Old 07-30-2016, 02:14 PM   #1
denso
Drives: 86
Oil gallery
Hi, did anybody know if the oil gallery plug near the throttlebody connector will supply enough oil to feed a turbocharger with a -04AN feed line? Thanks.
denso is offline   Reply With Quote
Old 08-01-2016, 07:47 AM   #2
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
I'm feeding my turbo from there, 2+ years.
The Following User Says Thank You to Sportsguy83 For This Useful Post:
denso (08-02-2016)
Old 08-01-2016, 08:01 AM   #3
FRS Justin
Drives: 2013 Asphalt FRS
Outfront Motorsports sells a really nice one piece stainless fitting, with a AN fitting made on to it.
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S
710whp
FRS Justin is offline   Reply With Quote
The Following User Says Thank You to FRS Justin For This Useful Post:
denso (08-03-2016)
Old 08-03-2016, 04:25 PM   #4
denso
Drives: 86
Thanks but I did one on my own.
Old 08-03-2016, 11:04 PM   #5
GsxrMe
GsxrMe's Avatar
Drives: Late 2014 Subaru BRZ
Only way it should be. The t fitting leaked no matter what. tap that bitch!
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe
GsxrMe is offline   Reply With Quote
Old 08-03-2016, 11:20 PM   #6
blindfold
Drives: brz
is that location also a better place for oil pressure? From the oil filter sandwich location, oil pressure gauge need is moving similar pace to rpm needle, are you guys facing similar problem? Thanks
blindfold is offline   Reply With Quote
Old 08-04-2016, 08:09 AM   #7
GsxrMe
GsxrMe's Avatar
It can be used to whatever you choose. I personally don't track the car and I have a Forester XT oil cooler on my car. I don't have any sandwich plates or 3rd party oil coolers to use as better tap for the oil pressure sensor. I just check for leaks, change my oil every 3k miles and check oil level every other fill up.
2014 Subaru BRZ
XXR 527/530 Gallery JoeBoxer Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2534 02-07-2021 10:01 PM
FT-86 Wallpaper Gallery Hachiroku FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 80 05-22-2014 09:12 PM
Carrozzeria Gallery Carrozzeria Other Vehicles & General Automotive Discussions 6 08-23-2013 04:25 PM
New Gallery of TRD Parts harajukukei FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 50 06-18-2013 10:33 PM
Projects and Gallery Dezoris Member's Car Journals 0 10-26-2012 05:30 PM
