#1569 |
Drives: 2015 BRZ, 2005 STI, 2024 Type R
I've read both install manuals and the JRSC definitely looks easier than the Edelbrock kit, but I'm mechanically inclined enough to install either. I would just need more time with the Edelbrock kit.
#1570 |
So how do owners feel about the kit so far? Long term driving impressions? Does the extra power change the way the car behaves when it's being pushed?
#1571 | |
Drives: 2013 Subaru BRZ, Edelbrock SC, E-85
Now running a delicious tune with the Delicious D BOX and it's an even more fun, and smooth, experience. No reliability issues yet, and I was in a fender bender doing about 10-15mph prior to the new tune. Had to replace the air box, but everything else is healthy. Sent from my SAMSUNG-SM-G890A using Tapatalk |
#1572 | |
Simply Forgotus
Drives: 2014 Supercharged SSM BRZ Limited
Indeed I did. Seems to be working well so far...still testing and looking for a small tank to fit in front of the fuse box. It is sharing the engine coolant overflow tank at the moment which I don't think will pose any problems since the radiator and intercooler surge tank caps are pressure caps and should prevent each system pulling coolant from the other, only pulling or expelling to the main overflow tank. <$10 at Home Depot for the supplies. What I really want is @Edelbrock LLC to come up with a larger volume surge tank! Maybe V2 or a retrofit. Last edited by BirdTRD; 08-29-2016 at 06:41 AM. |
#1573 |
I installed the Delicious D-box today. VERY noticeable difference in the upper RPM range. All the surging is completely gone. You definitely want to install a D-box with this supercharger.
-craig
2013 Subaru BRZ - AT - Satin White Pearl - Edelbrock Supercharger
2016 Subaru WRX STi - World Rally Blue Pearl |
#1574 |
Drives: 2015 FRS
Is the D-box suitable for other applications or is it just for the E-Force (TVS)? What is its actual function?
Sent from my HTC 10 using Tapatalk |
#1575 |
I'll have to let the experts answer if there is any benefit with other systems. My understanding is that the MAP sensor can give wildly inaccurate readings under some circumstances (for just a few milliseconds). I believe the D-box acts as a filter to smooth out the MAP sensor input. Again, maybe someone from Delicious can give a better technical answer than mine.
-craig
#1576 | |
Drives: UK GT86
.: Stealth 86 :.
#1577 |
If someone were to buy the kit used, does anyone know if Edelbrock is able to sell any of the parts bags containing the various nuts, bolts, crush washers, etc separately? I'm referring to bags #1-4 listed on page 3 of the installation guide here:
http://www.edelbrock.com/fa20/downlo...structions.pdf I don't see a way to contact Edelbrock via email so I'm asking here for now. |
#1578 |
There are part numbers for each of those parts listed in the instructions. That would indicate that the parts can be ordered individually. If you go to the Edelbrock web site, there is a link to a contact page where you can send them a message.
#1579 | |
sleep, drive, eat, repeat
Drives: '13 BRZ, '12 Outback
If I were to do it again, I'd still buy this kit, partly because its been hassle free but also because of the service I've had with Edelbrock and DT. Plus now its officially CARB certified! Give their tech support number a call. I've ordered various spare parts for the kit from them a few times. |
#1580 |
Just as a reminder, all E-force purchases from CSG include a free D-box upon request.
#1581 | |
Is the extra weight from the system noticeable on tight roads? I guess the main thing I'm worried about is the car losing it's willingness to be constantly revved up in the higher RPM range. I love how responsive this car is, but just like a little more power for daily driving. I'm worried I'm going to ruin such a well balanced platform though. |
#1582 | |
Regarding the "willingness to be constantly revved up" I have found zero need to do that because of the new power band. Peak torque is actually earlier now, so I never have the need to wring out the car. The only reason I did when I was stock was to get more power in the first place, but that's not a problem anymore. I can just stick in 3rd and power on/off into/out of corners. On the track, I actually naturally found myself shifting around 6k rpm instead of redline. If you want something that requires you to be at the redline, with just a little more power, maybe E85 is more your style? "Responsive" is such a loose term, so I'm not sure how to answer that. If you're talking about throttle mapping, yes, the CARB tune is much less "responsive" than say the DT tune, but not different from stock. I actually prefer the CARB tune since this is my daily driver. Not sure if I'm answering your questions/concerns accurately (we can have different definitions) but since you're local, I'd be happy to meet up with you some time. PM me if you have more detailed questions
| Vortech Owner Thread & Setup Questions | reyruiz191 | Forced Induction | 340 | 05-17-2022 12:44 PM |
| Edelbrock E-Force Supercharger | itsibarra | Forced Induction | 938 | 07-31-2021 04:48 PM |
| Most annoyingly over-asked questions on FT86 forums | mit_peid | Off-Topic Lounge [WARNING: NO POLITICS] | 36 | 01-16-2014 02:48 PM |
| Brz Info/Specs (helpful info for questions asked often) | Gaen | BRZ First-Gen (2012+) — General Topics | 0 | 05-24-2012 10:09 PM |
