#99 | |
#100 |
Drives: 2014 BRZ Limited SWP 6MT
#102 |
Drives: '23 BRZ Limited
@CSG Mike
Do you think the dual cooler will suffice for an Edlebrock/JRSC kit on track? Assume hood is also properly ducted. |
#103 | |
#104 |
Drives: 86
I'm in the process of installing this radiator but noticed it doesn't have a foam seal around the sides/bottom the way the stock unit does. Should I try to seal the bottom/sides with something or install without?
Also, I'm struggling to find a way to route the shorter line such that it doesn't kink, is there a reason a straight fitting couldn't be used? Seems like a straight AN fitting from both the rad/filter side would connect right up and the house wouldn't have to bend down just to bend right back up. |
#105 | |
Re-use the stock foam. |
#106 | |
Drives: 86
Are you able to send me an appropriately sized AN line with straight fittings? I'll pay for it of course. Thanks! |
| The Following User Says Thank You to Colin86 For This Useful Post: | funwheeldrive (07-22-2016) |
#107 |
Drives: JDM Toyota 86 GT limited
i'm not sure if this question is being asked before.
1. does it fit well with any super charger kit ? considering there are a series of piping going on from the intake to the intercooler then to the charger unit and charger unit to the throttle body. particularly HKS V3 charger. 2. any difference with JDM models ? |
#108 | |
Drives: 2015 FRS
Sent from my HTC 10 using Tapatalk |
#109 |
no one answering
#110 |
Drives: 2014 BRZ
Probably too new and too few people have it. Get the dimensions from Jackson Racing and compare to other units and you'll have your answers...
#111 |
| jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! | CSG Mike | Forced Induction | 24 | 04-27-2016 01:59 PM |
| Jackson Racing Scion FR-S & Subaru BRZ Dual Radiator/Oil Cooler | Jackson Racing | Engine, Exhaust, Bolt-Ons | 0 | 04-25-2016 06:35 PM |
| Jackson Racing Oil Cooler, NA, NEW IN BOX, NEVER INSTALLED. | OkieSnuffBox | Engine, Exhaust, Bolt-Ons | 5 | 01-12-2016 12:26 PM |
| Jackson Racing Supercharger and JR Oil Cooler | bobsacamenoh | Engine, Exhaust, Bolt-Ons | 20 | 12-12-2014 03:00 AM |
| Jackson Racing oil cooler for NA vs FI | ayau | Engine, Exhaust, Transmission | 1 | 05-29-2014 12:04 PM |
