Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
08-11-2016, 11:54 PM | #15 | ||
Drives: BRZ, STI, GT350R, Supra, 987.2
Looking at pictures online, it looks like we'll need a different bracket for those that are RHD. Thanks, Eric |
08-13-2016, 05:02 PM | #16 |
Long Distance Driver
Love the design and R&D that went into this.
Whats nice to see is the optional coolant passages, Another form of contamination not going into the motor! |
08-14-2016, 03:11 PM | #17 |
Here are some updated photos. Received the anodized and laser engraved parts and started assembling.
-6AN ORB to 1/2" hose barbs Caps with the coalescent filters installed Close up of filters installed Took off the prototype unit. Both sides of the AOS have oil traces on the filters showing they're doing their job. Definitely, need both sides filtered if you want to extract all of the oil out. Thanks, Eric Last edited by VerusEric; 08-09-2017 at 09:30 PM. |
The Following User Says Thank You to VerusEric For This Useful Post: | Calum (08-14-2016) |
08-14-2016, 03:50 PM | #18 |
in the recliner of rage
Drives: Asphalt FR-S
I like how you've incorporated coalescent filters into the design, and I think the unit looks great. But for those of us who would rather not drain the catch oil back into the pan, is there a way to check the fluid level of the can? Is a sight tube an option?
08-17-2016, 01:12 AM | #19 | |
From my experience, you won't need to drain it more than once an oil change unless you track it heavily. With a Fumoto drain valve threaded in, it'd be quite quick and easy to drain. Here are some more assembly photos. Rear of base assembly First (3) fully assembled units Each mesh ball gets a sonic cleaning before being installed into the cans for half an hour. Installed photos If there are any photos you guys want of something specific, please let me know. I'll have an install manual up soon and these should be fully assembled shortly and ready to go shortly. Thanks, Eric Last edited by VerusEric; 08-09-2017 at 09:33 PM. |
The Following User Says Thank You to VerusEric For This Useful Post: | yberther (08-17-2016) |
08-17-2016, 08:57 AM | #20 |
TALLY FT86
Drives: 2014 FR-S Monogram -- SBD Turbo --
Looks really clean!
08-22-2016, 01:52 AM | #21 |
Here are the last few photos of assembly.
Coolant passage port uncovered Coolant banjo bolts installed. Came out better than I had hoped! These should be available for order later this week on both FT-86 SpeedFactory and Velox website. Thanks, Eric Last edited by VerusEric; 08-09-2017 at 09:34 PM. |
The Following 3 Users Say Thank You to VerusEric For This Useful Post: |
08-22-2016, 03:27 AM | #22 |
Drives: FR-S Whiteout
Beautiful!
Intent > Content
cowardice is the mother of cruelty. |
The Following User Says Thank You to solidONE For This Useful Post: | VerusEric (08-22-2016) |
08-24-2016, 02:50 PM | #23 |
These are now for sale on our website and soon FT-86 SpeedFactory.
http://www.velox-motorsports.com/#!p...c-c921839a6b69 I noticed during final assembly that the bases on the blue units had some discoloring. I'm not sure what happened during the anodizing process but these are on clearance for anyone that doesn't need a "show quality" AOS. Below is an example of one of these blems. Thanks, Eric |
The Following User Says Thank You to VerusEric For This Useful Post: | 15limited (08-24-2016) |
08-24-2016, 10:46 PM | #24 |
Props for not just mixing in discolored units with the others and calling it a day. I have your LCA and they look amazing 👍 Velox has the quality control all companies should live by
Perrin Transmission Bolt, Drift Button,Intake Tube, Radiator Hoses, Engine Mounts, Gurney Flap Diode Dynamics Always On Module OLM 3k HID Foglights GCS Smoked Side Markers Motul Gear 300/300 V OE Acantara arm rest Password JDM Dry Carbon rear diffuser Rally Armour Mud flaps H.I.C side & rear visor Gruppe-S UEL header/OP HKS Front Pipe Leg Sport Cat Back Koyorad aluminum radiator Wheelhaus CF low pro 3rd brake light Toms JDM Clear Tail Lamps
08-25-2016, 10:12 AM | #25 | |
Drives: Raven Fr-S
<insert Colbert's give it to me now gif>
FR-S Mod target: 200 BHp / Tonne 4lb Li Battery, RPF1 17x9, 245 RE71R, RCE T2, OFH, OFT Stg 2, Berk Over+Front Pipe, , STI Eng/Trans Mts, PU Bushings, Forrester Liq-Liq oil cooler, Al Driveshaft, OSGiken Diff |
08-25-2016, 11:01 AM | #26 |
Drives: 2018 Golf R
From the drop down on their website, select Blue-Blemish Unit.
Parting out HERE
08-25-2016, 12:19 PM | #27 |
Drives: 2014 Subaru BRZ
08-25-2016, 06:02 PM | #28 | |||
Coolant kit and drain kit are now on there as well. FT-86 SpeedFactory will probably have them on the shelf/website soon as well. Coolant: http://www.velox-motorsports.com/#!p...9-d5aecc4258a4 Drain Kit: http://www.velox-motorsports.com/#!p...d-de3c930fc1ad Thanks, Eric |
Similar Threads | ||||
Verus Engineering High Performance Radiator - Gauging Interest | VerusEric | Engine, Exhaust, Transmission | 90 | 07-08-2023 07:43 AM |
Verus Engineering Rear Wing Development | VerusEric | Tracking / Autocross / HPDE / Drifting | 203 | 07-05-2021 09:15 AM |
Verus Engineering Billet Transmission Beta Tester Run | VerusEric | Engine, Exhaust, Transmission | 62 | 04-26-2020 01:44 PM |
Verus Engineering Carbon Thermoplastic Splitter Components | VerusEric | Cosmetic Modification (Interior/Exterior/Lighting) | 35 | 11-26-2017 05:23 AM |
Raceseng | Revo Pulleys Information and Release | Raceseng | Engine, Exhaust, Transmission | 3 | 10-09-2016 11:01 AM |
