Old 08-10-2016, 08:24 AM   #379
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
Originally Posted by cruizin01 View Post
errr. I forget the bluetooth name. Ill have to pull it up. Its a generic elm327 unit though.
Karl07 is using a obdlink usb cable and says it works fine, so I ordered one of those to try out.
I emailed Joying and the only thing they can tell me is to buy "their" obd2 unit. Which if thats all I cared about would be fine but it still doesn't fix the problem with it not pairing to other hardware.
Bit frustrating.
I thought about getting theirs too, but according to an Amazon customer it doesn't turn off when the car turns off... :mad:
-Josh
Old 08-10-2016, 08:29 AM   #380
Yoshoobaroo
TRACKBREAD
Originally Posted by shadoken View Post
Good news everyone , the JOYING logo on the new headunits in the front can be removed. Its just a sticker.
Are you sure? Mine sure doesn't look like a sticker...
Did you get yours to boot up again?
-Josh
Old 08-10-2016, 09:18 AM   #381
arrow34
Drives: Firestorm red FRS 2015
Is anyone using an app for their music? I have been using Powerapp and it is pretty sweet, but the next song buttons dont work with it.... Any ideas?
arrow34 is offline   Reply With Quote
Old 08-10-2016, 11:13 AM   #382
cruizin01
cruizin01's Avatar
Drives: 13' BRZ
-Josh
The only thing that would hurt is leaving the led on in the unit though right?
cruizin01 is offline   Reply With Quote
Old 08-10-2016, 11:31 AM   #383
Yoshoobaroo
TRACKBREAD
Same here, I was hoping this app would fix it, but no dice..
https://play.google.com/store/apps/d...k3188.headunit
-Josh
Old 08-10-2016, 11:33 AM   #384
dchan
Drives: DGM BRZ
If you install the malaysk Roms on it, one of the utilities lets you choose to change the names of the OBD devices it can connect to.
dchan is offline   Reply With Quote
The Following User Says Thank You to dchan For This Useful Post:
Yoshoobaroo (08-10-2016)
Old 08-10-2016, 11:49 AM   #385
Yoshoobaroo
TRACKBREAD
No Malaysk Roms for the Lollipop units yet...
Old 08-10-2016, 12:04 PM   #386
arrow34
Same boat here... I also finally took the protective film off of the screen, that has helped a but with touch screen response...
Old 08-10-2016, 01:16 PM   #387
Yoshoobaroo
TRACKBREAD
-Josh
Just to update: these are stickers and they're pretty tenacious, but they do come off. Much better now!
Just gotta trim the file the back of the dash trim a bit and we're done!
-Josh
Old 08-10-2016, 02:19 PM   #388
j_motion
Drives: 14 BRZ Red premium
Bit frustrating.
naa dont buy their OBD2... my was a stud
it cause CEL on my car and doesnt read at all..
tried it on other car it did not connect to.
But do get a good OBD too.. the reading speed is different..
I tried a few , but eventually pull the trigger on OBDlink
j_motion is offline   Reply With Quote
Old 08-10-2016, 02:23 PM   #389
j_motion
-Josh
My lcd came with a protective film..that fits right over the screen..
Do not remove it..
That film is there to help swiping, it has lower surface energy.
I removed my thinking it was another screen protector form factory.
It will still work after, but the original screen surface has a lot more friction and make it feel giddier.
I seen it on a lot of Chinese LCD panel, they put on the secondary film to help with the smooth swiping
Old 08-10-2016, 05:57 PM   #390
Yoshoobaroo
TRACKBREAD
Have you guys found a way to tweak the text size on screen? Everything in menus is giant in my opinion
-Josh
Old 08-11-2016, 10:14 PM   #391
Rican_D
Rican_D's Avatar
Drives: Asphalt FR-S
Anyone heard any info on update kit for the KitKat Toyota units? Emailed them and they said nothing yet. Don't understand what's the hold up since they are selling the unit with lollipop now.
Rican_D is offline   Reply With Quote
Old 08-14-2016, 02:10 PM   #392
Yoshoobaroo
TRACKBREAD
Guys, heads up about the OBDLINK SX USB cable: it needs full USB power.
So plug it in -by itself- into one of the back ports OR use a powered hub.
I tried a passive USB hub and it didn't work.
Another Android Head Unit Starscream15 Electronics | Audio | NAV | Infotainment 57 08-23-2015 12:41 AM
Dashlinq4 Android Head unit. Stock BRZ fitment. Toyota Universal. junglizste Audio/Visual, Electronics, Infotainment, NAV 3 01-08-2015 11:55 AM
Ca-Fi Dashlinq4 Android head unit universal Toyota phanguy Audio/Visual, Electronics, Infotainment, NAV 4 11-19-2014 11:57 AM
FS: T7019A Android Head Unit pheoxs Audio/Visual, Electronics, Infotainment, NAV 4 08-26-2013 05:05 PM
Android head unit drei Electronics | Audio | NAV | Infotainment 21 07-16-2012 02:42 AM
