Old 06-18-2016, 08:17 PM   #1
phantasticity
Ricer
p2096 after headers install
I'm getting the code p2096 after install headers, o2 sensor is brand new from dealer so its not that. And when the CEL is on the car runs hella weird, it starts up hella weird too, feels like it gonna shut back down, which sometimes it does. And the RPMs dropping hella weird too. Can anyone help me out?
phantasticity is offline   Reply With Quote
Old 06-19-2016, 06:28 AM   #2
steve99
Drives: FT86
If you have not touched anything else then you likely have exhaust leak causing 02 sensor to see fresh air so ecu is setting lean code
http://www.obd-codes.com/p2096
How much force did you use to install o2 sensor ?
excessive torque can damage them
is sensor screwed in all the way so ring is seated.
if it tight run a M18 by 1.5 mm pitch thread tap through header bungs
did you use new exhaust gaskets
make sure both plugged in correct sockets
grey plug is primary (first) sensor
make sure your tune is correct, running a petrol tune on e85 will cause lean condition
Teseo (06-19-2016)
Old 06-19-2016, 07:04 AM   #3
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
You could have gotten a bad O2 sensor also. It happens.
guybo is offline   Reply With Quote
Old 06-19-2016, 07:26 AM   #4
Dream20b
Y u do dis?
did you install a tune?
Dat Hot Lava Doe
Clearly you have no clue what you are talking about. Everything you said was completely and utterly the ramblings of a babbling idiot regurgitating garbage from his mouth. Everyone here is now dumber from reading your post. Please die now.
Dream20b is offline   Reply With Quote
Old 06-19-2016, 08:27 PM   #5
RJasonKlein
RJasonKlein's Avatar
Drives: 2013 Scion FR-S 10 Series
This. My guess is hella no...
RJasonKlein is offline   Reply With Quote
The Following 3 Users Say Thank You to RJasonKlein For This Useful Post:
Brayden_23 (08-21-2016), celek (06-25-2016), Kestrel (06-22-2016)
Old 06-22-2016, 03:11 PM   #6
Kestrel
Kestrel's Avatar
Drives: 2015 Ultramarine FR-S AT
Hella
Sent from my SAMSUNG-SM-G900A using Tapatalk
Kestrel is offline   Reply With Quote
The Following User Says Thank You to Kestrel For This Useful Post:
Wayno (08-23-2016)
Old 08-21-2016, 11:50 PM   #7
phantasticity
Ricer
Originally Posted by Kestrel View Post
Hella
Duh fuck you know betch? I'm on Stg2 UEL e85. Nice facts. Funny you thinks your comment is useful.
The Following User Says Thank You to phantasticity For This Useful Post:
Kestrel (08-27-2016)
Old 08-21-2016, 11:51 PM   #8
phantasticity
Ricer
Not sure if sensors are messed up, but ill check them again tomorrow.
Old 08-22-2016, 11:39 PM   #9
RJasonKlein
Alright, so your car has a tune. What type header (brand, catted, or uncatted), front pipe (brand, catted, or uncatted), and FlexFuel kit (if equipped) are you running? Does your car throw the code when running pump gas or only with E85?
Your post catalyst readings are too lean on bank 1. Either you have inadequate fuel in the combustion chamber caused by a fuel delivery problem or a substantial vacuum leak, a failed or leaking O2 sensor, an inoperative catalyst, a leaking exhaust manifold gasket, a problem with your mass-air flow sensor, or an issue with your tune.
I'm asking partly so that I can try to help you and partly so you'll keep posting, because you talk funny.
Last edited by RJasonKlein; 08-23-2016 at 02:01 AM. Reason: Corrected a typographical error.
The Following User Says Thank You to RJasonKlein For This Useful Post:
JazzleSAURUS (08-23-2016)
Old 08-23-2016, 12:51 AM   #10
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
It's obvious you've not interacted with folks from NorCal much...
The Following 2 Users Say Thank You to mav1178 For This Useful Post:
JazzleSAURUS (08-23-2016), RJasonKlein (08-23-2016)
Old 08-23-2016, 01:32 AM   #11
Songha
Songha's Avatar
Drives: 2013 Scion FRS
I'm running stage 2 uel and randomly threw a code driving to work few weeks ago. Ran weird. I just reflashed the tune and drove it easy for a bit and it went back to normal.
2013 Scion FR-S | 6-MT | Raven Black | Performance Mods: Invidia N1 Catback, Invidia Catless Frontpipe, BC Racing Extreme Lows Coilovers, 1320 Performance UEL Catless Headers, 1320 Performance Overpipe, OpenFlash Tablet (Stage 2 UEL, 93 Oct. tune), Whiteline Front Swaybar, Whitelight Adj. Front Endlinks | Asthetic Mods: DS Style Front Lip, Rocket Bunny style flares, F1R F21s | MY BUILD THREAD!
Songha is offline   Reply With Quote
Old 08-23-2016, 07:01 AM   #12
steve99
Drives: FT86
If you ever get CEL code its best to read it and see what it is, rather than just clear it.
In most cases it will give you a clue to problem, they don't usually pop up unless their is a problem
Old 08-23-2016, 12:53 PM   #13
renfield90
The Stig's German cousin
Shhh. Don't tell them to actually fix their stuff. We need more parts cars in junkyards.
The Following 2 Users Say Thank You to renfield90 For This Useful Post:
JazzleSAURUS (08-23-2016), steve99 (08-23-2016)
Old 08-23-2016, 01:15 PM   #14
mav1178
mav1178's Avatar
@RJasonKlein
https://en.wikipedia.org/wiki/Hella
P2096, Completely stock. cbell7492 Issues | Warranty | Recalls / TSB 6 01-31-2016 10:10 PM
Headers and over pipe install question Carnewbee Engine, Exhaust, Transmission 5 10-14-2015 03:04 PM
P0102, P0113, P2096 Engine code Oburn Engine, Exhaust, Transmission 24 09-22-2014 04:30 PM
CEL Code P2096 w/ exhaust only ShutterSpeed Issues | Warranty | Recalls / TSB 7 12-03-2013 12:59 AM
Headers install help!!! Blackout808 Engine, Exhaust, Transmission 9 04-02-2013 05:27 PM
