Old 08-07-2016, 05:10 PM   #29
KoolBRZ
KoolBRZ's Avatar
Drives: Silver 2013 BRZ Ltd Auto 45,000 mi
I have an OFT, a Tomei/Gruppe-s UEL header, 2.5" overpipe, resonated 2.5" front pipe, stock midpipe, and 2.5" axle-back single muffler w/dual exhaust. I don't have much muffling, so my car can be loud sometimes, but not with my current tune. My startup is quiet and at a low rpm, even cold. I don't have a torque dip because I don't use valve overlap for higher mpg through internal EGR. My power curve is smooth because my AVCS tables have smooth transitions. My advice is to get an OFT, then tune it till you like it.
If I say yes, will that make you think I understand?
KoolBRZ is offline   Reply With Quote
The Following 3 Users Say Thank You to KoolBRZ For This Useful Post:
Arcainum (08-07-2016), Lantana frs (08-07-2016), WWFT86 (08-24-2016)
Old 08-07-2016, 09:30 PM   #30
RJasonKlein
RJasonKlein's Avatar
Drives: 2013 Scion FR-S 10 Series
If price is not your primary concern and you want gain the maximum horsepower and torque while converting the 'dip' into a 'bulge', go with an ACE Type A 4-2-1 350 catless header, EcuTek, and tune by Delicious Tune. Keeping it quiet will be a challenge, but your tune can be set to eliminate raised revs during cold-start, and if you use a resonated and catted front pipe (JDL Ultra Quiet) paired with one of the quiet exhausts (Invidia Q300), it'll probably work for you. Keep in mind that no cat-back exhaust will improve power, but the factory exhaust will sound pretty crappy with the header and front pipe, so you'll need to do the whole exhaust for it to sound pleasing.
There are cheaper solutions, but this addresses the issues you raised and will totally transform your car.
Last edited by RJasonKlein; 08-11-2016 at 08:20 PM. Reason: Corrected a typographical error.
RJasonKlein is offline   Reply With Quote
The Following 2 Users Say Thank You to RJasonKlein For This Useful Post:
AceHeader-MT (08-10-2016), WWFT86 (08-23-2016)
Old 08-08-2016, 06:58 AM   #31
RichardsFRS
RichardsFRS's Avatar
Drives: 2013 Pearl White 6MT
Keep your rpms high and dance on the clutch?
Back from bancation in Banopolis where I laid on the beach with a beer between my legs. I at night and ate at sun rise
RichardsFRS is offline   Reply With Quote
Old 08-08-2016, 02:11 PM   #32
JSube
JSube's Avatar
Drives: 2017 ISM PP BRZ
Eliminate the Torque Dip
RJKlein, I'm new to the forum, have a 2015 STI I'm considering selling for the upcoming BRZ (love RWD, lighter sports cars, big power not an end-all-be-all issue with me.) I looked at the ACE header, which could hang framed in an art museum, so I have no doubt about the quality. But is your recommendation for that specific piece that it significantly outperforms other well-made headers or that it's equal in performance and better made than any other?
JSube is offline   Reply With Quote
Old 08-08-2016, 09:46 PM   #33
steve99
Drives: FT86
Theirs no huge performance gain on these cars NA.
best results you will get with four simple mods
Good set of catless headers
tune (for e85 if you going E85)
E85 fuel
drop in air filter
that will get you arround 30 or so wheel hp over stock and eliminate torque dip.
after that you can spend a heap of money for little more gain and large increases in noise and raasp.
ACE are good headers and will produce better gains than most headers especially 91 fuel, bit better on 93, but once you go to E85 the extra gains are smaller compared to other headers.
have a read of the Basic bolt on Mods link below.
WWFT86 (08-24-2016)
Old 08-08-2016, 09:55 PM   #34
Lantana frs
Drives: 13 frs red
With Crawford intake spacers and 93 tune the dip is minor, more like a plateau. I would listen to what our Aussie contingent says. They seem to have these cars figured out.
Lantana frs is offline   Reply With Quote
Old 08-09-2016, 12:37 AM   #35
RJasonKlein
@JSube, welcome to our community! @steve99 pretty much nailed it - there's no magic bullet and only a few meaningful modifications you can make while staying normally aspirated. I recommended the ACE header because it outperforms other headers currently on the market and it's what I chose, but I prefaced it as a 'cost no object' recommendation. There's been a ton of dialog on this subject and there are solutions that provide meaningful bumps in horsepower and torque for less money.
Last edited by RJasonKlein; 08-24-2016 at 12:01 AM. Reason: Corrected a typographical error.
CSG Mike (08-10-2016), WWFT86 (08-24-2016)
Old 08-10-2016, 11:24 AM   #36
JSube
JSube's Avatar
E85 fuel
drop in air filter
Originally Posted by RJasonKlein View Post
@JSube, welcome to our community! @steve99 pretty much nailed it - there's no magic bullet and only a few meaningful modifications you can make while staying normally aspirated. I recommended the ACE header because it outperforms other headers currently on the market and it's what I chose, but I prefaced it as a 'cost no object' recommendation. There's been a ton of dialog on this subject and there are solutions that provide meaningful bumps in horsepower and torque for a lot less money.
Thanks RJ, Steve, Lan. I appreciate the responses and the welcome. Seems like every sportscar I've owned and joined forums for has one or two main issues that generate the most discussion and I guess I've found one of them for the BRZ! I'll read the bolt-ons link and start the process of learning about this engine. I'm enjoying the STI power a lot, but a light car with a great chassis is a really rewarding experience for me. Don't want to redesign the car, just get a little power bump and a nice exhaust note. But I'll do my research and have more questions when I get the car.
Old 08-10-2016, 12:57 PM   #37
KoolBRZ
KoolBRZ's Avatar
Another option is to go the same route as the 2017 models. Change the Final Drive from a 4.10 to a 4.30. Speed is measured at the wheels, so it wouldn't even affect the speedometer. It wouldn't increase the power, so much as give the power better leverage. There is a complicated formula for calculating horsepower per revolution of the tire. Changing the gearing increases the horsepower per revolution. The drawback on MT cars is having to shift sooner and more often, while on AT cars it's an advantage, since the AT can shift quicker and easier when the stretch between gears is closer. It also takes some of the strain off the engine/trans/driveline/diff, and puts it on the axles/wheels/tires. It's a seesaw. When one end comes down, the other end goes up, with the pivot point at the differential.
The Following 2 Users Say Thank You to KoolBRZ For This Useful Post:
Lantana frs (08-10-2016), Teseo (08-10-2016)
Old 08-10-2016, 07:33 PM   #38
steve99
Drives: FT86
If you have E85 fuel the best cheapest easyesy best bang for buck mods are
E85 fuel with tune
and drop in filter
you get 20hp and big reduction in torque dip with no pyhsical mods other than filter, thats with completly stock exhaust.
Old 08-10-2016, 07:40 PM   #39
Teseo
Drives: frs
You think 2017 FD will fit on 2013 model?
Old 08-10-2016, 09:17 PM   #40
KoolBRZ
KoolBRZ's Avatar
For a MT, yes. For an AT, no. A 4.88 or 5.71 would be better.
The Following User Says Thank You to KoolBRZ For This Useful Post:
Teseo (08-10-2016)
Old 08-24-2016, 11:47 AM   #41
WWFT86
Drives: 2017 BRZ Limited
Nope. the only answer is still get a Hellcat
I heard the Tesla ludicrous is woth looking into too
WWFT86 is offline   Reply With Quote
Old 08-24-2016, 11:56 AM   #42
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
You see the new P100D? 0-60 in 2.5 sec
Least harmful additives to eliminate crickets Muskokan Issues | Warranty | Recalls / TSB 46 05-07-2017 12:10 PM
Eliminate oil pressure switch? @Art_Mighty Engine, Exhaust, Transmission 13 09-17-2015 09:23 PM
The truth behind the option to dealers to eliminate the scion part Frstorm Scion FR-S / Toyota 86 GT86 General Forum 8 08-21-2013 03:37 AM
Best Method to Eliminate Sand ShoShin Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 6 07-29-2013 04:45 PM
Cheapest way to eliminate the torque dip allawd Engine, Exhaust, Transmission 42 04-24-2013 09:40 PM
