go_a_way1
Old 07-23-2016, 02:11 PM   #3543
SLC_BRZ
Drives: 2013 WRB BRZ
Originally Posted by swarb View Post
Not hard, but if you are asking, probably too hard.
Just pay someone to do it.
Post pics/specs of your car/wheels.
18x9.5 +35 ESR SR02 225/35 all around
I know I can do it I've done everything on my car including the air suspension. Just never messed with taking apart an actual camber plate before.
SLC_BRZ is offline   Reply With Quote
Old 07-23-2016, 09:51 PM   #3544
Tranz
Tranz's Avatar
Drives: 86 GTS
I never thought I'd actually be able to post here
IMG_0346 by Sebastien Peek, on Flickr
IMG_0349 by Sebastien Peek, on Flickr
IMG_0351 by Sebastien Peek, on Flickr
Unfortunately no full car shots
Tranz is offline   Reply With Quote
The Following 3 Users Say Thank You to Tranz For This Useful Post:
8R6 (08-23-2016), Lococholo84 (08-06-2016), VIP BRZ (07-23-2016)
Old 07-24-2016, 06:42 AM   #3545
swarb
If the spring is tensioned/loaded, you need a spring compressor. If not, you can just take off the top hat and swap them if they are compatable. Some shock shafts may have an allen on top that you need to hold while loosening the top nut with a pass through socket or a wrench.
I think it looks good. Ever consider a 215/40?
Not sure how much bag clearance you have for more camber.
Old 07-24-2016, 10:35 PM   #3546
RSKYBZ
Aloha Served Daily
RSKYBZ's Avatar
Drives: 2015 BRZ World Rally Blue
Hopefully this is good enough. Still rebuilding my SSR Vienna Courages, however currently running on these Work Kiwamis. 17x9 +23 (effective, +38 w/out 15mm conversion spacer).
WORK CR KIWAMI by Jessie Alex Gabbuat Jr, on Flickr
RSKYBZ is offline   Reply With Quote
The Following User Says Thank You to RSKYBZ For This Useful Post:
Old 07-29-2016, 09:18 PM   #3547
chargedup
Drives: SC BRZ
17x9 et17
chargedup is offline   Reply With Quote
The Following User Says Thank You to chargedup For This Useful Post:
DuMa (07-29-2016)
Old 07-31-2016, 04:39 PM   #3548
gurshawnbal
Drives: 2017 Subaru BRZ
Anybody ever ran an 18x10 -1 in the rear? Or anything similar ? 5 inch lips.
gurshawnbal is offline   Reply With Quote
Old 08-01-2016, 02:17 PM   #3549
illmattic
illmattic's Avatar
Work CR-Kai Kiwami
18 x 9.5 +38 all around
10mm spacer in front
5mm in rear
-Flickr-
IG @illmattic86
illmattic is offline   Reply With Quote
The Following 3 Users Say Thank You to illmattic For This Useful Post:
iamhubert (08-01-2016), Lococholo84 (08-06-2016), stancypants (09-30-2016)
Old 08-02-2016, 09:36 PM   #3550
Kuzuri
__(X)__
Kuzuri's Avatar
Drives: '11 Legacy, '89 190E, '78 GS1000
IG: @dustin_faulkner
Kuzuri is offline   Reply With Quote
The Following User Says Thank You to Kuzuri For This Useful Post:
8R6 (08-23-2016)
Old 08-03-2016, 02:25 PM   #3551
HAWAIICALIVEGAZ
HAWAIICALIVEGAZ's Avatar
Drives: HONDA, TOYOTA
Sent from my SM-G935V using Tapatalk
HAWAIICALIVEGAZ is offline   Reply With Quote
Old 08-03-2016, 11:06 PM   #3552
wutangbrz
Drives: 2015 dgm brz
made some minor adjustments fitment wise and im content with it for now.
18x9.5 +5 on airlift bags. around -5 camber all around.
ordered some spacers to play around with fitment, hopefully try and get -8 all around when they come in.
@wutangbrz if you would like to see what more stupid things i do to my car
wutangbrz is offline   Reply With Quote
The Following User Says Thank You to wutangbrz For This Useful Post:
Old 08-06-2016, 05:28 AM   #3553
Tranz
Tranz's Avatar
Drives: 86 GTS
This thing looks wonderful
Old 08-08-2016, 02:10 PM   #3554
wutangbrz
thanks sir!!
Old 08-08-2016, 02:46 PM   #3555
JDLAutoDesign
JDLAutoDesign's Avatar
Drives: 13 FRS
JDLAutoDesign is offline   Reply With Quote
The Following 4 Users Say Thank You to JDLAutoDesign For This Useful Post:
brz11b (09-27-2016), Lococholo84 (08-23-2016), NyC Zn6 (08-08-2016), sqd (08-11-2016)
Old 08-11-2016, 01:59 AM   #3556
Tranz
Tranz's Avatar
Drives: 86 GTS
Possibly grabbing some really rare wheels but I believe they are flat backed, and I want to run some spacers to get the fitment right.
Anybody know how big of a spacer you need for the stock studs not to poke through? -I'd rather not be cutting studs but so be it if its required, hence why I'm asking-
dontlike?dontlookmoveon
Post the Wheels You want On your FRS/BRZ!! Zaku Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1738 10-11-2017 05:29 PM
RPF1 and PF01 aggressive fitment size requests Crossover Auto Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 12 10-22-2012 03:30 PM
post VIN with any problem thread? fistpoint Issues | Warranty | Recalls / TSB 0 10-04-2012 11:11 PM
Do aggressive offsets cause more debris to kick up into the paint? switchlanez Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 09-26-2012 11:03 PM
Scion FR-S / Toyota FT-86 / Subaru with Aggressive Body & High Wing! + VIDEO! Hachiroku Scion FR-S / Toyota 86 GT86 General Forum 538 06-15-2011 03:20 AM
