Old 07-16-2016, 10:59 PM   #1
tofurun
tofurun's Avatar
Drives: 2014 BRZ Limited 6MT
Jackson Racing Dual Radiator Review
Just thought I would write up a few things I found about the JR dual Radiator/oil cooler.
-Oil temps before sat around 205-210 cruising. Now are at 183-195 depending on driving. They cool down very fast at a stop.
-A small 1-3 degree difference in the actual coolant. By the way our stock radiator is the same thickness as the AC condenser wow...
-The Bolt or whatever you want to call it holding down the oil plate does not specify a torque. Everyone else uses 25lbs. I did not at first and it was loose. I suggest torque being used on that 27mm.
One problem that was very irritating was the top Oil Line fitting kept kinking. I wish they had an NA option or at least that's why I think they run the line all bent to get past their super charger kit. I can understand that but just annoying to worry about.
The actual fitment of the radiator was dead on 0 problems. It bolted right up and seems to be a very good quality radiator.
Their customer support team was awesome and great to talk to so that was a plus too.
My only question about the whole kit was on the last page. I just sent an email to them so I am curious to see their response.
"Check the rotation of the oil filter adapter at this time and tighten the 27mm hex. Stock Airbox: The AN line closest to the oil filler cap will need to be as close as possible to the oil filler cap. Jackson Racing Supercharger: The AN fitting doesn’t need to be as close. "
tofurun is offline   Reply With Quote
Old 07-18-2016, 09:33 PM   #2
tofurun
tofurun's Avatar
Update
"This is to clear the factory airbox.
Avoid kinking by rotating the oil line ends until they find a natural alignment. The most important thing is to find a natural hose alignment." -Jackson Racing
Sooooooo im good and anyone else that may have this problem in the future.
Update 7/27/16
-Hoses are holding good. no leaks. Went to check tightness and did a little tighter but hoses still seem like they want to kink... Very sketchy hoses.... If they do kink im assuming all that will happen is no cooling will occur so I am going to just run it. If that happens I plan on just fitting custom hoses and ordering my own.
Old 08-28-2016, 10:35 PM   #3
tofurun
tofurun's Avatar
Had my first issue today. Ran the tar snot out of my car on the mountains this morning. Drove 6 hours back home in the same day. Went to check everything out and there was oil on the bottom AN fitting of the radiator. Gonna take everything off this week so i can get to this fitting but it seemed tight to me. I dont know if it just spewed a bit or what but I can see oil on my fan shroud too. Looks like I lost about .1 or .2 quart. Not sure if the high oil pressure just cause it to spew or what. Im gonna tighten the crap out of the fitting is thats the only place i find oil and go from there.
Old 08-29-2016, 05:01 PM   #4
CounterSpace Garage
CounterSpace Garage's Avatar
Drives: Subaru BRZ / Toyota 86 Experts
The bottom AN line must be torqued appropriately, but not torqued too much or too little. Also, threading on the line is utmost importance to ensure you do not strip the threads. Everything is precise and fits perfectly when done properly. The "kink" is actually a soft bend. We have seen the kinked lines, but when routed properly (this takes a little time), it bends ever so slightly. This allows it to clear the OEM airbox.
CounterSpace Garage is offline   Reply With Quote
Old 08-29-2016, 05:29 PM   #5
Dr. BRZ
Dr. BRZ's Avatar
Drives: 2013 WR Blue Pearl BRZ Limited 6MT.
useless without pics.
Dr. BRZ is offline   Reply With Quote
Old 08-29-2016, 09:51 PM   #6
tofurun
tofurun's Avatar
lol this car drives me nuts. I take everything off and tighten the bottom AN fitting gorilla tight. JR has no torque specs for this. I let the car heat up and run the revs up got the oil temps to 205 or so. Felt the AN fitting and it had a super small coat of oil on it. Cleaned it off and thought well thats either new or was the other side of the fitting I couldnt get to before I tightened it. Ran the car on some back roads and got the temp of again (which is not easy with this setup they did a really really good job). came back had a touch of residue. Ima let it ride and see if it build back up like it did. Who knows now when the AC is off the coolant temp jumps up to 210 and then the safety fans cut on and cools it back down to 206... have to turn the AC to get it back down to 194... This car man.
its a review not a DIY
Old 08-30-2016, 01:26 PM   #7
CSG David
CSG David's Avatar
Check the threads. We've had guys who put several thousand miles on them with some spirited drives without issue. Gorilla tight isn't good either. If the AN fitting is spinning, you may have stripped something.
Old 08-30-2016, 01:46 PM   #8
tofurun
tofurun's Avatar
Everything is tight and nothing loose or spinning. I think it just wasn't tight enough. It sat over night and everything was still dry. Going to drive it again when I get off work but it seems to be fine as of now. Installer error ftw most likely
Old 08-30-2016, 02:58 PM   #9
CSG David
CSG David's Avatar
Sounds good. Looking forward to a good install this time. I've helped several guys install these units already and none of them had issues (these magical hands!).
Old 11-06-2017, 06:28 PM   #10
Jyukai
Drives: scion FR-S MT
mine was slightly leaking from fitting, then i tighten all fittings super tight with an adjustable wrench, after 1 track day everything seem to be oil free beside the oil filter... I guess b/c i reuse the same filter and its gasket couldnt hold anymore...
btw the bottom fitting i used some thread seal, it wasnt super tight but no leak at all. just wonder if that will cause any problem?
Jyukai is offline   Reply With Quote
Jackson Racing Dual Radiator/Oil Cooler Jackson Racing Engine, Exhaust, Transmission 439 12-03-2021 11:34 PM
Jackson racing dual oil cooler radiator tofurun DIY (Do-It-Yourself) Guides 2 07-11-2016 04:56 PM
Jackson Racing Scion FR-S & Subaru BRZ Dual Radiator/Oil Cooler Jackson Racing Engine, Exhaust, Bolt-Ons 0 04-25-2016 05:35 PM
Jackson Racing SC, Radium dual catch can, EcuTEK cable negligent Engine, Exhaust, Bolt-Ons 23 03-13-2016 12:55 AM
FS: Jackson Racing SC kit, brand new blower + Radium Dual Catch Cans autograph NY / NJ / CT / PA 6 10-29-2015 09:06 PM
