Old 08-06-2016, 06:24 PM   #1
phatroksek
Drives: 2014 Subaru BRZ
Unichip & Perrin 3" CAI - map availability?
Hi All,
I've been trying to figure out a P0171 lean code and have gotten all the way down to... Jack @ Unichip doesn't provide a map for a 3" Perrin CAI.
It would've been awesome had they specified that upon point of purchase instead of simply saying "Perrin CAI"...
Jack hasn't been active on the forums anymore, and unfortunately, based on my 1 email interaction with him; he's back to his norm of where I saw many bad reviews about him on other forums. Where did the Jack from posts on this forum go???
Anyhow, I want to keep everything set up as is and am hoping to just drop in a different map to get my Perrin 3" CAI working. I don't want to spend any more money with Unichip just to access their maps database just to find out that nothing will work so hoping to get some confirmation from any of you wonderful people on here that have tried to run a large diameter intake with Unichip.
Thanks all!
phatroksek is offline   Reply With Quote
Old 08-06-2016, 06:49 PM   #2
steve99
Drives: FT86
Originally Posted by phatroksek View Post
Hi All,
Thanks all!
Unfortunatly no one on these forums that im aware of develops maps for unichip.
you would have to log data and then use this info to rescale \adjust how the unichip alters the maf input to ecu to suit the perrin 3" intake.
With flash systems like oft tactrix ecutek this involves rescaling the maf sensor tables within ecu. However unichip works by altering\intercepting som input signals from sensors, im assuming it does maf (mass air flow) and presenting an altered input signal to ecu.
Intakes on naturally aspirated 86\brz\frs produce very little power over a drop in filter, but they can cause you a few issues especially where the size of the maf tube is changed like in 3" perrin.
my suggestion woul be sell the intake and put the stock one back with a drop in performance filter.
I doubt you will get any support for unichip, the flash systems are far superior, unichip gained some popularity in very early days before flash systems cracked the ecu code.
Second suggestion would be stick with what you have with unichip or just sell it as well and get a flash tune from someone.
Old 08-06-2016, 06:57 PM   #3
phrosty
When Unichip was in development for the 86, Perrin only had their 2.75" intake available.
I'd be very surprised to see any further investment from Unichip, given that flashing has been made so painless and gives an objectively far better result.
phrosty is offline   Reply With Quote
Old 08-07-2016, 10:38 AM   #4
phatroksek
thank you so much for the info!
yea I thought I was going the right direction, and I think I still am, as far as keeping it simple; I don't care much for creating big horsepower so I think I'll sell this intake, put the stock one back in to ensure that I stop throwing this P0171 lean code, and then drop in the 2.75" Perrin and all will be done.
cheers guys!
Old 08-07-2016, 10:53 AM   #5
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
One thing I have messed around with a little is to compare AFR results from the untuned dyno runs from this article http://dsportmag.com/the-tech/scion-...ogramed-ecu/2/ with my Weapon R and use the most similar result to see how that tune works. The TRD intake was closest to the Weapon R results and I tried the Unichip map for the TRD intake and it worked really well.
If yoou can find a dyno run WITH A/F ratio, you can compare to the dsport article's intakes and hopefully one of them will be similar and there's a Unichip map for it. It's a long shot, good luck. Choose an intake that runs very lean untuned like the Perrin seems to.
What does your LTFT look like after a good long drive?
guybo is offline   Reply With Quote
Old 08-07-2016, 04:15 PM   #6
Lantana frs
Drives: 13 frs red
Stock intake is well designed. The tune can be optimized because of inefficiencies due to mpg/emissions requirements. Intakes, catbacks are for sound and aesthetics. There is some meat on the bone with cam timing, fuel, advance etc. Amazing stuff
Lantana frs is offline   Reply With Quote
WTT: Perrin 3" Catted Front Pipe + 3" Perrin Resonated Exhaust for 2.5" Setup projek_01 Canada Classifieds 3 03-03-2016 02:45 PM
FS: Unichip w/ Cable and Perrin Battery Tie Down DieselxIndustry Engine, Exhaust, Bolt-Ons 3 01-04-2015 10:18 PM
Unichip w/ flux 2 and Perrin CAI FOR SALE!!! AMAY93 Engine, Exhaust, Bolt-Ons 8 07-24-2014 11:44 AM
Unichip + Fluxx2 and an OBDII "Y" Splitter ReThink Software Tuning 4 10-12-2013 04:38 PM
Perrin intake (full) Unichip+bracket+cable Hix Engine, Exhaust, Bolt-Ons 6 09-16-2013 07:21 PM
