Old 08-10-2016, 01:32 AM   #1
refriedspinach
refriedspinach's Avatar
Drives: 2016 Raven FRS
New to Tuning
Hey everybody, I just got my OFT hooked up after I got my Tomei UEL headers installed. I'm using the Stage 2 UEL 91 octane tune for it, I'm new to tuning a vehicle so I just want to make sure its running good and I'm not going to damage my car.
I'm In Canada and I've read that I should be using 93-94 octane as ours is less quality than Americas. I've been filling up with Chevron 94.
My questions are:
Is this what us Canadians should be running? is there specific tunes for us?
What should I be Datalogging to make sure everything is ok?
How long does it take your vehicle to learn the new tune/ fuel trims?
how should i drive to get a good datalog?
I drove very casually with the new tune to try and stay in a closed loop so it can learn for about 15-20mins and then drove normally for about 15 min after. I ran datalogs the full time and seen that my LT fuel trim stays at -10.16 at idle and around -8 to -3 under load. the ST fuel trim stayed pretty balanced the full drive.
Sorry if these kinds of questions have bee answered. I've searched for the last few days to preemptively solve my questions but could really find anything for my Canadian situation
All my mods are: K&n drop in filter, Tomei UEL header, q300 Catback Exhuast, OFT
Thanks!
refriedspinach is offline   Reply With Quote
Old 08-10-2016, 06:19 AM   #2
steve99
Drives: FT86
ECU Logging link below should get you started.
Fuel trims seem a little high but likey ok
Old 08-10-2016, 11:11 AM   #3
refriedspinach
thanks for the link! I found some helpful information but I still cant quite get understand if my tune is good or not.
http://datazap.me/u/refriedspinach/l...data=1-5-12-14
Here's the first run, which includes the ECU learning.
http://datazap.me/u/refriedspinach/log-1470805319?log=0&data=5-10-11-12-14
Here's my run form the end of day yesterday, about 20 mins after tuning to stage 2 and steadily cruising around.
-Is the FLKC supposed to be going crazy into +/- 100 like that?
-The Advance Multiplier(Is this IAM?) is staying at 0, and didn't move the full trip.
-knock correction didn't move the full trip either
Old 08-10-2016, 11:26 AM   #4
Boomerang
86
Boomerang's Avatar
Logging some parameters on newer ROMs/cars(like mine and maybe yours) doesn't work. What is your ROM?
Stuff like IAM, FLKC MAF V don't work on newer ROM logging which sucks.
Your AFR and LTFT looks OK to me, but I am by no means an expert. @Wayno and @steve99 are the gurus on this forum on tuning/OFT
Try posting on this thread below for some knowledgeable answers;
http://www.ft86club.com/forums/showthread.php?t=47754
And do some more research so you start understanding the OFT and tuning, plenty of info on this site..
Cheers
Old 08-10-2016, 11:44 AM   #5
refriedspinach
The car is a 2016 MT scion bought new in July.
I'm using the newest ROM from Openflashes site: Toyota GT86 Off-The-Shelf (OTS) Tune Files (v2.076) UPDATED 3/30/16.
The ZA1J__C roms, stg 2 UEL F40C, 91 octane.
Old 08-10-2016, 11:54 AM   #6
Boomerang
86
Boomerang's Avatar
OK, so you have a ZA1JF40C cal id
Google that with FT86 next to it and do some reading
Logging doesn't work on some parameters like mine
Contact Openflash for resolution, good luck because I haven't had any..
Old 08-10-2016, 12:30 PM   #7
vin08
275/1000
Drives: 2016 RS2 auto
Is there any tuning that won't void my warranty and CARB legal? Wish they have something like Ford manufacture release tuning packages.
I have a 2016 FRS RS2 AT with only 1,200 miles on it and dealer gave me 7yr/100k warranty free when I bought the car. So far have installed Injen cold air but afraid to do anything else because of warranty and California emissions.
vin08 is offline   Reply With Quote
Old 08-10-2016, 01:06 PM   #8
everythingsablur
everythingsablur's Avatar
Drives: 2016 Scion FR-S RS 2.0
I think the Injen CAI you have installed could technically already be voiding your warranty. If you do need to make a warranty claim, it may be dependent on your dealer/service technician and how big a stickler they are about aftermarket mods on your car; if they determine that the intake is the cause of whatever problem you run into in the future, you're SOL. If you are truly trying to stay within warranty, you've got to be stock, or use TRD parts.
2016 Scion FR-S Release Series 2.0 #170/1000
everythingsablur is offline   Reply With Quote
Old 08-10-2016, 01:28 PM   #9
vin08
275/1000
I guess it's a good thing I kept my stock intake so I can put it back to stock if needed.
Old 08-10-2016, 01:39 PM   #10
everythingsablur
Yes, hold on to those stock parts (especially if you are leasing and may decide not to keep the car). Revert to stock if needed.
ECU tunes can be somewhat similar. I know the OFT can easily revert back to stock, but like all things it will depend on whether or not the service technician/dealership bothers to look, or bothers to care.
Old 08-10-2016, 07:29 PM   #11
steve99
Drives: FT86
Cheers
correct it looks like
IAM FLKC MAF V parameters not working for logging on F40C rom you will need to hassle the oft guys.
looking at KC Learned it looks ok no knock but their no full throttle run.
Try a full throttle run on second or preferably third 2000-7000
log
AFR
Commanded AFR
LTFT
RPM
load
KC Learned (it works)
throttle
ignition advance
should be able to see if its ok from that.
refriedspinach (08-10-2016)
Old 08-10-2016, 08:19 PM   #12
refriedspinach
log
AFR
Commanded AFR
LTFT
RPM
load
throttle
ignition advance
Awesome! Thanks so much for the reply, I try to get a couple runs in tonight.
Old 08-11-2016, 12:18 AM   #13
refriedspinach
log
AFR
Commanded AFR
LTFT
RPM
load
throttle
ignition advance
Heres a run I did tonight with 2 2nd gear runs at the end.
http://www.datazap.me/u/refriedspina...1?log=0&data=1
Heres a run with a 3rd gear pull as far as I could get it before had to slow down.
http://www.datazap.me/u/refriedspina...1?log=1&data=1
As far as I can tell everything seems fine, though I could be completely wrong.
Old 08-11-2016, 02:45 AM   #14
steve99
Drives: FT86
OK looking at those logs its got a little knock here and their not real bad (be less than stock tune)
see here
http://www.datazap.me/u/refriedspina...zoom=8104-8271
the chunky drops in the KC Learned indicate knock like arround 4000-4500
Also the afr (measured is running about 5% richer than commanded AFR this is fine and safe just costs you some power.
It goes rearly rich on initial throttle application so likely needs the load limits corrected again not critical, it will just stop the car bogging if you jump on the throttle at low rpm
the two runs here one has knock and the next doesnt, see how the KC learned curve is pretty smooth in second run , but in first run its all chunky and jagged thats knock, again not super bad.
http://www.datazap.me/u/refriedspina...zoom=6318-6829
Maybe try a different brand of fuel some are way better than others.
if its still same I would smooth the ignition timing in those problem areas.
But fix up the fueling by taking about 4 or 5% of the maf flow values that will get your commanded and measured afr on target .
then maybe the load limits.
refriedspinach (08-11-2016)
Delicious Tuning - Q&A EcuTeK ProECU Tuning and Maps DeliciousTuning Software Tuning 1213 06-17-2025 04:02 PM
R/T Tuning & R/T Tuning Speed Shop Review Thread R/T Tuning User/Vendor/Sponsor Reviews, Feedback, Comments 37 10-03-2014 02:23 PM
Mann Engineering 2nd Quarter Tuning Days April 25th & 26th by Bill (Delicious Tuning) DesertFrs Northern California 14 04-24-2014 03:15 AM
Delicious Tuning - Dyno Tuning Weekend at Mann Engineering's (San Jose, CA) DeliciousTuning Announcements, Contests, Giveaways 6 09-19-2013 05:55 PM
Visconti Tuning - Latest Forced Induction Tuning Info Visconti Forced Induction 340 04-30-2013 06:33 PM
