Old 07-18-2016, 05:32 PM   #15
Barusu
Barusu's Avatar
Drives: 2013 Subaru BRZ
Originally Posted by Frs909 View Post
Yes I live off of church in these condos good eye! Lol
Barusu it's actually called Java Pearl it's a brownish Pearl color. If you got an Instagram swing by my page : frs909 I have a video posted where you can see the color little better.
I'll check it out
Barusu is offline   Reply With Quote
Old 07-22-2016, 12:15 PM   #16
asdf
Loading...████████] 99%
asdf's Avatar
Drives: #0517
dang. color and wheels look perfect
asdf is offline   Reply With Quote
The Following User Says Thank You to asdf For This Useful Post:
Frs909 (07-23-2016)
Old 07-22-2016, 12:25 PM   #17
Amillionoh7
Amillionoh7's Avatar
Drives: 13' Raven FRS n 92 Camaro
can you post pics in 1920x1080 i need a new wallpaper
Amillionoh7 is offline   Reply With Quote
The Following User Says Thank You to Amillionoh7 For This Useful Post:
Frs909 (07-23-2016)
Old 07-23-2016, 12:43 PM   #18
Frs909
Drives: 2013 Turbo FR-S Java Pearl
Finally stopped being lazy and installed the my steering wheels. Cusco carbon steering wheel with gt 86 airbag. Airbag was purchased from forum member 6spd
Frs909 is offline   Reply With Quote
Old 07-23-2016, 06:11 PM   #19
FNCrazy
Rambling Man
FNCrazy's Avatar
Drives: 2013 FR-S 6MT - In Heaven Now
How do you like your steering wheel as opposed to stock? I want one, but a bit too timid about changing airbags and explosives! (Wouldn't want Scion still there).
In a million years I never would have picked that color off a wall, but dead gorgeous on your car. Congrats
I make up 112% of what I say.
FNCrazy is offline   Reply With Quote
The Following User Says Thank You to FNCrazy For This Useful Post:
Frs909 (07-24-2016)
Old 07-23-2016, 10:34 PM   #20
Frs909
Thanks man appreciate that! Now as far as the steering wheel, it's pretty straight forward, a lot easier then you would think. Airbag swap literally takes a few minutes, it's just 4 nuts holding the bomb in place and quick swap over to new airbag. Just disconnect battery ahead of time and your good to go! Lastly, steering wheel over stock feels great man, it's a lot thicker when in your hands. Overall excellent feel would highly recommend it.
The Following User Says Thank You to Frs909 For This Useful Post:
FNCrazy (07-23-2016)
Old 07-23-2016, 10:41 PM   #21
FNCrazy
Rambling Man
FNCrazy's Avatar
I've heard that Japan has a single stage bomb while USDM has a dual stage bomb. Did you swap those? Is that not true? It's slightly possible I've been reading The Onion again today.
Also, did you then sell your old one?
Frs909 (07-24-2016)
Old 07-23-2016, 11:40 PM   #22
Frs909
Yes that's true. You would need to swap out the usdm bomb for the Japan one, which is literally just 4 screws on the back. Pulls right out and drops right into the gt86 airbag and then bolts back up with the four screws. Airbag replacement if leaving steering wheel on, with bomb swap etc,literally matter of minutes. Whole steering wheel swap, takes a little longer only due to having to remove cruise control stalk and other small various parts. Everything drops back into new steering wheel though, so it's easy just swapping parts over.
Old 07-23-2016, 11:56 PM   #23
FNCrazy
Rambling Man
FNCrazy's Avatar
I fly a lot. I'm not sure I look forward to seeing what DHS might have to say next time through security
Frs909 (07-24-2016)
Old 07-24-2016, 02:50 AM   #24
Let's not use the term "bomb" when referring to airbags please. It is an explosive charge yes. Bomb it be not.
The charge is very precisely controlled and is about the size of the average person's thumb. It is the expanding gasses from the charge that deeply the bags not the actual explosive energy which is disapated to the rear of the charge.
Yes there are a few differences between the two different systems but there are ways to adapt each to the other. In reality though this is probably one of the worst possible value to cost mods that you can do and you would really need to hate that Scion logo to go to the trouble and expense required to swap an airbag.
[YOYO] (07-24-2016)
Old 07-24-2016, 02:59 AM   #25
FNCrazy
Rambling Man
FNCrazy's Avatar
Took it to PM
Old 07-24-2016, 12:30 PM   #26
[YOYO]
Amazing Member
[YOYO]'s Avatar
Drives: 2014 Whiteout FR-S
Car looks fantastic. Love the 17" Volks + beefier tire look. Awesome paint job as well
MY 86 BUILD
[YOYO] is offline   Reply With Quote
The Following User Says Thank You to [YOYO] For This Useful Post:
Frs909 (07-24-2016)
Old 07-24-2016, 02:26 PM   #27
Frs909
Thanks appreciate that man!
Old 08-03-2016, 01:46 AM   #28
Frs909
Apr ducts/brake cooling kit installed. Few last minute preps for 86 fest.
Beginner STX Build Whiteout FRS Build Thread Hachi86Roku Tracking / Autocross / HPDE / Drifting 21 03-31-2020 07:52 PM
Superpenguin's "Not Another Build Thread!" Build Thread superpenguin Member's Car Journals 7 06-17-2015 04:00 PM
SWP's 13' BRZ Build Thread SWP BRZ Member's Car Journals 2 01-16-2015 01:23 PM
Jac's BRZ build thread Jac Member's Car Journals 0 04-30-2014 07:09 PM
EOJ (Not much of a Build) Thread jonbatz01 Member's Car Journals 41 07-31-2013 07:34 PM
