Killed Scion
Drives: 2013 FR-S Whiteout
Tom's LED went out!
Just purchased these lights second hand from a forum member who said they worked completely fine and even watched me install them on the car just to find out when i was pulling the car into the garage the drivers side light has 2 or 3 defective leds on the boomerang/running light. I tried to search this topic unfortunately couldnt get anywhere. Is there anything I could do?
Ps these are the red toms
Miyuki みゆき "Beautiful Snow" The Whiteout FR-S Instagram: trevor.parque |
#2 |
Rambling Man
Drives: 2013 FR-S 6MT - In Heaven Now
I wonder if you tried a company like diode Dynamics if they could either fix it or have the parts for you to fix it? Just a thought.... I love those Red TOM'S though...
All we know is.... He's called The Stig |
| The Following User Says Thank You to FNCrazy For This Useful Post: | MisterSheep (07-26-2016) |
#3 |
Is the plastic melted on the inside? USDM or JDM? I would contact TOMS directly, because this is a common issue with these lights.
| The Following User Says Thank You to funwheeldrive For This Useful Post: | FNCrazy (07-26-2016) |
#4 |
Killed Scion
Theyre USDM and the plastic is not melted. I had contacted toms racing usa and still awaiting a response.
#5 |
Killed Scion
Contacted diode dynamics last night and they have already gotten back to me. Great service by them but unfortunately they cant help due to the LEDs being molded into the light
#6 |
The Fail Boat
Drives: CWP S.B.
I don't think you can get a proper response on these unless you brought them brand new?
Let me know when toms get's back to you... maybe contact depo too..? I have a set just like urs.... & I kind want to fix them too. (3 LEDs on the left break light went out)But the only thing on my car that's USDM ...... & Breaks within 1 year... Yaa.... This is why I would always go for JDM on aftermarket stuff cuz quality is just that much better..........USDM is usually "Just bearable" on quality thou its not cheap ebay china part bad but pretty bad none the less in my book. |
#7 |
Space for Rent
Drives: 2014 6MT ToyoBaru86ScionMonogram?
mines went out too on my clear toms
#8 |
Drives: 2017 Subaru BRZ
Some of mine went out too a while back in my clear Tom's. I pretty much gave up after the vendor wouldn't help.
| The Following User Says Thank You to anthonybrz For This Useful Post: | funwheeldrive (08-05-2016) |
#9 |
Drives: Subaru BRZ Stock
This just happened to mine as well. Except mine are Buddy Clubs. If you buy them secondhand unfortunately you're pretty much out of luck.
Oh well...
#10 |
should have stayed stock and bought LED's with the reverse/turn-signal kit from diode dynamics instead
#11 |
Drives: 2013 Subaru BRZ Limited (CBS)
I wonder what it is about TOM's that causes this to happen. I just bought a set of USDM Red TOM's from FT86 SpeedFactory. Hoping this isn't the fate that awaits my units. If it is individual diodes going out, maybe the taillights were not designed with the correct resistors. The OEM LED tailights on my Exige are prone to this. The forum fix has been to crack open the lens (which are ultrasonically welded to the body, so care is to be taken), de-solder any burnt out diodes, solder in new diodes (either from a donor take-off OEM unit from a crashed car or with new diodes), then replace the stock resistors with higher rated ones. The diodes then output less light, but only marginally so and not by any visually appreciable amount. No reported burnouts since. Perhaps this is what might be happening with the TOM's. Just a guess.
2016 Scion FR-S
1991 Acura NSX 2012 Mazda Miata (Track) 2019 Triumph Bonneville Bobber 2007 Suzuki SV650 (Track) |
#12 |
Sarcastic SOB
So, were the LEDs working on the initial install? If so I guess that relinquishes the seller from having to reverse the deal.
Tom's has so many reports like this. I am mind boggled people pay at least 150% of the price of some other tails. I have smoked Valentis from The Speedline and they look great, have been very reliable, and were a good price.
| The Following User Says Thank You to wbradley For This Useful Post: | funwheeldrive (08-05-2016) |
#13 | |
Some people just really dig the design aesthetics of the TOM's.
2016 Scion FR-S
| The Following User Says Thank You to akiranakayama For This Useful Post: | funwheeldrive (08-05-2016) |
#14 |
