Old 08-30-2016, 07:34 PM   #1
TheMedakaBox
[EUROBEAT INTENSIFIES]
TheMedakaBox's Avatar
Drives: 2015 Scion FR-S Steel
Considering Lemon Law or similar
I've owned my 2015 AT FRS for close to 2 years now but as of now the car is leaking oil for the 2nd time. The first time it leaked was at approximately 36k miles. Toyota applied a new gasket and was ok for a while. Now it's leaking oil again after 7k miles. Ive also have taken it in for various TSB recalls like the AT hard shifting, HPFP replacement for the crickets and Idle hunt issue.
In short I have an extended warranty and I love my car but I've been having a lot of issues with it. Plus I've kind of been eyeing the new 2017 BRZ. Would appreciate any tips or opinions. At this point if Toyota re-applies the gasket and fails a third time I'm gonna be pissed.
Edit: First oil leak was from a timing cover seal failure. Same issue for current oil leak.
TheMedakaBox is offline   Reply With Quote
Old 08-30-2016, 07:47 PM   #2
swarb
Read your local laws on the matter.
Find a lemon law layer.
You have an extended warranty... use it?
It's not that easy to lemon a car, it needs to be for the same problem. You don't mention which gasket was repaired.
Old 08-30-2016, 07:52 PM   #3
Toyarzee
Shibby!
Toyarzee's Avatar
Drives: '14 White FR-S, '01 turbo mini taco
First off, lemon law applies to the SAME exact issue recurring 3 times with the same failure. 2 times does not work, and it cannot be for an issue that is not detrimental to the drivability of the car. AT Hard shifting and idle hunt were just new flash tunes... and different successful repairs under TSB will be non issues in Subaru's perspective.
What's leaking oil? Is it the same leak reoccurring?
Toyarzee is offline   Reply With Quote
Old 08-30-2016, 07:57 PM   #4
TheMedakaBox
Service reported that the oil was leaking from the timing cover at 36k. It's leaking from there again now.
Old 08-30-2016, 08:33 PM   #5
Oh, I'd suggest you have the timing chain cover sealed again, under warranty.
Then, maybe consider trading it for a new, bright, shiny one.......
Old 08-30-2016, 08:44 PM   #6
Teseo
Drives: frs
Sound like hotlava
The Following 2 Users Say Thank You to Teseo For This Useful Post:
humfrz (08-30-2016), soulreapersteve (08-31-2016)
Old 08-30-2016, 09:15 PM   #7
mrk1
Drives: Sterling BRZ Ltd
I work at a dealer (Not Toyota/Subaru) and buy backs are more likely then lemon law, usually newer cars though.
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
Old 08-31-2016, 01:29 AM   #8
TheMedakaBox
I wouldn't mind a buyback option. But am I required to get the same car from the same dealer? I'm curious because if I follow through with the buyback option from Toyota can I go to Subaru after they take it back.
Old 08-31-2016, 08:42 AM   #9
Summerwolf
Panda Trueno
Summerwolf's Avatar
Drives: No twin now.
Doubtful with the mileage and lack of actual drivability issue / same issues there is a "lemon law" case here.
Old 08-31-2016, 08:57 AM   #10
OHHHH new shiny model out. How can I manipulate the system to get one?
Get the car fixed if there is a problem and if you really want a new one then take the hit and trade it.
86geek (08-31-2016), BRZoomTX (08-31-2016), JazzleSAURUS (08-31-2016)
Old 08-31-2016, 09:12 AM   #11
KendallH
Drives: 2013 FR-S Base, 1997 Jeep Wrangler
That would require accepting responsibility for vehicle ownership. Millenials just cant wrap their heads around that.
KendallH is offline   Reply With Quote
The Following 2 Users Say Thank You to KendallH For This Useful Post:
Tcoat (08-31-2016), why? (09-01-2016)
Old 08-31-2016, 09:22 AM   #12
JazzleSAURUS
Drives: 15 BRZ LTD, 05 FXT
As a responsible millennial, (owns two cars, about to get married, own a home, gainfully employed for the last 8 years, 6 by the same company,) why are old farts so hellbent on pointing fingers at us like it's a systemic problem with my whole generation because my birthday falls in a specific time range?
OP: Bring your car back and get it fixed under warranty. You do not apply for the lemon law, you are just frustrated at the reliability of a non-drive ability related failure. If it bugs you, trade it in on a new one with the exact same gasket (down to the part number.) Or maybe an ACTUAL Toyota product, like a Camry.
If it does not bug you, keep driving like nothing ever happened. There's a decent chance the tech did a bad job installing the gasket, or didn't clean the surface correctly. Express your displeasure that it's a return visit with the same issue to the service writer, and they can be sure one of their most competent techs does the work to see what the root cause is.
JazzleSAURUS is offline   Reply With Quote
The Following 5 Users Say Thank You to JazzleSAURUS For This Useful Post:
Bearcat86 (08-31-2016), DustinS (08-31-2016), soulreapersteve (08-31-2016), Tcoat (08-31-2016), TheMedakaBox (08-31-2016)
Old 08-31-2016, 09:29 AM   #13
TheMedakaBox
Again, I'm only considering buyback if my twin can't keep its shit together. I included an extended warranty when I financed it predicting problems would arise much later, but I didn't expect this soon in mileage. I'm just upset that the car leaked after 36k and again now.
Old 08-31-2016, 09:40 AM   #14
Because, since the days of the caveman, that has been a primary duty of the job of us "old farts". One day we will pass that responsibility on to you, and we want to make sure you are ready for it.
The Following 10 Users Say Thank You to Dadhawk For This Useful Post:
86geek (08-31-2016), Bobby@Forged (08-31-2016), DustinS (08-31-2016), humfrz (08-31-2016), JazzleSAURUS (08-31-2016), MuseChaser (08-31-2016), new2subaru (08-31-2016), soulreapersteve (08-31-2016), Toyarzee (08-31-2016), why? (09-01-2016)
What happens after lemon law Herndon Scion FR-S / Toyota 86 GT86 General Forum 7 02-28-2014 06:20 PM
BRZ- Lemon? laxfogo Issues | Warranty | Recalls / TSB 24 04-05-2013 05:15 PM
So my FR-S is officially a lemon... frsinpa Scion FR-S / Toyota 86 GT86 General Forum 90 01-19-2013 11:50 AM
Lemon? grgonium Scion FR-S / Toyota 86 GT86 General Forum 13 10-08-2012 10:13 AM
