Old 08-15-2016, 12:45 AM   #7435
riboyster
riboyster's Avatar
Drives: 2013 Scion FRS
Preliminary testing using water meth injection kit that I made myself. Here are some runups during which I engage the system, and on one of them you can actually hear my boost build a little. Tests were run using OFT to maintain throttle %.
ScreamingElectron - SnakeShit
riboyster is offline   Reply With Quote
Old 08-15-2016, 09:21 AM   #7436
Rich196
Drives: GT86
Have you got more information on your WMI kit? Boost will build slightly as the water seals the supercharger completely. You may see up to 0.2bar increase.
Rich196 is offline   Reply With Quote
Old 08-15-2016, 12:24 PM   #7437
riboyster
riboyster's Avatar
What kinda info do you need?
Old 08-15-2016, 02:46 PM   #7438
Rich196
Drives: GT86
Where are you injecting?
Size of nozzle?
% meth?
What are using to control the injection?
Old 08-15-2016, 06:56 PM   #7439
brybot
Drives: 13 DGM BRZ 6MT
Suh dudes. I was able to purchase a used 210 non-IC kit from another user here. It's been with Jon Bond for the last three months (seems like they've having some shop troubles), but I've had plenty of time to save and research in the meantime. Currently running OFT+OFH, so either the tablet or both will need to go for a new tune, likely through Moto East. Anyone have any insight on whether I ought to keep the OFH or replace it with something else?
Also, what maintenance should I be doing once it goes on aside from checking the oil with the SC level?
Just looking to see if I've missed anything. I DD the car and expect to do so with little to no track use for the next three years. Want reliability over big power for the foreseeable future. Thanks.
brybot is offline   Reply With Quote
Old 08-15-2016, 08:07 PM   #7440
Rifle
EX-86 Supercharged God
Rifle's Avatar
Drives: '16 Series.HyperBlue BRZ
Go with ECUTEK.
Oil every other oil change, belts every 30k.
Have fun.
Sprintex 210 Supercharged HyperBlue BRZ "HI MOM"
295WHP/220TQ
Rifle is offline   Reply With Quote
Old 08-16-2016, 12:07 AM   #7441
riboyster
riboyster's Avatar
Size of nozzle?
% meth?
Snow performance 40100 nozzle. 250psi. Probably about 30% isopropyl, household light switch
Old 08-16-2016, 07:05 PM   #7442
jwvand02
Drives: 2013 SWP BRZ Limited
To add to what @ryfle said - use quality belts. I just had one shred on me.
jwvand02 is offline   Reply With Quote
Old 08-16-2016, 08:24 PM   #7443
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
lol light switch.
You gonna switch to a pedal mounted one or run a boost trigger when you finalize the system?
Old 08-17-2016, 02:41 AM   #7444
riboyster
riboyster's Avatar
Originally Posted by continuecrushing View Post
lol light switch.
Yeah originally the idea was pedal mounted. Still in the early days though. Still lots of logging to do.
Old 08-17-2016, 05:16 AM   #7445
Edsc
Drives: Gt 86
Hi, i am new here and it seems to be too long for me to read through all the information here. Please allow me to ask some simple question.
what is the output figure for s210 non intercooled with the 80mm pulley and intercooled with 75mm pulley ? As from my survey from the official website claims that the intercooled with 69mm could produce 270whp.
No info for the 80mm and 75mm.
Most tuner around me does not recommend sprintex to me yet they din mention much on what kind of problem from it.
Thanks everyone here.....
Edsc is offline   Reply With Quote
Old 08-17-2016, 10:20 AM   #7446
jwvand02
Intercooled with the 69mm pulley can climb to 280+ if you use E85, depending on how you tune it.
Old 08-17-2016, 11:13 AM   #7447
stockysnail
Just the tip
stockysnail's Avatar
Here's a link to my spread sheet I've posted a few times in this thread that gives torque and horsepower figures based on what people have said:
https://drive.google.com/open?id=1Zn...PpWOBM4vKUkfdA
Old 08-18-2016, 07:53 AM   #7448
Dream20b
Y u do dis?
Exciting news hopefully coming tonight. Car is going on the dyno for a tune. 75mm pulley on the 335 kit. built motor, shooting for 400.
flex tune
Dat Hot Lava Doe
Clearly you have no clue what you are talking about. Everything you said was completely and utterly the ramblings of a babbling idiot regurgitating garbage from his mouth. Everyone here is now dumber from reading your post. Please die now.
Dream20b is offline   Reply With Quote
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
