make me smile
soulreapersteve is offline
Old 08-30-2016, 11:04 PM   #16976
Originally Posted by Sarlacc View Post
It could of went either way.
Sarlacc (08-31-2016)
Old 08-30-2016, 11:10 PM   #16977
OK, good to hear it was fixed ......
Now, don't be hot rodden around them cones so much ...........
humfrz is offline
soulreapersteve (08-30-2016)
Old 08-30-2016, 11:11 PM   #16978
Float stuck on a tube? Ockham FTW.
HunterGreene (08-31-2016), soulreapersteve (08-30-2016)
Old 08-30-2016, 11:17 PM   #16979
Well, OK, what's the ..............rest of the story..??
* you jumped on a rusty nail?
* an animal bit you?
* a nasty sex partner bit you?
humfrz is offline
jawn (08-30-2016)
Old 08-30-2016, 11:19 PM   #16980
If they half-assed the charge by not first evacuating properly, or blatantly overfilling it, that would cause issues. There's an under/over pressure switch on the system. You could check the state of the switch with either techstream or a multimeter.
If the clutch engages sometimes, then it's not the clutch.
Download a copy of the service manual and dig in!
Old 08-30-2016, 11:38 PM   #16981
soulreapersteve
oh, its going to be an actual track day! With corvettes and porsches stretching their high powered legs past me haha
Yeah I know right?? So the original part was actually broken, but when they replaced it, looks like they forgot about the tube... or it simply got tangled with the float. Least thats what I gathered from the work notes.
Anyhoo, I'm a happy camper now. Took out the back seat and sprayed a tiny bit of Ozium on the rear floor mat in hopes of getting rid of the gas smell faster.
The Following 2 Users Say Thank You to soulreapersteve For This Useful Post:
humfrz (08-30-2016), Ultramaroon (08-31-2016)
Old 08-30-2016, 11:49 PM   #16982
iManage
iManage's Avatar
Drives: '14 Whiteout Pearl
iManage is offline
