Old 08-30-2016, 10:56 AM   #393
KendallH
Drives: 2013 FR-S Base, 1997 Jeep Wrangler
The MAP sensor will always read differently than a standalone gauge, FYI.
KendallH is offline   Reply With Quote
Old 08-30-2016, 11:07 AM   #394
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
Not necessarily. When tuned by OFT it would display the same pressure. Moto-East Scales the MAP sensor differently in their tunes. I am assuming because they use speed density. So MAP sensor reading is useless for me.
Would be interesting to note if the MAP sensor would read different with the new OFT tunes as they use Hybrid Speed Density now.
Edit: Got the okay to switch to E85.
Old 08-31-2016, 10:59 AM   #395
DustinS
DustinS's Avatar
Threw in some E85 last night. Runs great, seems to be so much smoother than pump gas. I was only getting ~16mpg on pump gas due to my fueling issues (still not sure if tune related or an issue in the car I.E. Vacuum leak). Not too excited to see what E85 Mileage will be like.
Old 09-13-2016, 04:33 PM   #396
DustinS
DustinS's Avatar
Not a whole lot going on at this point, a lot of waiting and planning. Enjoying E85 power, hating the gas mileage haha.
I am starting to look for the best place to build the engine. I had planned on going Element tuning, but they have a long wait list. Engine will need to be pretty robust for the plans brewing. Any suggestions would be greatly appreciated.
The Following User Says Thank You to DustinS For This Useful Post:
killboy (09-14-2016)
Old 09-15-2016, 10:42 AM   #397
DustinS
DustinS's Avatar
MAPerformance sells a complete NEW short block for the price that element takes to build you old short Block. I would just need to figure out the head situation.
I would really like the Head package from Element Tuning still, but I don't think they do just heads. Really after the 1mm oversize exhaust valve and good valvetrain to be safe to 8000RPM (9000RPM in element build head)
Old 09-19-2016, 10:20 AM   #398
DustinS
DustinS's Avatar
Okay. Plans are being set in stone and things are moving along (as soon as my parts guy gets back to me...)
Sell Current Turbo kit
Built Engine
Custom T4 Twin Scroll Manifold
Custom 3" Downpipe
GTX4088R
Cosworth Supercharger
Bigger A/W Pump
Treadstone TR6/TR8 intercooler
Tial BOV
Tial MV-R x2
Multiple New Gauges (Multiple boost, air intake temp, Possibly Exhaust Manifold back pressure)
The Following 3 Users Say Thank You to DustinS For This Useful Post:
D_Thissen (09-19-2016), JustAnEngineer (10-19-2016), killboy (09-23-2016)
Old 09-20-2016, 09:01 PM   #399
DustinS
DustinS's Avatar
Really liking the billet merge collector. Should make the manifold easy to weld for someone who is just learning. (like me)
D_Thissen (09-20-2016)
Old 09-21-2016, 07:33 PM   #400
Cockatoo
TALLY FT86
Cockatoo's Avatar
Drives: 2014 FR-S Monogram -- SBD Turbo --
Didn't see twincharged coming...
Sent from my Nexus 6P using Tapatalk
Cockatoo is offline   Reply With Quote
The Following 2 Users Say Thank You to Cockatoo For This Useful Post:
DustinS (09-22-2016), Travisty75 (10-10-2016)
Old 09-22-2016, 03:44 PM   #401
spitfire481
spitfire481's Avatar
Drives: 2JZ FRS
buy my t4 manifold, ill give you a good deal lol. one problem with 8k rpm + is the di pump pressures oscillate between 600-2000 psi. that was my reading through motec on e85 at least. the ecu was fast enough to compensate di duty cycle to make up for it though. ps, buy my motec as well lol
Pure Automotive Performance
MoTeC
Build Thread
@spitfire481
The Following User Says Thank You to spitfire481 For This Useful Post:
Old 09-22-2016, 04:15 PM   #402
DustinS
DustinS's Avatar
If it was twin scroll I would!
Motec isn't in the cards right now. Not with the expense of everything else that is happening currently. Maybe in the future. Not that it helps you trying to sell yours now haha
spitfire481 (09-22-2016)
Old 09-23-2016, 09:52 AM   #403
DustinS
DustinS's Avatar
Quick Fly-by of my car last night. The crappy tires squeal louder than my almost straight piped exhaust.
[ame="http://youtu.be/DsdjhD116tY"]https://youtu.be/DsdjhD116tY[/ame]
D_Thissen (09-23-2016), Futaba (09-23-2016), Yoda (09-28-2016)
Old 09-23-2016, 10:34 AM   #404
Futaba
Futaba's Avatar
Drives: GT86
Sounds so nice! amazing work man
Futaba is offline   Reply With Quote
The Following User Says Thank You to Futaba For This Useful Post:
DustinS (09-23-2016)
Old 09-28-2016, 09:47 AM   #405
DustinS
DustinS's Avatar
Had a very weird and bad case of Knock a couple nights ago. Resulted in .50 IAM. I have tried everything to get it to come up(IAM though it is good to note I can't recreate the knock event either), slow acceleration 1rd-4th, decently quick acceleration in same gears and WOT in each gear with no results. It has crept up to .67 but seems to go up at the weirdest times. Anyone know how much this affects the drivability/power of the car? Had some play time with a couple friends on the way home last night and the car didn't feel as strong as normal. May have just been placebo effect though.
Picture I grabbed last night
Old 10-10-2016, 10:30 AM   #406
DustinS
DustinS's Avatar
Girlfriend wanted to get shots of the car
The Following 2 Users Say Thank You to DustinS For This Useful Post:
Cockatoo (10-10-2016), D_Thissen (10-10-2016)
The reason I'm always broke - Dustin's Supercharged 86 Dustin Member's Car Journals 211 11-08-2015 10:57 AM
Help! New Car Engine Blew Up. What are my rights? Obsidiank Scion FR-S / Toyota 86 GT86 General Forum 53 12-11-2014 11:43 AM
Midwest Modified - Auto Photography by Dustin Faulkner (aka Fancy) Kuzuri Great Lakes 20 02-16-2014 05:23 PM
Engine Warm-up Time Chad86 Scion FR-S / Toyota 86 GT86 General Forum 44 01-10-2014 12:03 AM
So my engine blew up.... alliedcam1 Engine, Exhaust, Transmission 57 12-28-2013 02:50 PM
