Old 08-02-2016, 10:41 AM   #14925
Tectoniic
#FiftyShadesOfBlue
Tectoniic's Avatar
Drives: 2015 FR-S
Open ended lugs would fix that. Be aware Subaru uses the common aftermarket bevel on their lugs so stock lugs are compatible with most aftermarket wheels
Yep, going to try and avoid if possible as I'm not a fan of the open ended lug look but I may end up having to go to it.
Ideally I want to have the new wheels/tires on with no spacers and then in the winter go back to stock wheels with spacers for "flushness" with both sets of wheels without having to change the studs.
Engine/Exhaust: OFT w/ E85 Tune | FT86SF Catted UEL | Invidia Q300 Catback
Wheels/Tires/Suspension: Avid.1 AV-20 18x8.5 +33 w/ 245/35/18 PSS | RCE Yellow Springs | Velox LCAs
Cosmetic: Valenti FT86SF Special Edition Tails | Diode Dynamics Full HID/LEDs | BRZ Fender Garnishes
Tectoniic is offline
Old 08-02-2016, 11:14 AM   #14926
Nevermore
Wayward Member
Nevermore's Avatar
Drives: Hot Lava 86
Word of advice as well, if they are not hub centric and have a much wider bore, you will need skinny lug nuts. I found out the hard way that if you increase the bore, but keep the bolt pattern, the space has to be lost somewhere, and that space is lost in the bolt holes.
Nevermore is offline
Old 08-02-2016, 11:19 AM   #14927
Ashikabi
Ashikabi's Avatar
Some lugs have little caps so they look closed
Ashikabi is offline
Old 08-02-2016, 11:34 AM   #14928
Tectoniic
#FiftyShadesOfBlue
Tectoniic's Avatar
Drives: 2015 FR-S
I have the proper hub adapters and the "tuner style" lug nuts to fit as they do have a smaller bolt holes.
I'll look into open ended with caps but for now I'm holding out.
This is why I held off on wheels because there are just so many things you have to make sure you have correct between bolt pattern, offset, stud length, clearance w/ fenders, tire+wheel diameter vs OEM, brake clearance etc..... I'm sure there will still be something I forgot when I go to install them...
Old 08-02-2016, 11:48 AM   #14929
Nevermore
Wayward Member
Nevermore's Avatar
Drives: Hot Lava 86
Have you tested them to see that they fit? I had tuner style lug nuts that didn't fit my forgestars.
Old 08-02-2016, 12:02 PM   #14930
Tectoniic
#FiftyShadesOfBlue
Tectoniic's Avatar
Drives: 2015 FR-S
Not yet, but I'm testing them tomorrow before I order the tires. I did think that far ahead
Old 08-02-2016, 01:13 PM   #14931
Nevermore
Wayward Member
Nevermore's Avatar
Drives: Hot Lava 86
Yeah, I did not know my lug nuts didn't fit until the tires were mounted, I had gone out and bought a new jack and torque wrench, the car was jacked up with the stock wheel off and the new wheel on. I was pissed.
Old 08-02-2016, 01:17 PM   #14932
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
Well I am back from my trip, so here is a TL;DW (Too long; didn't write)
It was awesome I drove through Alberta and BC in Canada, Washington, Idaho, and Montana in the USA. Car is great on gas. My girlfriend is a princess lol. Northern Montana has some of the best twist roads with high speed limits. The I-90 in Washington (I think that's what it was) is the worst road I have ever driven on, it may have been a gravel road it would have been smoother.
go_a_way1 is offline
Old 08-02-2016, 01:20 PM   #14933
FX86
i quit smoking today cold turkey
FX86 is offline
Old 08-02-2016, 01:31 PM   #14934
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Almost had a heart attack when Doug Demuro posted he was leaving Jalopnik. Though Im worried too much of a good thing on Oversteer will kill his brand.
He's kinda like a calmed down version of @MisterSheep and @go_a_way1
finch1750 is offline
Old 08-02-2016, 02:19 PM   #14935
There are tornados that are a "calmed down version" of Way!
Tcoat is offline
Old 08-02-2016, 04:00 PM   #14936
FX86
sometimes i switch to the BRZ forums on here just so I can change the color of the twin in the banner to blue because it matches the background
FX86 is offline
Old 08-02-2016, 04:07 PM   #14937
Tectoniic
#FiftyShadesOfBlue
Tectoniic's Avatar
Drives: 2015 FR-S
And because they get a nice quarter panel view whereas us FRS plebs get a side shot with tires that have a 3mm sidewall
Old 08-02-2016, 04:28 PM   #14938
Or just leave it in All and forget the banner is there. I had to go and look to figure out what the hell you guys were talking about.
Tcoat is offline
