Old 08-12-2016, 02:23 AM   #113
BigFatFlip
sleep, drive, eat, repeat
BigFatFlip's Avatar
Drives: '13 BRZ, '12 Outback
Originally Posted by VeloxEric View Post
We are finally getting close to releasing our AOS that has been in development for a long time. It's been proven on NA and moderate turbo'd cars now over 3 years. Below are some preliminary pictures of CAD and raw billet.
Very cool design Eric. Is that the "baffling" for the AOS? I really like how the fins act as diverters to drain.
Old 08-15-2016, 02:35 AM   #114
VerusEric
VerusEric's Avatar
Drives: BRZ, STI, GT350R, Supra, 987.2
Yes, that is the baffling.
More photos of the first few units being assembled are below. Installed the first unit on my car as well over the weekend for the install manual(s).
Anodized fittings
Cap with coalescent filters
Prototype unit showing that the filters are removing oil from the airflow, on both sides of the PCV system.
Installed photos
We ordered production on our rear spat design as well, so sharing some images of the final design we went with. The unit will be made from 2x2 twill carbon thermoplastic and bolt to existing holes in the bottom of the car.
We finalized the PERRIN performance WRX gurney flap analysis and posted up a blog about it. ANSYS really is pretty neat, we're looking forward to learning more and continuing developing our skills and products using it!
http://www.velox-motorsports.com/#!W...f26d54f732510c
Stock Body
PERRIN Gurney
Thanks,
Eric
VerusEric is offline   Reply With Quote
The Following User Says Thank You to VerusEric For This Useful Post:
M1K3 (08-15-2016)
Old 08-15-2016, 08:07 AM   #115
Pat
Pat's Avatar
Drives: 2023 BRZ
Cool stuff, Eric, but the last couple images don't look like a BRZ to me. Is the flap also usable on BRZs?
Old 08-15-2016, 08:12 AM   #116
15limited
15limited's Avatar
Must be the wrx version pictured, however there is a gurney flap available for the BRZ as well.
Perrin Transmission Bolt, Drift Button,Intake Tube, Radiator Hoses, Engine Mounts, Gurney Flap Diode Dynamics Always On Module OLM 3k HID Foglights GCS Smoked Side Markers Motul Gear 300/300 V OE Acantara arm rest Password JDM Dry Carbon rear diffuser Rally Armour Mud flaps H.I.C side & rear visor Gruppe-S UEL header/OP HKS Front Pipe Leg Sport Cat Back Koyorad aluminum radiator Wheelhaus CF low pro 3rd brake light Toms JDM Clear Tail Lamps
15limited is offline   Reply With Quote
Old 08-15-2016, 10:30 AM   #117
VerusEric
VerusEric's Avatar
You're correct, I amended my post. Just wanted to share a cool blog (to us) about an analysis we recently performed. It's for the 2015+ WRX.
Old 08-15-2016, 12:01 PM   #118
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
Stock Body
PERRIN Gurney
Thanks,
Eric
Did they install something else on the rear bottom? Cuz bottom airflow is different as well... or that gurney changes the airflow of the bottom as well?
Old 08-15-2016, 12:36 PM   #119
VerusEric
VerusEric's Avatar
That is correct. Just how a gurney flap changes the flow under a rear wing, it does the same for a car.
Old 08-15-2016, 12:39 PM   #120
ichitaka05
Site Moderator
ichitaka05's Avatar
Huh, never knew this. Thanks for the info
rookie (08-21-2016)
Old 08-23-2016, 11:23 AM   #121
VerusEric
VerusEric's Avatar
Still working on getting the 1300s dialed in, at very low pulse widths the injectors have a hard time injecting precise amounts of fuel. It's significantly improved already with very few hiccups, thinking after I run some 91 through it and hit it with a few more flashes she'll be near OEM driveability. Anyway, here's a video below of the car idling just on port injectors, these things are LOUD! First time I fired the car up with the new injectors I thought the engine was knocking at first.
Installed our slanted hood louver design on my car for some product photos. Some people did not like the looks of our initial louvers, so we redesigned the louver detail.
-These are prototypes, wickers are not installed because I didn't have any at the time of install.
-These fit in the same holes as the previous design.
-I need to clean up the louver cut yet, which is why you see the white peaking through.
-The logo is a vinyl sticker, which we are including with kits moving forward for those that want to place it on the louvers.
-They only look different close-up, far away they look roughly the same as the previous design.
-We assume similar results, potentially a bit less evacuation since they are slanted.
Small louver comparison
Large louver comparison
Been doing a ton of assembly lately, whether that hardware or actual product. Here are some photos of the AOS going together!
Each mesh ball gets a sonic cleaning before being installed into the cans for half an hour.
Sonic cleaned stainless mesh, nestled in its final resting place in the AOS
Coolant passage port uncovered
Coolant banjo bolts installed. Came out better than I had hoped!
(3) fully assembled units
Thanks,
Eric
The Following 2 Users Say Thank You to VerusEric For This Useful Post:
15limited (08-24-2016), DAEMANO (08-23-2016)
Old 08-23-2016, 12:46 PM   #122
icebär
icebär's Avatar
Drives: Toyota GT86
Nice BRZ. Love the whole Aerodynamik Thing witj the diffusor, Spoiler and so on.
Hope to get some of your Parts for my Next years Project BRZ Facelift.
Keep on rocking. :-)
icebär is offline   Reply With Quote
The Following User Says Thank You to icebär For This Useful Post:
VerusEric (09-12-2016)
Old 09-15-2016, 10:46 AM   #123
norcalpb
norcalpb's Avatar
Any updates on those sweet rear spats??
Old 09-15-2016, 07:09 PM   #124
Chenjovi
Drives: 2012 GT86
+1 for an update request! pretty much have the credit card ready to go as a package deal with the rear diffuser!
Chenjovi is offline   Reply With Quote
Old 09-16-2016, 10:42 AM   #125
Traktor
Drives: Subaru BRZ Limited
What is the diameter of that CF driveshaft?
Traktor is offline   Reply With Quote
Old 09-16-2016, 10:45 AM   #126
VerusEric
VerusEric's Avatar
Sorry for the lack of updates, been a crazy few weeks recently. Should have some new updates for the car shortly .
They are coming shortly, taking a bit longer than we wanted to produce but they're still on their way. Hoping next few weeks.
It is approximately 80mm, 3.125".
Thanks,
Eric
Verus Engineering Rear Wing Development VerusEric Tracking / Autocross / HPDE / Drifting 203 07-05-2021 09:15 AM
FRS / BRZ Intake Manifold - Development Thread - FT-86SpeedFactory by Velox FT-86 SpeedFactory Engine, Exhaust, Transmission 712 12-11-2018 10:13 PM
Hancha BRZ/FR-S/GT86 Aero Parts Development Thread Hancha Group Cosmetic Modification (Interior/Exterior/Lighting) 57 03-24-2014 05:40 PM
Raceseng | Development FT86 | Build Thread Raceseng Member's Car Journals 17 06-06-2013 09:22 AM
