Old 08-09-2016, 03:13 AM   #309
Kodename47
Kodename47's Avatar
Drives: UK GT86
Originally Posted by FISHBURGLAR View Post
i dont have the tables for maf ofset and im nervous to add it on my XMLS thats my issue i dont want to brick my ECU and im using the newest DEF from open flash
I posted the defs for you above....
.: Stealth 86 :.
Kodename 47 DJ:
Old 08-09-2016, 06:34 AM   #310
rjgough95
rjgough95's Avatar
Drives: 13 Subaru BRZ, 02 7.3 F350 Diesel
Originally Posted by FRSBRZGT86FAN View Post
Mine does the same it's the side effect of the extra rpms just allow it to warm up more or lower the rpms....
What exactly do I need to lower to make this happen then? Like what tables exactly? If I drop the rpms does anything else have to be adjusted as well?
2.5" Non-resonated Perrin catback - Hks dual resonator front pipe - Borla UEL headers - K&N drop in - Supertek intake pipe - Megans Racing strut bar - Racer X Fabrication cylinder brace - Valenti tail lights - Veloxs Motorsports front splitter - Galvez Customs rear diffuser - Open Flash Tuner - GCS paddles - Apex ARC8 Track Wheels
rjgough95 is offline   Reply With Quote
Old 08-09-2016, 08:40 AM   #311
FISHBURGLAR
Drives: whiteout fr-s
THANK YOU THANK YOU! .i missed your post. thanks to using my phone at work
FISHBURGLAR is offline   Reply With Quote
Old 08-09-2016, 12:51 PM   #312
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
No simply adjust the table A-F for the idle tables, because you already adjusted the maf stuff.
Old 08-09-2016, 01:09 PM   #313
rjgough95
rjgough95's Avatar
Any recommendations on how i should set it up? Thanks!
Old 08-09-2016, 02:31 PM   #314
FRSBRZGT86FAN
You still want it to warm up up to 122 quickly, so from -40 to 122 keep it at 1400 rpm, then from 140 to 176 use 1000 rpm, this should decrease the amount of pulling the car has when you set off. This should also help you notice when the motor is at 122 because you'll notice the idle drop at which point you may set off.
Old 08-11-2016, 09:14 AM   #315
FISHBURGLAR
THANK YOU for posting the DEF and thanks to steveaswell. COLD start is Perfect. time to put my mxp exhaust back on heehhe
Old 08-12-2016, 12:39 PM   #316
rjgough95
rjgough95's Avatar
Can someone check this over please that'd be great. Thanks! 140 I changed to 1150 and 158, 176 to 1000. Reason for that is because of a worry I had with my automatic transmission.
Old 12-06-2016, 02:19 PM   #317
Pointmutation
Pointmutation's Avatar
Drives: 2016 ZC6
Spent all weekend reading through this thread and any cold start related thread I could find. Thanks for all the info everyone!! I'm in a '16 BRZ running a stage 1, 91 octane F40C rom.
My original values for the 91oct Stage 1 F40C rom...
FYI, all the tables where there for me using the defs from OFT's website, at least for F40C. I guess they added those in now??
My modded values...
What I did...
Changed all the Ignition Timing Post Start to -4. Will try 0 later on and see how that sounds.
Changed rows 1 and 2 to match the rest of the rows in MAF Correction After Start (in gear and neutral).
Changed Idle Speed Targets A-F that were greater than 1200 to 1200.
And disabled the P050b DTC.
Double and triple checked work, uploaded modded rom to OFT, flashed the car, and started up while the car was still cold and success! A major drop in cold start noise. Exhaust is still going to be heard by my neighbors, but shouldn't piss them off as much if I need to idle a bit before leaving. FYI, high 70's F would be a 'cold' start where I am. Lol.
Pointmutation is offline   Reply With Quote
Old 02-08-2017, 11:32 PM   #318
vietspride70
Drives: 2016 scion 86
My modded values...
What I did...
well done......I just got 2016 and notice a cold start on this thing with exhaust is loud.
after read through this thread, I still have no clue where to start....
vietspride70 is offline   Reply With Quote
Old 02-17-2017, 12:08 PM   #319
Travisty75
Travisty75's Avatar
Drives: 2015 Scion FR-S
(Image)
My modded values...
(Image)
What I did...
Just wanted to bump this up and comment about my setup.
I didn't see your values here, but mine is setup very closely to yours. I had read earlier in the thread that people were saying to not copy the MAF offset values because they'd be too low, but I selected all the high tables, multiplied by .8, then horizontally interpolated to have a more smooth ramp effect as the car warms up. It works great!
There is still an initial bark when the car initially catches, but it immediately settles down to 1000rpm (my only tables above 1000 are down near 15°f). I'm going to try playing with the initial Cranking Injector Dwell setting to see if I can get the car to stay below that 1000rpm mark, but I was playing around with that before and it had a poor side effect of causing an extended crank before firing.
Anyways, @Pointmutation you have it set up right and now there is absolutely no cold start high idle. Job good!
Travisty75 is offline   Reply With Quote
Old 02-19-2017, 04:59 AM   #320
Pointmutation
Drives: 2016 ZC6
What I did...
Update on this... I got headers now and had to change the Ignition Timing Post Start to 0. Before the headers, setting it to zero sounded a little anemic so I had kept it at -4. Post header install, zero sounds better than before but not as loud as -4 without headers. So you can still tell there's an exhaust, but more so I'm not pissing off the neighbors leaving the house late at night/early morning hours as much anymore.
Old 02-20-2017, 10:32 AM   #321
D_Thissen
D_Thissen's Avatar
Just to confirm, these are safe to use with the OTS (AO1C) v2.06X maps? Just replace the XML def in romraider with these instead of the ones provided by shiv, correct?
Old 02-21-2017, 11:42 AM   #322
Kodename47
Kodename47's Avatar
Drives: UK GT86
I will assume that those are still based on the B01C ROM, if so then yes.
.: Stealth 86 :.
Kodename 47 DJ:
D_Thissen (02-21-2017)
Cold start question retrosmiths Scion FR-S / Toyota 86 GT86 General Forum 106 11-15-2016 02:14 PM
Cold weather knocking during start ups. JDMenrique Issues | Warranty | Recalls / TSB 38 01-12-2015 11:53 PM
backfire at cold start FreaQshoQ Scion FR-S / Toyota 86 GT86 General Forum 15 10-16-2013 06:21 AM
White Smoke cold start up in Cold Weather (turbo cars) whitefrs Forced Induction 17 09-25-2013 05:05 PM
Loud cold start and mpg drop since new be6sti Issues | Warranty | Recalls / TSB 7 11-28-2012 01:35 PM
