| Other Vehicles & General Automotive Discussions Discuss all other cars and automotive news here. |
| View Poll Results: What name should Toyota use for the production Toyota FT-1? | |||
| Supra gets my vote! |
367 | 74.59% |
| I don't know, but its time for a new name. |
125 | 25.41% |
| Voters: 492. You may not vote on this poll | |||
#1051 | |
I think the car's curb weight will be a huge factor with this car. The 4 cylinder model should weigh under 3200lbs for people to take it seriously. Then it can compete with the new 4 cylinder Cayman. |
#1052 |
Huge E85 fan!
Drives: 2016 Scion FRS
This thing needs to be well under 3000 and very low COG so it handles for that money. I know it won't be a h 6, but wouldn't that kick ass?
Almost every car is DBW now, v8 or otherwise. Turbo components don't weight much. I'm sure some of the exotic v8 engines weigh less than a regular turbo 4 but this wont be a $ 200,000 machine. Take for example the Mustangs. I looked at 2015 models- the v8 is 150 lbs heavier. The genesis coupe v6 is a couple hundred lbs heavier than a 2.0t. The Camaro turbo 4 is the lightest in the lineup too. A Supra with a 350 hp turbo 4 and an option for a 450 hp tt 6 cylinder? Yes please! But it's a fantasy, I don't even think this car will ever get to production. |
#1053 |
Drives: many
I too also would like to see < 3,000lbs. The 86 already failed when it came in significantly over the hoped 2,500lb mark. I can get close stripping it, so it wasn't a complete deal breaker for me. A CF structure weighing over 3,200lbs would just be FAIL imo. Much like the portly Alfa 4C in US spec being almost 2,500lbs which is bloated by MR-S and Elise standards.
I was hoping for an inline 6, but if it's as bad as this article below says, maybe the decision to dump BMW power and go in-house for a clean sheet V6 makes sense for Toyota. I only hope a new twin turbo V6 gets V mounted turbos like the latest Merc power plants to clean up the lag. http://thegarage.jalopnik.com/bmw-en...hit-1784684330 They should just re-engineer the 2JZ and make it the basis for all their 4 bangers in the future. |
#1054 |
Now w/ over 400 womprats!
Drives: BRZ LZR
Y'all are straight crazy if you think it'll be sub-3000lbs. Need I remind you of the heavy MKIV and even heavier MK3? Lightness is important to an extent, but this is a GT car, not a track day car. It will be comfortable and well equipped which, unless you're a McLaren, means a fair bit of mass.
- The Ancient BRZ Sacrament by Zaku |
#1055 | |
Drives: many
I don't see why the last gen Supras weighing a couple tons would be something for anyone to aim for in a new modern car using carbon fiber technology. I'll take good suspension tuning and adaptive rates in a light car over bad suspension tuning in a heavy car any day. The Supra is a performance car, not a lead sled, so turning and braking are actually going to matter. I'd rather see Toyota do that with something lighter and more responsive than a lard ass Camaro. If you want something to aim for from the last gen Surpras, shoot for an over-engineered and indestructible power plant, not excess weight. Realistically, 2950-3100lbs for base RWD (4/6 cyl) up to 3200-3350 for a supercapacitor hybrid AWD model would be acceptable I think. |
#1056 |
Has anybody seen any OFFICIAL updates on the concept? All I can find from Toyota is 2 year old press releases and a bunch of pics in their Concept section on the web page. Debating weight may be all fine and dandy since if it just remains a concept it's production weight will be zero.
#1057 | |
Drives: BRZ LZR
Also @abraxis, remember that this is going to be a conventional steel unibody car, so it won't be starting with as little weight as a carbon monocoque. I think 3100 lbs is definitely a good place to shoot for, but to be honest, I don't think it'll be much lighter than an LFA, which uses copious amounts of carbon fiber and aluminum, all while being roughly the same estimated footprint of the new Supra. For reference, the LFA weighs in at 3263lbs according to official figures, and in this day and age, that's quite light for that segment.
#1058 |
Panda Trueno
Drives: No twin now.
Considering the NSX is 3800 lbs and the Z06 is 3300.... to say this car "should" be under 3,000 or "around" 3100 is pretty ludicrous.
This will be a somewhat luxury GT car with a nice suspension and a bit of power. I'd expect it to be somewhere between those two cars, and hopefully perform somewhere in the C7 area in all categories. |
#1059 |
Drives: many
Do you have confirmation on this? The Z5 and Supra were supposedly looking to expand use of BMW's CFRP from the i3 and i8.
![]() http://www.extremetech.com/extreme/1...bon-fiber-cars That was one of the reasons for the Collaboration/MoU between the two companies. |
#1060 | |
Drives: many
http://corvettes.about.com/od/buying...rvette-Z06.htm Don't even get me started on the drama this NSX project turned into. It's nice their engineers finally figured out how to mount an engine without burning the car to the ground. On the luxury side, is this supposed to be a Toyota or a Lexus? Because the difference can be upwards of 100lbs or more depending. Last edited by abraxis; 08-04-2016 at 01:30 PM. |
#1061 | |
Panda Trueno
You're right, base model C7 is the lower weight. What does the supercharger and V8 have to do with anything? That setup is lighter than the GTR's DOHC twin turbo setup, which would be similar in weight to the Supras proposed DOHC twin turbo (probably.) I would expect a car of this caliber to come equipped with leather seats, premium stereo, and some nice amenities.... so yeah, an upscale Toyota. LT4 = 529 pounds VR38DETT = 608 pounds So says the internet, lol. More turbos and more cams = more weight... but it needs the power to go along with it as well. |
#1062 | |
Drives: many
BMW N55 3.0L Turbo I-6 is 427lbs. So 102lbs lighter than the LT4 even with more cams!! The S55 Twin Turbo is 452lbs. http://www.eurocarnews.com/0/0/116/0...lvetronic.html MB M178 4.0L TT V-8 is 461lbs. So 68lbs lighter than LT4. That has more cams and turbos too. http://www.autoblog.com/2014/07/25/m...g-gt-official/ Ford Ecoboost 3.5L Turbo V-6 is 417lbs. 112lbs lighter than the LT4. http://www.cjponyparts.com/ford-raci...hp/p/M600735T/ Ford Voodoo 5.2L V-8 DOHC flat plane crank somewhere < 440lbs. I'm not going to speculate on what Nissan does and whether Toyota will put anything like the VR in the Supra. I hope not. The idea Toyota is developing a clean sheet engine which would just be a copy of a competitors decades old design doesn't make much sense to me. Also, the N55 is built by Steyr in Graz, Austria. Same place as the Supra supposedly. Last edited by abraxis; 08-04-2016 at 03:41 PM. |
#1063 |
Drives: 2018 BMW M240i
Just give me:
2 doors <= 3200lbs 400+hp well equipped price of <=$50,000 Making me happy is very easy, DO IT TOYOTA! |
#1064 | |
Panda Trueno
The Z06 has gained weight along with a whole new body redesign, a different motor with new technology and upgraded interior options. Also it has to keep up with the current government mandates. Using the LS7 to compare weights is not the greatest idea either, you'd have to directly compare to the LS9 (supercharged motor to supercharged motor) but it is still a moot point since the C7 is a complete redesign both in vehicle and drivetrain compared to the previous gen. At least when comparing C5 to C6 they shared a lot of the same underpinnings. I just used the Nissan engine as a basis for a car in a similar category and a direct comparison to an engine that randomly got sidetracked to. ![]() All of this is conjecture, obviously. I just would not and have never considered that the Supra would be anything but a Toyota rival to the corvette, but a bit softer overall. So, similar or higher weight and similar performance, but possibly more enjoyable over a long drive. |
| Tags |
| bmwforsuckers, boring-zzzzzzzzzzzzz, brz, celica supra confirmed, frs, ft-1, hatch-y +1, morethanucanaffordpal, nomanualnogo, supra, toyota, twins, watstheretailon1ofthose |
| Toyota FR-S : Official Name for the FT-86 Concept? | Dark | Scion FR-S / Toyota 86 GT86 General Forum | 155 | 08-04-2010 11:05 PM |
