#85 | |
Drives: FR-S Whiteout
My own experience with a chromoly triangulated strut bar is that while u do get a little more feel it increases the car's propensity to understeer with all else equal. I believe this is the effect of stiffening up the front strut mounting that there is less 'give' in the chassis when the suspension is compressed with force of high g cornering. Although this car already has really really good ridgidity as is. The strut bar will make a bigger difference on a heavily sprung car with very sticky tires. It does not do much increasing steering feel, per se, in that it does nothing at all to stop the steering rack bushings from flexing during steering inputs. |
#86 | |
Because compromise ®
Drives: Red Herring
For me the TiC alloy bushes were a waste of money. Maybe because the car had only 6k kilometers on it when the bushes were installed. Aftermarket coilovers and front lca bushes had already been fitted as well. The tower bar was the last mod I made to the chassis.
| The Following User Says Thank You to Captain Snooze For This Useful Post: | solidONE (08-18-2014) |
#87 |
Drives: GT86
Since starting this thread I perhaps never gave a proper summary, but the TiC steering rack bushings together with some toe and the Grimmspeed strut bar and both gave me some subtle but real improvements over stock even on "normal" tires. Perhaps subtle but then again any further increase in grip information is very valuable, especially if you drive new ground all the time driving cross country on small twisty roads.
Anyhow, happy with my setup now (TiC, GS strut bar, alignment, subframe inserts, superlight wheels) |
| The Following User Says Thank You to Trettiosjuan For This Useful Post: | solidONE (08-18-2014) |
#88 | |
Drives: FT86
Was a nice car smooth quite good power handled well, but felt like the computer was driving it not you . Quite happy with BRZ after getting decent tyres and a 16mm rear bar to get rid of the initial understeer & front brace and camber bolts. |
#89 | |
Drives: GT86
PS: while not strictly steering feel related, also have the 16mm and camber bolts, really makes the car balanced on steering input only
#90 |
Drives: 2016 Ablaze Scion FR-S
Apologies for reviving an old topic, but I was wondering about everyone's opinion on steering feel.
I have a '16 FRS, and I previously drove a lowly 2001 Civic and have also been in a 2010 Cooper S. While I love the directness and immediate response of the FRS steering, I can't help but feel that it is a bit...numb. In my Civic the steering would sort of wobble around a bit on railway crossings, small ruts in pavement, and I quite liked this feeling of connection. The Cooper S would do the same, at parking speeds even the steering will jiggle around depending on the surface. I feel like in the Mini, I could 'read' the texture of the pavement quite well too. I think at higher speeds the FRS's steering instills the most confidence, but after reading so much about journalists loving the steering feel of the FRS, I am slightly let down by what I am (not) experiencing. Am I being realistic for wanting the steering to shimmy in your hands more? |
#91 | |
/dev/null
Drives: Uphill
Ideally, I'd like a little more tactile feedback from the road in my '13 GT86 too. It would sacrifice some stability around corners on uneven surfaces at high speed, though. Vibrations, jiggles and shimmying would mean loss of traction and oversteer. I think there will have to be some trade-off to be made, and I believe they got it just right. Last edited by Sarlacc; 08-16-2016 at 12:20 AM. |
| The Following User Says Thank You to Sarlacc For This Useful Post: | Ultramaroon (08-16-2016) |
#92 | |
Also, I just realized that both cars you mentioned are FWD which all exhibit another phenomenon called torque steer. Are you maybe just experiencing the joy of separating the steering wheel from the gas pedal?
| The Following User Says Thank You to Ultramaroon For This Useful Post: | Sarlacc (08-16-2016) |
#93 | |
| The Following User Says Thank You to Tcoat For This Useful Post: | Sarlacc (08-16-2016) |
#94 |
Drives: MY11 Maxima 350st, MY15 BRZ
I've read a few posts mentioning the addition of a strut brace. I fitted the flexible STI strut brace and though I sadly have no experience with other brands, the STI one really settled the ride down and provided a firmer and altogether sharper feel. Being flexible the design apparently allows some movement in areas where some flex is not a bad idea and counters movement in the directions need to be. This apparently results in a more supple ride and helps with communication. I further braced the doors via the TRD door stabilisers, which seems to help the car corner in a sharper and more confident manner. Note I'm still on stock wheels, tires and suspension otherwise.
I'm actually really enjoying the stock tires, but am thinking of lighter wheels down the line to help improve feedback, as also spoken about in this thread.
MY15 CWP A/T BRZ | Leather heated seats | STI CAI filter, A/T leather shifter, strut brace, V-brace, draw stiffener, battery tie down, Radiator cap, Oil cap, push start button | TRD door stabilizer | YoSpeed STI console garnish | Pioneer AVIC-F70DAB + Rev-camera, TS-WX710A sub | JL speakers, Amp | TOMS' Clear Brake Lights | Cusco 4.556 FD | Driveshaft Shop aluminum shaft | Tein FlexZ, EDFC AP+GPS | Crawford BPB
#95 |
Drives: '15 BRZ RA
You can try also to change the bolts in the steering linkage with larger ones. Personally, I'll do the change this week with the normal service. They are saying that it gives you a better steering feel.
New bolts are the following: ![]() Old bolds are located here: ![]() Replacement bolds are installed here:
| The Following User Says Thank You to nikitopo For This Useful Post: | johan (08-16-2016) |
#96 | |
Drives: 2014 BRZ
Bumpsteer is undesirable because the car changes direction with no steering wheel movement so you can't feel it. It occurs because the steering linkage is not correct such that when the wheel goes over a bump, the linkage causes the wheel to steer without any input from the steering wheel. You can increase steering feel by replacing bushings in the linkage with stiffer bits. I've also found that a stiffer strut brace and the Perrin steering rack lockdowns give more feedback in the steering wheel.
| The Following 2 Users Say Thank You to Sleepless For This Useful Post: | Racecomp Engineering (08-16-2016), Ultramaroon (08-16-2016) |
#97 |
Drives: Satin White BRZ Limited
I am currently on Tein Flex Z and Advan AD08 Tires. Steering feels mostly sharp with good feel. When it is really hot out (100 degrees +) I notice the steering feels lighter and more numb. I know increase in tire pressure can cause a lighter steering feel,but it is kinda strange that the steering gets a little numb in the heat. I am attributing this to the rubber bushings in the front suspension that probably turn to marshmallows in high heat. I have since bought energy suspension Poly front LCA bushings and steering rack bushings. I am going to get these installed at the end of the month and let you all know how it feels.
#98 | |
edit: oops I missed the whole point. "Kickback" Ok, I can go with that.
| power steering feel adjustment | brillo | Engine, Exhaust, Transmission | 29 | 11-06-2017 04:41 PM |
| Feel sorry for guys in LA | Pscylo | Southern California | 16 | 08-21-2012 11:26 AM |
| does rwd LSD feel the same as fwd lsd? | pr086 | Scion FR-S / Toyota 86 GT86 General Forum | 6 | 07-13-2012 09:04 PM |
| Steering Wheel Feel | ap5512 | BRZ First-Gen (2012+) — General Topics | 8 | 12-08-2011 12:16 PM |
| Stock suspension adjustability? | #87 | Scion FR-S / Toyota 86 GT86 General Forum | 4 | 01-02-2010 05:36 PM |
