#393 | |
Drives: 2013 FR-S Hot Lava
Honestly unless you are looking for a certain lollipop feature that KitKat does not have...there is little reason to upgrade. Both have the same theme skin and it is the same quad core processor and 1 gb of ram so you will doing the same things with it. I have no issues with mine being on KitKat. |
#394 | |
Drives: Asphalt FR-S
#395 | |
Joying-USA
Drives: Highlander 08
as was mentioned. the 4.4.4 model does a great job and I would stay with the mtcB 4.4.4 model till the mtcD 5.1 model is more stable and also get the 2GB RAM upgrade. If I can help you guys out with Joying products let me know. I check the forum from time to time when time allows. |
#396 |
Addicted
Drives: 2013 Asphalt FR-S 6MT
http://forum.xda-developers.com/andr...evice-t3385309
Isn't this for 5.1 Lolipop? These are roms for MTCD which I thought implies Lolipop 5.1.
Phantom Supercharger | Tsudo Cat-Back Exhaust | K&N Drop-in Filter | Winjet Headlights | Opti-coated | 35/20 Tint | Radar/Dashcam Hardwired | OFT tuned | OEM Audio+ Reference 400CF | Uber Sound Deadened | LED DRL strips | JPM Coachworks Kneepads
#397 |
Addicted
When I am playing music via Spotify and run Google Maps, music will stop immediately. I think it is being muted (as opposed to paused).
Is this happening for anyone else? It seems to be only Google Maps; Waze runs fine with background music.
#398 | |
TRACKBREAD
-Josh |
#399 |
Drives: Firestorm red FRS 2015
Hi all,
What is everyone using for a music app? Also what are your eq settings? I am using poweramp ,which is great, but I am having an issue with getting the sound right at higher volumes... IT is either too boomy or tinny.? |
#400 |
TRACKBREAD
Here are my equalizer settings:
![]() I'm not done tweaking it, but it sounds pretty good to my ears, better than the stock radio at least. It's a little warmer than neutral so you might want to drop the midrange a bit more if that's not your thing. Bass could be a smidge higher but this setting keeps my doors from rattling. -Josh |
#401 |
Drives: 2016 ZC6
I've been using Black player for a while. I like it but I'm still open to trying out others. As for EQ settings, it really depends on the song and what kind of music you listen to.
My build thread: Pointmutation's WRB BRZ build
#402 | |
TRACKBREAD
-Josh |
#403 | |
Drives: 2013 BRZ Limited / 2024 G70 3.3T
https://play.google.com/store/apps/d...jp.musicplayer It's got a bunch of EQ presets from different musicians which is kind of interesting, and the paid version works with USB DAC's. |
#404 |
Drives: 2016 ZC6
I'm not sure. I've always thought fade in/out was a nice touch in music apps but I don't go particularly looking around for that function.
#405 |
Drives: 2016 ZC6
Finally had some time to open up my dash and get the stock reverse cam working with my Joying 4.4.4 unit. Also wired up the radio antenna even though I only listen to the radio rarely.
See http://www.ft86club.com/forums/showt...39#post2740339 for how I wired up my 2016 BRZ stock reverse camera to the Joying HU without modifying any stock pieces. And for the radio antenna, I used a Metra 40-LX11 antenna adapter to plug into the HU. The blue wire on the adapter was not used since BRZ has antenna power on another harness already. The HU already had the antenna amp wire connected correctly for my 2016 BRZ. Testing everything out... Fire extinguisher just in case. j/k ![]() Tested everything out before reassembly of dash and all worked as expected. Reverse camera lines have to be activated in the android OS but the default ones in the Malaysk rom I'm using doesn't line up well for the angle of the stock camera. I'll have to mod the apk for that later on. The radio reception using this HU is so much better than the stock 2016 Starlink unit I originally had. Like day and night difference.
#406 |
Anyone try the malaysk 5.1 ROM for mtcb HU?
| Another Android Head Unit | Starscream15 | Electronics | Audio | NAV | Infotainment | 57 | 08-23-2015 12:41 AM |
| Dashlinq4 Android Head unit. Stock BRZ fitment. Toyota Universal. | junglizste | Audio/Visual, Electronics, Infotainment, NAV | 3 | 01-08-2015 11:55 AM |
| Ca-Fi Dashlinq4 Android head unit universal Toyota | phanguy | Audio/Visual, Electronics, Infotainment, NAV | 4 | 11-19-2014 11:57 AM |
| FS: T7019A Android Head Unit | pheoxs | Audio/Visual, Electronics, Infotainment, NAV | 4 | 08-26-2013 05:05 PM |
| Android head unit | drei | Electronics | Audio | NAV | Infotainment | 21 | 07-16-2012 02:42 AM |
