#211 |
Road-hole
Drives: 2013 Whiteout FR-S
I've worked on diesels...
| The Following User Says Thank You to Jaden For This Useful Post: | killboy (08-12-2016) |
#212 | |
Drives: Nissan Versa
[ame="https://www.youtube.com/watch?v=HmscSzFurwg"]Lotus[/ame] All these seem to make crazy power albeit very complex. But these cars made 480 hp, 500 hp and 700 hp respectively in engines under 2 liters. And the dyno curves probably look insane too. |
| The Following User Says Thank You to JustAnEngineer For This Useful Post: | killboy (08-12-2016) |
#213 | |
Drives: 2013 BRZ World Rally Blue
| The Following User Says Thank You to the_one_mike For This Useful Post: | JustAnEngineer (08-14-2016) |
#214 |
Road-hole
Here is a 2.0 lt running 9's...
http://www.fitfreak.net/forums/other...73-140mph.html
2.0 liter compound boost running 9's at 37 psi.. There's also one I can link to that was running 8's at only 600 hp because of the torque curve... Jaden |
| The Following User Says Thank You to Jaden For This Useful Post: | JustAnEngineer (08-15-2016) |
#215 | |
I don't want to seem like I'm taking a shot at any manufacturers here, because I'm not, but I suspect that quite a bit of the problems that WTF ran into during the build was relative to the supercharger equipment... Is the sprintex the only twin screw S/C out there? I know there are other PD superchargers available, but roots and TVS blowers won't further compress a charge like a lysholm style would... It seems like the supercharger is certainly the key aspect of making a successful and stable compound boost on the twins. |
#216 | |
Also, correct me if I'm wrong I just learned the difference between the two but it seems you're advocating a lysholm style which is a twin screw which the sprintex supercharger is, which is what they used? So how come you said that's where they had a problem? Not trying to argue, just trying to learn some stuff.
I know a few things about a couple things
#217 | |
The Sprintex seems to be reliable on its own, but there are commonly reported O ring failures, and something leads me to believe that introducing a turbocharge and subsequently increasing the internal pressure of the unit exponentially led to reliability problems in delivering a consistent boost. |
| The Following User Says Thank You to the_one_mike For This Useful Post: | JustAnEngineer (08-17-2016) |
#218 |
Road-hole
we've kind of completely derailed this thread now.lol
compound boost is doable with any style FI...
a positive displacement s/c would be best because of the linear boost. The way a pos displacement s/c boosts allows for max PR from very low rpms. So long as it is the secondary, you don't have to worry about air flow. The key to a successful compound boost setup is having the right primary FI system. You have to know how much boost it's going to be running and choose a system that has enough airflow at the boost level that that specific system will provide. Oh wow. this just gave me an idea... Use a huge procharger as a primary and then a smaller turbo as the secondary. You control total boost on the turbo and the S/C will give a finite amount of boost based on Rpms... The only problem with it is at lower rpms the turbo will be providing more boost. That might still be better. Time for some espeerimentin' Jaden p.s. it is possible for the air to blow by the seals on the s/c in a turbo fed into a pos. disp. s/c setup like the ops and make it act funny or get less boost, so sizing of the s/c could potentially come into play, and or the pressure capability of the seals. |
| The Following 2 Users Say Thank You to Jaden For This Useful Post: | DustinS (08-16-2016), JustAnEngineer (08-17-2016) |
#219 | |
This allows for a rather low inlet charge from a small turbo to be amplified significantly on a linear plane, while another style blower would also provide the power on a linear plane but just "add" its own boost to the provided charge coming from the turbo as opposed to exponentiate it as a twin screw would. As I said, my understanding of this could be wrong (I hope it is, honestly, for the sake of options for blowers) but I'm not sure here. Admittedly, this is fairly new to me as I've really only gotten interest in this since picking up my BRZ in April. |
#220 | ||
Drives: 1FRS, 1 BRZ, 2S2000s, Evo8, Dak.R/T
To quote a company info page that makes compound boost setups for Mustangs: Quote:
http://www.hellionpowersystems.com/i...boost-resource
| The Following 2 Users Say Thank You to killboy For This Useful Post: | JustAnEngineer (08-17-2016), the_one_mike (08-17-2016) |
#221 | |
Road-hole
no you're incorrect...
The most common uses are multiple centrifugal based turbos... Jaden p.s. Also, you can't use a small turbo as the primary. The primary FI system pulling from ambient has to be able to provide all of the air flow you need at the boost level it will be running at individually. That's why I'm now looking at using a large centrifugal S/C as the primary because their compressor maps have such a broad range of flow in general and great flow at lower boost levels, I think it will be ideal with the more linear increase for compound charging. Last edited by Jaden; 08-17-2016 at 01:00 PM. |
#222 | |
Also, Re: your p.s. ... I'm not sure what you are referring to as "primary." To me, the primary in the instance I described is still the twin screw, being as the turbo would be relaying a charge to it. The other way around and there is basically no point as you would still be dealing with turbo lag -- you would just be forcibly overspooling a turbo with a positive displacement charge. Maybe this is why you have suggested a large turbo so many times. |
#223 | |
| The Following User Says Thank You to the_one_mike For This Useful Post: | killboy (08-18-2016) |
#224 | |
Road-hole
hmm...
Sequential turbos a large one pulling from ambient feeding into the inlet of a smaller one is the most common. They are done in diesels all the time. The confusion on which is the primary and secondary comes from whether you're talking about how the turbos are powered versus the charge. When I'm referring to the primary I'm talking about the FI system pulling from ambient i.e. ~14.7 psi for sea level. The primary pulls from ambient and compresses that charge the charge then goes into the secondary at 14.7(or whatever ambient is) * whatever the pressure ratio is for the boost level it provides. This is the important part. It now becomes a closed system. You can't get any more air than what is provided by the primary. So the flow rate of the secondary charge system doesn't matter, only the PR. Now in a compound turbo, (Large turbo going into a smaller turbo) the smaller turbo is fed from the exhaust FIRST so that's where the confusion on what is the primary comes in. It's fed first because it will spool faster. Controlling the boost on a compound turbo into turbo setup is paramount. It's easier with a s/c because the boost is finite for the s/c and you only control total boost output with the turbo. You don't want a big turbo as the secondary because flow doesn't matter for the secondary, just p/r so you want it to spool as quickly as possible. Here's why I think that a big s/c as the primary might work better. Take a look at the compressor maps ogerf a big s/c like an Si trim Vortech You'll notice that the airflow is broad as fuck. This means that if you use it as a primary even at low boost you have TONS of airflow. Since you're using a quick spooling turbo as the secondary, you can use higher boost at lower rpm and slightly lower boost at higher rpm and have a hugely broad torque curve, which is the whole point of a compound boost setup. Jaden Last edited by Jaden; 08-18-2016 at 12:41 PM. |
| The Following User Says Thank You to Jaden For This Useful Post: | sato (08-18-2016) |
| Tags |
| streetfx, supercharged, twincharged, wtf86 |
| JET86 Twincharged complete build !INSANE! | jet86 | Member's Car Journals | 97 | 08-05-2016 01:15 PM |
| Dezoris | FR-S Build | Supercharged & More | Dezoris | Member's Car Journals | 329 | 03-21-2016 05:48 PM |
| Supercharged Rocket Bunny Widebody Conversion Build Thread | RWDRIFT | Member's Car Journals | 278 | 01-06-2014 01:12 AM |
| Supercharged Forgestar Rocket Bunny Widebody Scion FR-S | RWDRIFT | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 102 | 03-27-2013 07:48 AM |
| Supercharged GT 86/FR-S/86 vs. Turbocharged BRZ | switchlanez | Scion FR-S / Toyota 86 GT86 General Forum | 61 | 12-20-2011 12:16 PM |
