Old 07-27-2016, 06:36 PM   #1
Zeuseidon
Zeuseidon's Avatar
Drives: 2014 Sterling Silver BRZ
CEL P219a after Perrin Inlet and Drop-In Filter
**Disclaimer** I tried searching on the forum and Google. Didn't find this series of events but Found some helpful info about how to read data logs. And have had the OFT diagnostics up and everything "seemed" okay from what I could catch.
Threw code P219A today:
Okay ladies and gents here's the Low down. Been running OFT Stage 2 with Gruppe-S UEL, JDL ultra quiet highflow front pipe, and Corsa Catback for about 3 months.
Just added Perrin Inlet tube and a freshly oiled K&N air filter. 300miles later threw CEL P219A: Bank 1 Air Fuel-Ratio Imbalance.
Checked the sensor, and seals, everything looks to be good. Anyone run into this, or have some suggestions? I have a 3rd gear/4th gear pull recorded but won't be able to load it until Sunday most likely.
Zeuseidon is offline   Reply With Quote
Old 07-27-2016, 06:51 PM   #2
steve99
Drives: FT86
P219A is AFR imbalance ie the ecu is not getting the afr its askiung for.
check your long term fuel trims LTFT with your oft
also log AFR and Commanded AFR
ltft should be below about 8%
afr and commanded afr should follow each other fairly well during accereration
you likely have air leak or over oiled filer and oil got on maf sensor. you can get maf cleaner from auto shop
or you have developed an exhaust leak near or before o2 sensors, did you use new gaskets on header
Old 07-27-2016, 07:04 PM   #3
Zeuseidon
Zeuseidon's Avatar
Steve thanks for the quick response!
I replaced the gaskets all around. Checked for exhaust leaks by way of having someone cover exhaust and didn't see any leaks (I realize it's not the most effective way)
Ltft fluctuates between -2.34/-3.12
AFR and Command AFR seem to follow almost identically. Parameters based on another thread seem about right. However at wot it does read11.25:1
My buddy next door said I may have over oiled as well, but it didn't "appear" to be over oiled.
Old 07-27-2016, 07:22 PM   #4
RobertPaulson
Hisnamewasrobertpaulson
RobertPaulson's Avatar
Drives: 2017 Golf R
man, skip the oiled filter and get yourself a good dry flow filter instead. never have to worry about over oiling and still get the same small HP gains.
This is your life and it's ending one minute at a time.
RobertPaulson is offline   Reply With Quote
The Following User Says Thank You to RobertPaulson For This Useful Post:
Teseo (07-28-2016)
Old 07-27-2016, 08:16 PM   #5
Zeuseidon
Zeuseidon's Avatar
And just like that, 300 miles later, it's off...
Old 09-02-2016, 07:21 PM   #6
phantasticity
Ricer
My LTFT is at 17.18. Is that bad?
phantasticity is offline   Reply With Quote
Old 09-02-2016, 08:49 PM   #7
So, did you clean the MAF like @steve99 suggested ....??
Old 09-03-2016, 12:21 PM   #8
steve99
Drives: FT86
17% does not sound good
you have either changed intake and not re-scaled maf
got dirty/oily or defective maf sensor
defective front 02 sensor
intake leak
exhaust leak
running incorrect tune for fuel used ie E85 on petrol tune or petrol on E85 tune
Tcoat (09-09-2016)
Old 09-09-2016, 08:45 PM   #9
Jetpak
I'm having this problem as well, Fuel trims and AFR look normal. Mine CEL just randomly popped up after a year of having OFT STG 2 with Tomei UEL. I get codes p219a and p119e. I had stock air filter and changed it to K&N after CEL popped up and tried cleaning MAF sensor, but still no luck.
Jetpak is offline   Reply With Quote
Old 09-09-2016, 09:42 PM   #10
steve99
Drives: FT86
Check for intake and exhaust air leaks
Old 09-12-2016, 08:24 PM   #11
Jetpak
and just like that it's gone... I did not do anything lol
Perrin inlet (black) and k&n drop filter iRazor Engine, Exhaust, Bolt-Ons 6 07-14-2016 01:20 PM
FS: Perrin Intake Inlet Tube and Perrin Drop-In Air Filter FirestormFlex Engine, Exhaust, Bolt-Ons 6 03-31-2016 06:35 AM
FS: Perrin Inlet Duct/Hose and Perrin Drop in Filter (SOLD, LOCK) propulsion1 Engine, Exhaust, Bolt-Ons 2 09-01-2015 10:34 PM
Perrin Inlet Tube + Perrin Drop In Filter b1gb2olo Engine, Exhaust, Bolt-Ons 4 02-26-2015 10:50 AM
WTT: TRD drop-in filter and Perrin inlet hose for TRD CAI husker741 Engine, Exhaust, Bolt-Ons 4 02-28-2014 03:00 PM
