Old 08-12-2016, 11:16 PM   #71
Originally Posted by pfaffendorn View Post
Thanks for the reassurance. I've been driving the car only seven months, so some things are still new to me. The noise in the rear started out almost undetectable, and has become louder over time, which made me suspicious. The next service isn't too far off -- I'll relax for now and have it looked at when the time comes.
I'll even guess that it didn't change, you did. You're becoming more confident accelerating through turns so it's grabbing harder.
Old 08-13-2016, 02:42 AM   #72
Originally Posted by andrewtgg View Post
How do you manage to get the power cut just changing lanes? I've read a couple people saying that has happened to them, but it has never happened to me before.
It can happen very easily just running snow tires on dry pavement. And yes, even with the 5-second disable VSC (e-diff, whatever) kicks in with the slightest wheelspin in snow, ice, or most frustratingly, standing water.
Old 08-13-2016, 02:12 PM   #73
justatroll
justatroll's Avatar
Drives: Full race 4cyl boxer
I am beginning to think different cars have different levels of sensitivity.
In mine I have to REALLY be acting like a jackass to get the system to step in on the street on dry pavement.
I think it also gives us bad habits. If I accelerate as hard as the car is capable of when leaving a light making a left turn, the system blinks once telling me it intervened to keep the ass from going out, but passengers dont even notice unless they are looking at the dash. (Its not a violent intervention).
Doing that in any of my Supras would have left me in the intersection backwards.
Arguing with an engineer is like wrestling with a Pig in the mud. You are never going to win and after a couple of hours you realize that he likes it.
justatroll is offline   Reply With Quote
Old 08-13-2016, 03:05 PM   #74
Possibly a matter of calibration. IIRC it's quite a process.
I've noticed a few modes of intervention. It first pulls throttle and will do so without notification. I have noticed this most when driving in the wet. It also feeds out throttle at its own pace when in a turn. The 5-second push has no effect on this. Pedal dance cuts it.
Then there's the braking intervention that happens when it senses single-wheel loss of traction. In most cases I agree if that kicks in, sure, the driver could probably use a reality check. However, last winter I could swear it tapped the odd rear wheel brake and didn't give me the blinky light. This also was with the 5-second push.
I just wish they would publish the specs in detail. There is a lot going on all the time.
justatroll (08-13-2016)
Old 08-13-2016, 10:52 PM   #75
gravitylover
You know how you get those deep grooves, especially in the summer, in the right lane where heavy trucks tend to travel? When you accelerate out of that lane and over the hump sometimes a wheel lifts for a second then bounces as it lands. This can be enough to make it happen and if somebody is coming up on you they don't expect you to slow down suddenly when you were being aggressive. So can bumpy on-ramps if you're gettin' after it and then the road goes to shit.
The Following User Says Thank You to gravitylover For This Useful Post:
andrewtgg (08-14-2016)
Old 08-13-2016, 10:58 PM   #76
brz11b
Drives: United States
im lazy so the fact i have to turn it off everrtime i get in the car is to much work. so i just leave it on 99% of the time.
brz11b is offline   Reply With Quote
Old 08-14-2016, 12:40 AM   #77
andrewtgg
andrewtgg's Avatar
Drives: Release Series 1.0
that seems scary, how long do you lose power for?
andrewtgg is offline   Reply With Quote
Old 08-14-2016, 01:00 AM   #78
daiheadjai
daiheadjai's Avatar
Drives: 2003 S2000, 2008 Fit
People were able to commute to work before there were such things as seatbelts too. Is that a sufficient argument to say that we should not use them now? I mean they are kind of a pain in the ass...
And those air bag things have been known to kill you!
In fairness, this isn't a Honda forum and I don't think we have Takata airbags in our cars.
Too soon?
daiheadjai is offline   Reply With Quote
Old 08-14-2016, 09:23 PM   #79
Vracer111
Vracer111's Avatar
Drives: '13 Nissan Frontier (4.0L 6spd 2WD)
Driven on street with button held down on startup to 'disable' TC and VSC systems, whether wet or dry. I especially make sure the systems are 'off' in the wet. The systems seem to not work properly with grippy aftermarket tires... main issue is it stupidly cuts power when turning from a stop at an intersection under hard acceleration. The 205/45-17 Continental ExtremeContact DW's I run are too much tire for the systems, especialy with wet grip that is better than the stock tire dry grip. And if you forget to turn the systems 'off' when on track the ABS system freaks out and goes crazy and you can get power cut on you going into the apex, sport VSC mode on the fly does nothing to allieviate the problem - you have to 'fully disable' the systems at a minimum. I'm going to get a custom tailored Beastronix OBDII controller setup to permamently run with the systems normally 'off' at startup, then Pedal Dance at the flick of a switch plus ABS off additionally available at the flick of another switch for track use. As the car will be paid off and title in my name next year I'm starting to get it ready for track use...
Had a '13 FR-S Asphalt 6spd manual (bought new 5/25/12, sold 6/10/20) but needed to let her go... she will be missed.
Vracer111 is offline   Reply With Quote
Old 08-14-2016, 10:30 PM   #80
atlbrz
Drives: Hyper Blue BRZ
Mine is was too intrusive. It activated in a round-about the other day as I was trying to excellerate and exit the round-about.
atlbrz is offline   Reply With Quote
Old 08-14-2016, 10:45 PM   #81
new2subaru
Weight Weenie
Drives: 15 FR-S
Ummm, excuse me, but...
ac·cel·er·ate
əkˈseləˌrāt/
verb
verb: accelerate; 3rd person present: accelerates; past tense: accelerated; past participle: accelerated; gerund or present participle: accelerating
Old 08-15-2016, 03:29 PM   #82
gravitylover
Just a second or two but that's enough for the car to slow a few mph which can catch someone behind and coming up fast off guard. It's not like a total power loss just a reduction in power until the car settles and the computer catches up.
Mine is was too intrusive. It activated in a round-about the other day as I was trying to accellerate and exit the round-about.
Frustrating isn't it.
Old 08-15-2016, 04:18 PM   #83
WWTD
Old 08-15-2016, 10:17 PM   #84
atlbrz
ac·cel·er·ate
əkˈseləˌrāt/
verb
but I excel at accelerating so it is excellerate My poor spelling doesn't negate the crappy stability system on the car. I think it is the weakest aspect of the car. I wish Subaru would offer an upgrade to the software for the stabilty control.
The Following User Says Thank You to atlbrz For This Useful Post:
new2subaru (08-16-2016)
Turn signals don't always automatically turn off one2onejackpot Issues | Warranty | Recalls / TSB 6 04-18-2016 08:35 AM
Turn as tail timing not matching with the front turn signals NahumCC Cosmetic Modification (Interior/Exterior/Lighting) 1 01-03-2016 11:40 PM
Steering wheel issue---left turn lighter than right turn!!! xingxingtjf Issues | Warranty | Recalls / TSB 12 10-14-2015 07:47 PM
Voice Commands with new turn by turn in IOS6? jadewbj Electronics | Audio | NAV | Infotainment 0 09-21-2012 11:11 AM
