Old 08-19-2016, 11:06 AM   #7449
sam69
Drives: GT 86
Originally Posted by Dream20b View Post
Exciting news hopefully coming tonight. Car is going on the dyno for a tune. 75mm pulley on the 335 kit. built motor, shooting for 400.
flex tune
Looking forward to the results on this
sam69 is offline   Reply With Quote
Old 08-19-2016, 09:27 PM   #7450
Dream20b
Y u do dis?
244/214 on 93, heartbreaker dyno. This with the 80mm pulley 9:1 compression, minimal timing advance. didn't get the e85 tune in yet.
Dat Hot Lava Doe
Clearly you have no clue what you are talking about. Everything you said was completely and utterly the ramblings of a babbling idiot regurgitating garbage from his mouth. Everyone here is now dumber from reading your post. Please die now.
Dream20b is offline   Reply With Quote
The Following User Says Thank You to Dream20b For This Useful Post:
riboyster (08-20-2016)
Old 08-19-2016, 10:48 PM   #7451
Dipstik-sportech
Dipstik-sportech's Avatar
Hurry up and put the screws to that 335 kit I wanna see what it will top out at.
The Following User Says Thank You to Dipstik-sportech For This Useful Post:
Dream20b (08-20-2016)
Old 08-20-2016, 02:26 AM   #7452
Anal0g
Drives: Subaru
Anyone know if the CARB EO would work for 2015-2016 ? D-719 explicitly lists 2013-2014 as being exempt. AFAIK, there weren't any significant changes between 2013-2014 and 2015+ and so I'm curious to know if owners with 2015+ models would fail inspection w/ this kit installed.
Anal0g is offline   Reply With Quote
Old 08-20-2016, 02:46 AM   #7453
riboyster
riboyster's Avatar
Drives: 2013 Scion FRS
I could be wrong, but I think it would mostly be based on the tune used. IIRC Delicious Tuning has CARB certified stage1 tunes.
Keep in mind that this is barring any change to the system aside from the SS210 twin screw.
I was wrong, but it is available through Innovative: https://www.delicioustuning.com/node/151
ScreamingElectron - SnakeShit
riboyster is offline   Reply With Quote
Old 08-20-2016, 02:59 AM   #7454
stockysnail
Just the tip
stockysnail's Avatar
Are the numbers low because of the low compression? Moto-East were getting 300hp 260tq on the 85mm with a stock engine with the 335.
Old 08-20-2016, 07:45 AM   #7455
Dream20b
Y u do dis?
Likely.
Dat Hot Lava Doe
Old 08-20-2016, 10:58 AM   #7456
chargedup
Drives: SC BRZ
Installing a boost gauge today, can I tap in to the bypass line? It seems like the easiest to work with. Otherwise which line should I tap? Meh, guess i'm tapping the MAP
chargedup is offline   Reply With Quote
Old 08-20-2016, 01:03 PM   #7457
nmastereal
There is a boost sensor port on the back of the supercharger.
nmastereal is offline   Reply With Quote
The Following User Says Thank You to nmastereal For This Useful Post:
chargedup (08-20-2016)
Old 08-20-2016, 01:07 PM   #7458
chargedup
Drives: SC BRZ
Saw that as well- well not physically..
which one? pretty crowded back there
Old 08-20-2016, 07:14 PM   #7459
stockysnail
Just the tip
Small silver one in the middle higher than the rest. Be careful and don't strip the head. I stripped mine. It's super easy to strip the allen head, thus making me not install a boost gauge. ;(
The Following User Says Thank You to stockysnail For This Useful Post:
chargedup (08-25-2016)
Old 08-20-2016, 08:48 PM   #7460
Anal0g
Drives: Subaru
Originally Posted by sales@delicioustuning.com View Post
As stated before, there will not be any issue obtaining a Sprintex/Innovate supercharger kit in the US, nor will there be any issue obtaining a CARB tune. It is not my information to disclose the who, what, when, and how much, but I can tell you all that much. This kit will remain available in the US, and a CARB approved tune will remain available with it.
Sincerely,
Zach
Not sure if what Zach said a while back is still applicable, but if it's still the case then tune wise I think people w/ 2015+ are covered. What I'd like to know is 2015+ owners w/ the 210 kit would fail simply because of the technicality of the MY not being listed on the EO.
Old 08-20-2016, 11:44 PM   #7461
riboyster
riboyster's Avatar
There ya go then. Sounds more like a question for Sprintex/Innovate!
Old 08-21-2016, 01:32 AM   #7462
camelflage
Drives: pinto power
anyone get to 240/250hp on a 210 unit without e85? for some reason 335i drivers want to be fucbois around me lately and i know at 200 ive still got nothing for them..
camelflage is offline   Reply With Quote
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 11:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 07:15 PM
Not another need to drive topic Sargy Mid-Atlantic 5 11-27-2012 01:18 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-18-2012 12:38 AM
Can you close the topic please? Standardsuspension Brakes, Suspension, Chassis 14 06-26-2012 06:14 PM
