Old 07-25-2016, 05:25 PM   #71
cjny
Drives: 2016 BRZ
My magnet technique that doesn't involve bumper removal has been on the car about a month now with zero problems.
cjny is offline   Reply With Quote
The Following 2 Users Say Thank You to cjny For This Useful Post:
shiumai (08-09-2016), Sisko's_Baseball (12-30-2019)
Old 08-03-2016, 11:08 AM   #72
Kerrija
Drives: 2016 Subaru BRZ Limited
Great write up on this. I got mine installed today and it works fantastic! Thanks for this ingenious way of getting our plate on!
Kerrija is offline   Reply With Quote
The Following User Says Thank You to Kerrija For This Useful Post:
Old 08-09-2016, 08:59 AM   #73
shiumai
shiumai's Avatar
Drives: 2013 DGM BRZ, 2020 C8 Corvette
What happens when you remove the license plate - don't the magnets behind the bumper fall out?
shiumai is offline   Reply With Quote
Old 08-10-2016, 12:08 PM   #74
cjny
Drives: 2016 BRZ
The magnets hold the license plate mounting bracket to the bumper. You can remove the plate from the bracket and leave the bracket on the car. Yes, if you remove the bracket the magnets behind the bumper would fall out. Not sure what about that concerns you, though.
Old 08-10-2016, 12:34 PM   #75
kch
Senior Misanthrope
kch's Avatar
It's a good idea, but it makes the solution less flexible. If the only concern is avoiding holes in your bumper, then sure, your solution works well. But some of us like to install/remove the bracket as necessary, which would not be ideal with your method.
Old 08-10-2016, 03:39 PM   #76
cjny
Drives: 2016 BRZ
It takes seconds to install and remove. This is simply not an issue.
Old 08-10-2016, 04:03 PM   #77
shiumai
shiumai's Avatar
Well, it's definitely an option for those who don't want to remove the bumper. For me, I'd rather have the on-off convenience of not having to use loose magnets, as i take the plate on and off often enough.
Take a vid and see how long it really takes - i'm curious.
Old 08-30-2016, 12:53 PM   #78
Kerrija
Well I don't have a video but it's really easy to pop off and back on again. Removing the bumper was the "hardest" part aka the sidemarkers. (Who the hell designed those?) Getting the magnets in place and everything else after that was a piece of cake.
shiumai (08-30-2016)
Old 01-06-2017, 10:06 AM   #79
Leftyonly
Drives: 2017 Toyota 86, Halo
Came her for this thread!! Great idea and write-up.
I did this on my wife's new 2017 86. Easy to do. Side marker lights weren't that hard given the amount of write-ups on the web for their removal. I'd hate to be the first guy that tried it. I would have broken them for sure!
-Richard
Leftyonly is offline   Reply With Quote
The Following User Says Thank You to Leftyonly For This Useful Post:
shiumai (01-30-2017)
Old 01-10-2018, 01:56 AM   #80
Lizrdlover
Drives: '15 FR-S
Put the finishing touches on my '15 FR-S bracket today! I'll update if it falls off--no hooks here. Suggestions?
Lizrdlover is offline   Reply With Quote
Old 01-10-2018, 10:57 PM   #81
shiumai
shiumai's Avatar
Well, it's been almost 5 years since I posted this DIY and it hasn't fallen off yet
The Following User Says Thank You to shiumai For This Useful Post:
Old 01-15-2018, 11:51 PM   #82
SteveSFO
Drives: 2017 BRZ Limited w/ Performance Pkg
Thanks for the tip! Just ordered the magnets!
SteveSFO is offline   Reply With Quote
Old 01-18-2018, 01:00 PM   #83
Localghost
Drives: 2014 WRB BRZ
Thanks for the write-up! I just completed this last night and used 3M automotive attachment tape to attach the magnets to the bumper. I'm thinking this tape should be one of the best options since it is designed for hot, cold, vibrations, and moisture.
Localghost is offline   Reply With Quote
The Following 2 Users Say Thank You to Localghost For This Useful Post:
shiumai (04-16-2018), Sisko's_Baseball (12-30-2019)
Old 04-16-2018, 01:38 PM   #84
MarvinC93
Drives: 2016 Subaru BRZ Limited MT
I did this 2 years ago and it’s holding strong.
MarvinC93 is offline   Reply With Quote
The Following User Says Thank You to MarvinC93 For This Useful Post:
front license plate mount? Jeong Cosmetic Modification (Interior/Exterior/Lighting) 16 02-13-2014 10:54 PM
Frs Cap and OEM Subaru Front license plate bracket Xdragonxb0i Miscellaneous 1 01-16-2013 12:25 AM
Front license plate: Why you don't want the dealer to drill your bumper CircuitJerk Issues | Warranty | Recalls / TSB 53 08-27-2012 02:02 AM
USA front license plate mounting? Slimline bracket mount.. Help across the world :P WTF Scion FR-S / Toyota 86 GT86 General Forum 32 08-23-2012 07:25 AM
2013 BRZ License Plate Bracket Kit Installation Revision‏ taosracer Cosmetic Modification (Interior/Exterior/Lighting) 19 05-26-2012 02:28 PM
