Doborder, orthojoe
Old 06-17-2016, 01:37 AM   #197
XanRules
A Very Powerful Wizard
XanRules's Avatar
Drives: 2014 BRZ LTD WRB (RIP), 2017 FiST
I just did it by hand, "really tight" ¯\_(ツ)_/¯
XanRules is offline   Reply With Quote
Old 06-17-2016, 02:49 AM   #198
tofurun
tofurun's Avatar
Drives: 2014 BRZ Limited 6MT
Lol I'll pass on that one but thanks I guess
tofurun is offline   Reply With Quote
Old 06-17-2016, 02:53 AM   #199
tofurun
tofurun's Avatar
Found it. 36.1 lb same as other one on dif if anyone was wondering
Old 06-17-2016, 03:28 AM   #200
XanRules
XanRules's Avatar
Old 07-02-2016, 09:40 AM   #201
Curtski96
Curtski96's Avatar
Drives: Pearl white '13 frs
Simple and effective I love it and plan on doing this In The near future the sooner the better!! I'll be using amzoil
Curtski96 is offline   Reply With Quote
Old 07-11-2016, 02:57 PM   #202
BDKane01
BDKane01's Avatar
Drives: 2016 Subaru BRZ Limited CWP MT
I called Subaru to order the washers for the trans and the diff. The parts guy asked on e of the techs and they said that they are aluminum/reusable. He stated I wouldn't need to replace that.
Is that true?
Hindsight is 20/20
BDKane01 is offline   Reply With Quote
The Following User Says Thank You to BDKane01 For This Useful Post:
N_AL_spyder (03-07-2019)
Old 07-11-2016, 03:09 PM   #203
tofurun
tofurun's Avatar
Is that true?
I wouldn't do that. They're crush washers. One they crush they're done. If you insist on re using make sure u at least flip them. I have seen many motorcycles leak oil from not replacing the crush washer.
Old 08-03-2016, 09:33 PM   #204
BRS86
Silly question... but for MT.. do I leave it in neutral or in gear?
BRS86 is offline   Reply With Quote
Old 08-04-2016, 02:07 AM   #205
aegisdrgn
aegisdrgn's Avatar
Drives: Scion FR-S 10 Series #2263
Either. Doesn't matter. However, it'll make your life easier to leave it in neutral (if you're using a floor jack).
aegisdrgn is offline   Reply With Quote
Old 08-04-2016, 11:45 AM   #206
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
just reposting so people get correct washer
Differential fill plug gasket: SU00300122 @$2.30 each- part no.11126jb000
Differential drain plug gasket: TOY1215710010 @$1.50 each - 1215710010
Transmission fill/drain plug gasket: SU00303626 @>$11 each
SU003-03626 for the transmission drain and fill washer gasket is the same exact size as hondas transmission drain plug and it costs 2.27 instead of 11 bucks.
save some money. hondas part number is 90471-px4-000
I went to Honda and got their washer (
90471-px4-000) and worked perfectly
The Following 3 Users Say Thank You to zc06_kisstherain For This Useful Post:
aegisdrgn (08-05-2016), BabaYaga (09-09-2016), ddevl_86 (04-02-2021)
Old 08-05-2016, 01:14 PM   #207
Black Tire
Black Tire's Avatar
Drives: Whiteout Scion FR-S
Rusted Plugs!
I change the differential and transmission fluid every year using Amsoil. This year, the fill and drain bolts were very rusted (outdoor parking and Minnesota winter road salt). I had trouble getting the hex wrench in the socket in the bolts, and used PB Blaster to make removal easier. I went to the dealer to look for new ones, and they wanted $13 each, so four bolts (2 for transmission, 2 for differential) would come to $52. Also, they did not have them in stock and would need to order them. Since it was Saturday, they would be ordered on Monday, and be in later in the week. My diff and transmission were already drained with the car on jack stands, so I came up with an alternative.
First I soaked the bolts in Evapo-Rust to get rid of the rust. The photo shows the bolts soaking in the Evapo-Rust solution, about an hour after putting them in. Note that only the exposed heads of the bolts are rusted, the threads are very clean. It took many hours before the bolt heads were nearly clean. I rinsed them and you can see the difference in the photo. I did re-soak them after that photo was taken to try to remove as much of the rust as I could. Some black spots appeared on the bolts at this point, but this is just carbon from the steel according to the Evapo-Rust website, and should not hurt anything.
I punched holes in cardboard with an old part of a lamp pole. The holes were just smaller than the bolts, and so I just screwed them into the cardboard. Then I painted one coat of Rust-Oleum etching primer, and one coat of yellow enamel. I didn't want to get the paint too thick where I couldn't easily fit in a wrench. Also, you are not supposed to use this paint for galvanized metal, but I figure most of it was worn off anyway and it's better than nothing. I used a halogen shop light that puts out a lot of heat about a foot away from the cardboard to "cook" the paint to speed drying, as it was quite humid at the time.
You can see the results. Hopefully when the time comes next year, the bolts will have little or no rust. The paint was slightly damaged by installing the bolts, but it should still protect them better than no paint at all.
My cars always dress formally. They all wear black tires.
Black Tire is offline   Reply With Quote
The Following 4 Users Say Thank You to Black Tire For This Useful Post:
aegisdrgn (08-05-2016), Insurme1 (09-09-2016), sato (08-05-2016), zc06_kisstherain (08-05-2016)
Old 08-05-2016, 02:53 PM   #208
zc06_kisstherain
Drives: SWP BRZ
^ looks pretty good to me!
Old 08-05-2016, 04:02 PM   #209
KnightRyderx2
Drives: 2014 FR-S
I think I need to do this. My transmission could be a little smoother and Im sure the trans and diff fluid was not changed before. Ill probably be doing this within the next couple months.
KnightRyderx2 is offline   Reply With Quote
Old 08-07-2016, 09:00 AM   #210
BRS86
Thanks!
Also bump to the OP for the write up! Did it yesterday and the results were amazing!
differential, diy, fluid, transmission
Transmission fluid swap? flawedchemical Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 48 09-12-2014 03:23 PM
What Differential fluid is in your BRZ/FRS? ft86Fan Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 9 11-12-2012 09:57 PM
Anyone change transmission lube yet? BMWDavid Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 14 08-21-2012 06:47 AM
FR-S quick reference and warranty / maintenance guide is up pkny Scion FR-S / Toyota 86 GT86 General Forum 15 06-21-2012 12:33 AM
topspeed difference between manual transmission and automatic transmission torquemada BRZ First-Gen (2012+) — General Topics 51 05-04-2012 08:54 PM
