#3613 |
I doubt it's the tune. Blaming a FNG on a JRSC is like blaming the CARB tune; this isn't rocket science, and it's not uncharted territory.
Got a log? |
#3614 |
Drives: 23 BRZ
In the mean time, try this; when you pull up to red light, quickly put it in neutral and release the clutch pedal before you stop. The flywheel will keep spinning and less likely to stall.
#3615 |
Drives: 2014 Monogram Scion FRS Whiteout
#3616 |
#3617 |
Drives: 2013 Scion FRS
Looking for advice. Just finished my install. When I first started it up it sounds like squealing on the driver side. Sounds like it is a bearing or belt issue. However I don't know if it is even an issue. Thoughts?
#3618 | |
Drives: JR FR-S,
Also, email us at tech@jacksonracing.com. |
#3619 |
Thanks for the response. I located the reservoir on the passenger side (not my picture), but still 1.125" above Rotrex reservoir clamp. So I did have to route my hoses differently, but matches the diagram.
To me, the sound does not seem to be coming from the Rotrex. |
#3620 |
How's the install guys? I just got my kit in yesterday and I plan on doing it over the weekend.
How long did it take you and what was the hardest part? |
#3621 |
Just installed mine last weekend. I would plan on about 10 hours or so depending on your expertise. Nothing really too hard, a few instructions could be clearer.
| The Following User Says Thank You to snowdog For This Useful Post: | VABeachBRZ (08-16-2016) |
#3622 | |
Read the manual cover to cover a few times, before opening your other boxes. |
#3623 | |
Thanks for your help dude. I'll be reaching out for the duel radiator/oil cooler soon probably |
#3624 | |
I am by no means a expert with installing SCs or anything. I love to do the work myself so I can learn in case something goes wrong down the road |
#3625 |
Drives: '13 FRS
The install was pretty straight forward. As was mentioned before though be super careful about priming the rotrex before you start the car. I followed the instructions and primed it until the traction fluid started coming out of the SC inlet then closed it up. But I have been told my SC is louder than normal and is probably related to poor priming.
So if I did it again I would probably keep priming it until there was a pretty healthy flow out of the inlet as you have extra fluid and want to make sure you get all of the air out. Not sure if someone who has done more kits has any other suggestions for better priming. |
| The Following User Says Thank You to etc For This Useful Post: | Brz866 (04-26-2018) |
#3626 |
This is the best resource I found for removing the bumper and headlight.
[ame="https://www.youtube.com/watch?v=mMdIWZLUEj0"]SPECDTUNING INSTALLATION VIDEO: 2013 SCION FR-S LED PROJECTOR HEADLIGHTS - YouTube[/ame] |
| Jackson Racing Rotrex Supercharger System Info and Discussion | Jackson Racing | Forced Induction | 827 | 04-06-2020 05:56 PM |
| Jackson Racing Supercharger Press Release and Info | CounterSpace Garage | Forced Induction | 110 | 01-03-2017 10:04 PM |
| jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! | CSG Mike | Forced Induction | 24 | 04-27-2016 01:59 PM |
| Jackson Racing supercharger | NoppyNop | Forced Induction | 241 | 06-26-2014 04:05 PM |
| Jackson Racing Supercharger Pre-Order Sale, $200 off! | Xero-Limit | Forced Induction | 2 | 03-05-2014 05:14 PM |
