Old 07-28-2016, 09:14 PM   #99
wireman957
wireman957's Avatar
Drives: 2015 FR-S MT Steel
Originally Posted by OldSkoolToys View Post
That's not warp speed *ahem* *cough*
Oh, picky, picky, picky. It's just a gif to accentuate his point which is pretty much dead on.
"No matter where you go, there you are" - Buckaroo Banzai
wireman957 is offline   Reply With Quote
The Following User Says Thank You to wireman957 For This Useful Post:
Tcoat (07-28-2016)
Old 07-28-2016, 09:18 PM   #100
Nah I was trolling and picked warp speed and that gif just to see how long before somebody called it.
I am a bi universe sci fi nerd and swing both ways.
It did help with the point though as well.
wireman957 (07-28-2016)
Old 07-28-2016, 11:17 PM   #101
OldSkoolToys
Is a Monster
OldSkoolToys's Avatar
Drives: AE86, MA70
I'm a fan of both as well. It's just the nerd in me that couldnt help but point it out.
OldSkoolToys is offline   Reply With Quote
Old 07-29-2016, 03:16 AM   #102
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Originally Posted by cf6mech View Post
and no it doesnt handle any better or any worse but almost exactly, if not exactly the same.....total drive train weight gain for me was right around 100lbs..most of the weight gain is from the heavy Tremec compared to the Aisen
Something seems to be wrong with your numbers. Do you tell us that a V8 engine weights the same with the FA20 engine? I am not sure about the details of the LS engine, but the FA20 engine has an aluminum block and cylinder heads. Overall, it is a well thought and modern design engine.
And how did you check that your car handles the same? You are getting too far with this. Even if you have in total only a 100lbs difference, you should have a reasonable difference in handling because the car's center of gravity is now much higher. I don't think there is any other production engine that can sit so low in our cars.
So, I don't accept your argument that you have exactly the same car, but with more power. You made compromises and in fact you got some very bad financial decisions. If you wanted to have a muscle car, you could buy from the beginning a Camaro and have a functional car from day one!
I am not saying that no one else should do this, but at least we should be clear here about the REALITY.
Old 07-29-2016, 10:00 AM   #103
cf6mech
Drives: FRS Silver LS1 swapped.
Well then you need to educate yourself,....dont take my word for it,.....listen to an expert............
http://www.vorshlag.com/forums/showthread.php?t=8275
cf6mech is offline   Reply With Quote
Old 07-29-2016, 10:50 AM   #104
Twinz
Twinz's Avatar
Drives: 2016 FR-S MT, 2015 Scion FR-S AT,
I just skimmed through the two pages, but I did not see anything about how the V8-powerd car handled compared to stock, much less an "expert" opinion on said handling.
They added 134lbs, and the corner balance is over 52%.
Neither of those compromises are a train wreck, but they are compromises.
I have driven a couple miata's with V8 swaps. Maybe they were done wrong, but they no longer handled as well as a stock Miata.
Twinz is offline   Reply With Quote
Old 07-29-2016, 11:03 AM   #105
cf6mech
Ok.....what ever......i was refering to Vorshlag on weights and the balance of the car afterwards not on how it handles.....not going to sit here and argue with people who have never driven my car or a swapped FRS done properly.......no matter what I say im always going to get the fan boys......but yes power is way better and handling is very close to OEM if not the exact same.....with the addition of instant engine torque for steering corrections and engine braking on down shifts is like dropping an anchor out because the car is so light......
The Following User Says Thank You to cf6mech For This Useful Post:
Summerwolf (07-29-2016)
Old 07-29-2016, 11:14 AM   #106
NOHOME
Drives: RAVEN
Oh no doubt!
And then the other guys up the ante and adds more power then, the other guy adds more, then the other, and so on until they run out of money or somebody discovers warp speed.
That is sorta what it felt like to drive the V8 Miata. And I can safely say that the one I drove kept all the nice Miata-like manners and handling until you dropped the hammer. Then it got interesting.
NOHOME is offline   Reply With Quote
The Following 3 Users Say Thank You to NOHOME For This Useful Post:
cf6mech (07-29-2016), Summerwolf (07-29-2016), Tcoat (07-29-2016)
Old 07-29-2016, 11:29 AM   #107
Yes. So no longer a "Miata".
FX86 (07-29-2016)
Old 07-29-2016, 11:46 AM   #108
FX86
right! modding a car to that level makes it technically like this..it's just a body over something totally different from the factory:
Old 07-29-2016, 11:57 AM   #109
Summerwolf
Panda Trueno
Summerwolf's Avatar
Drives: No twin now.
Do a little research, the LSx (x being variant) is a well thought out, modern design as well. Aluminum block and cylinder heads in a compact design with large displacement.
Basically why the engine is swapped so much over offerings by other companies. It is compact, reliable, and lightweight.
FA20 dry supposedly weighs 377 lbs based off a thread I found on ft86club.
LS1, there are multiple quotes depending on where you look.... but fully dressed with oil around 430 according to hot rod magazine.
The Following User Says Thank You to Summerwolf For This Useful Post:
Old 07-29-2016, 12:19 PM   #110
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
The swap seems to add ~100-250 lbs to the curb weight of an 86.
http://www.ft86club.com/forums/showthread.php?t=38499
http://www.vorshlag.com/forums/showt...?t=8275&page=2
ineedyourdiddly
Old 07-29-2016, 12:20 PM   #111
cf6mech
We are not talking this, as some are trying to argue......this is not a Camry, but in my view a engine swap does not make a twin or any other car for that matter change every characteristics of said car to the point it loses its identity in particular quirks and inherent qualities and short comings to the point of badging alone, thats simple ridiculous ......unless you live in a world of only black or white.
Old 07-29-2016, 12:23 PM   #112
Yep. Dry engine weight is just part of it. Changed tranny, more oil, heavier mounts to handle HP and so on all add up.
Some goals to reach for my FRS in 2016 yzhang Scion FR-S / Toyota 86 GT86 General Forum 15 01-20-2016 07:29 PM
Can I get help with my goals? Sulee417 Scion FR-S / Toyota 86 GT86 General Forum 16 05-03-2014 09:12 PM
What are people's car goals? darkonion Northern California 31 04-17-2014 08:06 AM
What is your motivation? Why do you track/autox/etc.? What are your motorsport goals? CSG Mike Tracking / Autocross / HPDE / Drifting 22 02-20-2013 09:18 PM
Forum owner should change the top left image of the forum Hanzo Off-Topic Lounge [WARNING: NO POLITICS] 68 01-27-2012 10:33 PM
